Page 2 of 22 FirstFirst 123456789101112 ... LastLast
Results 26 to 50 of 536
Thread: We need more build threads: 00 Z3MC SG/DBO
  1. #26
    Oct 2007
    VA
    00 Mshoe
    Quote Originally Posted by FinnNiks View Post
    Looking good! That MM undertray is sexy...
    Thanks, I had one on my E36 and liked it alot. These were a little more difficult to fit, but it works well.
    Did all the wire splicing for the alarm over the weekend. Now I just need a few hours to get all of it ran and plugged in the car sometime this week/weekend.
    Found my camera that had some other updating/cleaning photos. I'll get those uploaded and posted here in the next day or two.
    Hoping to hear back today about the offer I put on the house as well. Fingers crossed.
  2. #27
    Oct 2007
    VA
    00 Mshoe
  3. #28
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    Perfect. Good deal!
    /.randy
  4. #29
    Oct 2007
    VA
    00 Mshoe
    Ordered today:
    Powerflex Diff bushing (purple)
    EGR blanking plates
    Oil filter to block gasket
    Window sliders
    Driver door handle trim
    misc fasteners for some more body part fitting
  5. #30
    Oct 2007
    VA
    00 Mshoe
    UPDATE: 8/17/13
    Got the keyless installed yesterday.
    Had an idiot moment and forgot I needed to change the polarity on the aux1 output from ground to 12V(+) so made a mid-install run to the store.
    Installed and wire tucked up:
    I now have Keyless entry and remote window roll up
    Photos I had from a time before I was working on it but forgot to load up:
    Rusted X-brace got scrubbed and rustoleumed for now:
    Cleaned all the brake parts as well... these are are how I found the sliders:
    And how they went back in
    Also found 13 years of dirt behind the fender liners (weight reduction 101):
    Also have my oil sample ready to go out to Blackstone next week to see how the motor is doing.
  6. #31
    Jul 2005
    Temecula Ca.
    99 M Coupe LS Swap
    I noticed the brake pins had grease on them. That is not good for the OEM rubber bushings the pins slide into. The grease will soften the bushing allowing too much flex and you will get uneven pad wear and reduced stopping ability. They are suppose to be dry. I would replace those bushings. If you have brass aftermarket bushings, not recommended for street use, I would replace if this is street use or lube every couple months.
    Dan "PbFut" Rose
  7. #32
    Z3speed4me's Avatar
    Z3speed4me is offline Coupe Cartel Forever! BMW CCA Member
    Apr 2002
    Westfield, NJ
    MCoupe, Q3, Tiguan
    I'd go amsoil but that's just me.
    I want that MM panel so bad I have to just order one...
    ~Ken~ '99 M coupe THE "original" TT Stage 3 - HTA3586R; 701 whp 672 wtq @ 26.5 psi ; NeverSell - CoupeCartel
  8. #33
    Dec 2007
    Great Dismal Swamp
    Is that grease or deteriorated rubber?
    /.randy
  9. #34
    Oct 2007
    VA
    00 Mshoe
    From what I saw it looked like old grease. I'll be double checking the bushing this next weekend when I replace my rear pads.
  10. #35
    Jul 2005
    Temecula Ca.
    99 M Coupe LS Swap
    Quote Originally Posted by rf900rkw View Post
    Either way, it's not suppose to be there. It's a very easy fix. The bushing just pop out. Clean things up. Replace and do not Lube.
    Dan "PbFut" Rose
  11. #36
    Oct 2007
    VA
    00 Mshoe
    Noted. I never knew to not grease them. Not to mistrust you but I confirmed in my bently they specifically say to not lubricate them. Thanks for the tip.
  12. #37
    Andover, MN
    Z3 Coupe, ZHP, E46 M3
    I greased mine when I reassembled them... Oops
  13. #38
    Oct 2007
    VA
    00 Mshoe
    Boxes erryday.
    More parts to replace this weekend. Got the pads for free till I do brakes for real since the one pad drug ~150 miles on the drive home. Window sliders, oil gasket, replacement door handle cover egr blanking plates and door cards show up tomorrow.
  14. #39
    Jul 2004
    SA TX
    E46 M3
    Looking good bro.
    M driver, RSV4 Rider, Powerstroke roller
  15. #40
    Oct 2007
    VA
    00 Mshoe
    Thanks snik.
    Man I can't get a break with this car. Replacing the filter to block gasket today and broke the ground stud off the alternator.
    Replaced the rear pads and removed the SAP today.
    Alternator to order is Bosch AL9414X (115A) for anyone interested. All local parts stores and websites call up the wrong alternators (An 80A and 140A that DO NOT FIT) these I am guessing are for M3 S52 equiped cars.
  16. #41
    Oct 2007
    VA
    00 Mshoe
    Have an appointment with a body shop next Tuesday. Hooptie might be getting some lovin'
  17. #42
    Aug 2013
    San Francisco CA
    00 Imola E/S TS M Coupe
    This is a nice thread. Car's looking good so far. Steel Gray s52 dammn what a rarity!!!
  18. #43
    Jan 2013
    Texas
    ///M Roadster
    How did the alarm wiring go? Is something I want to do in the near future. Is it as simple as buying an old harness and splicing/soldering the new system in?
    Cyrus Mistry
  19. #44
    Oct 2007
    VA
    00 Mshoe
    More or less, yes. I Haven't trouble shot it yet, but currently my lights arent flashing. Might be a polarity issue, or a wiring issue.
    The other hard part is finding a plug for the siren, if you want to keep it plug and play. Mine currently is still missing the siren.
    I put it in for the keyless option and the ability to know its locked when not staring at it (2-way system), along with remote window roll up. So its not a high priority since these things work and I have other things I need to sort out first.
  20. #45
    Oct 2007
    VA
    00 Mshoe
    After talking to the body shop yesterday and the little difference between fixing all the "trouble areas" and a full respray the plan is to just do the whole blooming car. So as life plans go it will be put on the back burner till a house with garage is purchased to protect said investment in paint.
    Still more to come.
  21. #46
    Aug 2008
    Sunny SoCal
    E368x2 / F15
    That is the perfect idea! ^ Just do everything else until you are ready for paint.
    Great work
  22. #47
    Oct 2007
    VA
    00 Mshoe
    ^Thanks
    In the plans is a full Exhuast, or possibly replacing the driver window (scratched up) and tint, or suspension components. Trying to weight the smiles to dollars ratios
    I havent decided what I want to do first. The sliders are getting replaced soon, so tint and window replacement would make sense to do at the same time, but its not a high priority so I may just replace the window. While the doors are torn apart I plan on taking car of the seperating wrap on the top front corners and replacing the driver insert that is badly worn.
    Luckily the wheel bearing I thought was going bad was just the uneven brake pads making noise. I was holding my breath, but after driving it with the new pads a bit the noise has disappeared and it looks like I finally got my first break with the car.
    Also currently looking at a set of 18" ACS II's, so no decisions will be made yet.
  23. #48
    Oct 2007
    VA
    00 Mshoe
    Sooooo over the weekend I scored these from Germany.
    18" AC Schnitzer Type II Rennsport
    Current specs:
    18x8.5 ET 38
    18x9 ET 45
    They will be torn down and rebuilt before being mounted probably getting their own thread as well.
  24. #49
    Oct 2007
    VA
    00 Mshoe
    Late update but had a chance to properly wash and wax the exterior Oct 4th. Still slowly getting parts replaced here and there. Have headers sitting under my bed for when I get the exhaust work done and just got some AKG poly subframe bushing to help keep my floor together.
    Oil was replaced when it rolled over 95000 and sent a sample to Blackstone for an anaylsis that gave the motor a clean bill of health.
    ACS's logistics got worked out and they should be shipping to me Monday.
    Threw in an old radio for Ipod usage till I can get it replaced properly.
    Post waxing shot I took while waiting for my Realtor to show me a house (which was horrid) back in early Oct:
  25. #50
    Oct 2007
    VA
    00 Mshoe
    Put a deposit on a set of GC coils.
    Also, my wheels shipped this morning from Germany.
    AND, Looking at a townhome with a garage on Monday.
    The new year will be good for the Mcoupe.
