Page 10 of 21 FirstFirst 1234567891011121314151617181920 ... LastLast
Results 226 to 250 of 516
Thread: We need more build threads: 00 Z3MC SG/DBO
  1. #226
    Oct 2007
    VA
    00 Mshoe
    Just posting here to keep it all together... sorry for the bump
    Wheels are done!
    The color in the sun
    255's look small next to the 295's
  2. #227
    Columbia, Worst Carolina
    2000 M-Coupe, 1994 SE-R
    Yummy.
  3. #228
    Sep 2013
    Fort Lauderdale, FL
    e30 m3, 99 M Roady
    different! I like!
  4. #229
    Jun 2004
    Youngsville, Louisiana
    2001 M Coupe
    Excellent! Fenders appear properly filled!
    Please add wheel specs.
    -Ed Hands
    MaxPSI Stg2 Turbo
    R.Forbes magic F&R
    100K Original owner miles.
    Proud member of the BF.c FI - Big Torque Club (>500wtq Dyno Results)
  5. #230
    Oct 2007
    VA
    00 Mshoe
    Got the final alignment done today.
    Front end:
    xxx Caster (removed pending confirmation)
    3.5* Camber
    1/32" Toe
    Rear:
    2.3* Camber (max we could take out)
    1/16" Toe
    Mileage for tire wear tracking: 97647 after alignment
    Wheel/tire specs added to OP.
  6. #231
    Is there really that little caster in the front, or did you dial almost all of it out with plates? Not knowing anything about the E36 chassis, I was expecting 7 degrees or more...
  7. #232
    Oct 2007
    VA
    00 Mshoe
    Actually now that I think about it that was the delta between the two I just remember that number since we talked about it. I don't recall seeing the actual angle but it was unchanged from my last alignment I'll dig up the sheet when I get home since I think he forgot to throw the new one in the car today.
  8. #233
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    Stock Z3 is around 3.5. M is over 7. Mixing the two, M caster on Z3 knuckles or visa versa, causes horrendous bump steer.
    /.randy
  9. #234
    Oct 2007
    VA
    00 Mshoe
    Woop woop!
    Its nice to have friends in Germany
  10. #235
    Dec 2007
    Great Dismal Swamp
    Is that the German version of the CD changer cover?
    /.randy
  11. #236
    Oct 2007
    VA
    00 Mshoe
    Something like that.
    Some shots from Schuh via Tony Parish:
  12. #237
    Northwest NV
    Audi B8.5 S4
    I'm indifferent about the euro glovebox. What's actually impressive to me about both those parts is that the 'inner' mounting tabs (that hold the speed nuts behind the center console wings) are actually intact.
  13. #238
    Oct 2007
    VA
    00 Mshoe
    I know! I saw the setup in Mark's car and decided to keep an eye out for them. For roughly 100 shipped to me I can't complain after looking one night and both in beige.
  14. #239
    Oct 2007
    VA
    00 Mshoe
    Mscire2's preview shots from Schuh. He's got more supposedly that will be in the Ulitmate Klasse blog post he'll be posting in the next few days covering the whole Schuh event.
  15. #240
    Well executed style right there. Good job.
  16. #241
    Oct 2007
    VA
    00 Mshoe
    So wheel weights are in! I took the time today while I was touching up the lips from Schuh's mayhem and fitting a little more clearances in the fenders to weigh them.
    (On my highly calibrated bathroom scale)
    Front: ~55lbs
    Rear: ~60.5lbs
    Taking into consideration the tire weights I had from before:
    295/30/18 Yokohama AD08R -31lbs
    255/35/18 Yokohama AD08R -28lbs
    Front wheels: 27lbs
    Rear wheels: 29.5lbs
    Have some photos to upload this weekend of the finalized S50 euro tank swap but they are still on the card in the camera.
  17. #242
    Jan 2014
    Lincoln, Nebraska
    1999 BMW M Coupe
    How you liking your yokos?
  18. #243
    Oct 2007
    VA
    00 Mshoe
    Worth every cent. I'm anxious to drive it again now since I just made some more clearance adjustments. Need to see if they are still rubbing as bad as they were before
  19. #244
    Quote Originally Posted by robb1887 View Post
    Front: ~55lbs
    Rear: ~60.5lbs
    Front wheels: 27lbs
    Those weights are going to be off by a good few pounds because they take into account the air fill (balancing weights and valve stems too). I would knock at least 2lbs. off those weights as an estimate.
  20. #245
    Oct 2007
    VA
    00 Mshoe
    I'm not really that worried about the weights more for informational purposes. I wouldn't be surprised if the scale was off 2-3% itself.
  21. #246
    Jun 2004
    2001 M Coupe
    Quote Originally Posted by BenFenner View Post
    -Ed Hands
    MaxPSI Stg2 Turbo
    R.Forbes magic F&R
  22. #247
    We could go through the theory of compressed air weight, but I'll just post real numbers once I get more pictures hosted. Maybe we're talking a few dozen grams and not a few pounds though. We'll see. =/
  23. #248
    Jun 2004
    2001 M Coupe
    My measurements on my 255/315s: total of balancing weights on all four tires=12oz. Throw in 4 rubber valve stems and we're still under a pound. I've weighed wheel&tire combos un-inflated and over inflated and could not measure any real world difference.
    -Ed Hands
    MaxPSI Stg2 Turbo
    R.Forbes magic F&R
  24. #249
    Oct 2007
    VA
    00 Mshoe
    Quote Originally Posted by E.Hands View Post
    This. On a bathroom scale my weights are "closenuff"
  25. #250
    Jul 2004
    SA TX
    E46 M3
    Did I just read someone saying 2lbs for valve stem. Air and balance weights?
    M driver, RSV4 Rider, Powerstroke roller
