Bought my dream car finally June 2013. It was a little rough, but I fell in love with it immediately.
Current Photo(s)
Backstory:
Specs:
2000 Z3 Mcoupe (E36/8)
Steel Gray exterior (400) Custom order
Dark Beige Oregon (R3SN)
1 of 1
944xx Miles at purchase
100% stock, save for a set of Billy sport front struts
Original owner was a Doctor from DC (per business cards found under seats) and it was apparent he didn't "care" for the car like he should have being that he ordered it SPECIFICALLY for him originally. Guy (technically 2nd owner) I ended up buying it off a dealer lot and put only 300 miles on it before, what I understand to be, not having the desire to put the work into bringing it back to its proper state.
Issues:
Transmission wasn't very smooth, clutch point was at the floor, throw out bearing was shot, minor rust, curbed rims, dent in hood, scrapes on pass rear fender, tear in driver bottom bolster, misc broken/missing interior bits, dinged/misaligned bumper, missing undertray, the list goes on, but I'll get to some pictures:
For sale listing photo:
Car has obviously been neglected for a while, and I thought I would document its rebirth. I'm horrible at taking pictures 90% of the time, but will try to get them through this process. I have wanted one of these awesome cars for years now and it just so happen I find a 1of1 so close to me I couldnt pass it up.
Ardy (guy I bought it from) replaced:
Valve Cover Gasket set
Power Steering hoses refreshed and flushed with new fluid
metal impeller water pump
Aluminum Thermostat housing and thermostat
Coolant flush
Things I have done so far:
Engine:
Eurosport 1.7L Twinscrew
Eurosport air intake carbon heat shield
Bosch (Porsche) "803" MAF (0 280 217 803)
Amsoil 3.5" Cone filter (pending ITG replacement install)
RaceTCS traction control
RE underdrive WP & PS pulleys
VDO oil press sender
VDO Water temp sender in head (A2C59517248-S)
S54 Oil Filter Housing
Randy Forbes S54-S52 Vanos feed adapter block
Bespoke DBG oil adapter block for remote oil pressure sender
Wired oil pump nut
Bimmerworld performance engine mounts
ECS 8oz catch can
Radium Engineering PCV Valve
Radium Engineering Valve cover PCV to 10AN adapter
-10AN nylon braided PCV hoses
Aluminum adapter plate for -10AN ORB fitting for PCV suction line
Eurosport base ECU "tune"
Lava shield wrapped ECU box
Throttle body coolant line delete
Relocated Diagnostic (D110) connector
Relocated 12V+ Tower
Relocated Ignition plug
Relocated Passenger side relays to inside ECU box
ACS-TB delete
Magnetic Oil drain plug
Fueling:
Walbro GSS342 in tank fuel pump
Radium engineering fuel pump intake filter/sock (14-0743)
Delphi 37lb/hr injectors (D3165BA)
Cooling
Zionsville Autosports Type 2 radiator
Zionsville bespoke radiator puller shroud
14" Spal puller fan wired to OE Relays
S50B32 Euro expansion tank retrofit
Eurosport oil cooler -10AN fitting adapter block
Zionsville Autosports bespoke oil cooler (19x2.5x2.5)
-10AN nylon braided oil cooler lines
Stewart Water Pump (mechanical fan threads removed)
Aftercooler circulation pump (Johnson pump 10-24504-03)
Air to water heat exchanger (24x5x2.5)
-12AN nylon braided aftercooler lines
Exhaust:
Long tube headers, Cerakote Piston Coat (V-136)
N54 exhaust manifold studs
GESI high-flow 3" cat
Custom 3" 304SS midpipe
Vibrant 3" resonator
Super Sprint cat-backs
Vibrant V-bands
SAP Delete
Drivetrain:
Mason clutch pedal
Oilite clutch pedal bushing
Rogue Engineering Trans mounts
Shifter bushings refreshed
Delrin shifter carrier bushing
Sach's Clutch/PP/throw out bearing kit
Brass clutch fork pivot pin
Shift pin service
Amsoil Trans Fluid change
Rogue SS clutch line replacement (DCV delete)
OE Slave cylinder
Suspension:
GC Coilovers (Eibach 440f/ Hypercoil 700r) break down progress 1 2 3 4 prealignment
GC Hybrid camber/caster plates
Meyle HD FLCAs
Powerflex offset FLCABs
Lemforder inner/outer tie rods w/ fresh boots & locking plates
OEM front strut reinforcement plates (modified for GC camber plates)
Bimmerworld weld-in eccentric rear toe/camber adjusters
AKG poly subframe bushings
Turner Motorsports "Street" rubber RTABs
Mason Engineering Racebrace
Brakes:
Zimmermann 2-pc OE "euro" floating front rotors
Zimmermann vented OE rear rotors
Axxis pads
Ireland Engineering SS brake lines
Motul 600 fluid
Overhauled rear calipers (OE softparts, painted)
Bimmerworld SS caliper pistons (rear)
Delrin brake pedal bushing
Interior:
50% ceramic tint on sunroof
Double Bee Garage seat tilt kit (driver & passenger)
Seat bushing replacement
12V Sky ///M plug
Viper 3202 2-way Alarm w/ OEM siren & OEM Alarm harness spliced for plug-n-play 2
(Remote functions: Keyless entry, window roll up/down, hatch pop)
ZHP shift knob
Passenger side "parcel net" replaced
LeatherZ armrest
Refreshed center console
LeatherZ sunroof sunshade (Suede applied)
LeatherZ footwell lighting
VDO Vision water temp gauge (VDO-310-1952)
VDO Vision oil temp gauge (VDO-310-1962)
VDO oil pressure gauge (VDO-350-1942)
Euro driver lower dash panel
Euro glovebox
Black Flocked Center dash
Extended leather door cards and dash pods
Suede headliner & A/B/C pillar
"BMW Individual" door sills
Shepott E46 sport steering with with radio steering wheel controls
Euro sun visors (NO airbag labels)
Redline Goods Alcantara Shift and e-brake boots with M-tristitch
Redline Goods Leather ebrake handle with M-tristitch
Homelink garage door opener retrofit to modified fog switch
Colourlock leather restoration for seats and center console
FIXED driver seat back rock, identified as seat pan busted spot welds
3D printed rearview mirror high mount (aluminum in process)
Rallyroad 52mm dual gauge pod mount
AEM 30-0300 Wideband
AEM 30-0306 Boost gauge
DBG "High tuck" rear view mirror mount V2
DBG dead pedal reinforcement block
Exterior:
Aluminum Motion Motorsports Undertray
OEM gloss black painted hatch spoiler
Blacked out kidney/hood grilles
Color matched Garagewelt wiper delete
Skeene design front license plate bracket (currently removed for ESTS HE flow)
OEM shorty antenna
OEM S54 belly pan cover
Neverdone Hex grill insert
Wheels & Tires:
APEX 90mm wheel studs
Motorsports Hardware lug nuts /w locks
Yokohama ADVAN Neova AD09's 255/35F 295/30R
AC Schnitzer 18" Type II 3-pc 9.5 ET34 (measured, incl. 5mm spacers) 11.5 ET9 (measured) (post1post2teaser)
Hand-made aluminum o-ring fit AC Schnitzer centercaps
Lighting:
Smoked bumper marker lights
Stealth bulbs all around
LED 3rd brake conversion v2.0
3rd brake light accelerometer flasher module
LED license plate bulbs
FX-R 3.0 2.5" projector retrofit v2.0 (v1.0)
Skyy FX-R 3.0 brackets
Stereo:
Pioneer DEH-80PRS HU
Alpine PDX M12 Monoblock amp
Alpine PDX F4 4channel amp
Focal ES 130K K2 Component front speakers
Focal Performance 100AC rear speakers
Dual JL Audio 6W3v3 subs in custom fiberglass sub box
Alpine bass knob
E46 Steering wheel control retrofit
Niche Motorsports USB plug with 12V switched power & HU port
16Ga speaker wire throughout
12Ga Sub wiring
JL Audio RCAs
Misc:
Windshield washer bottle relocation to M-mobility kit well in trunk
Minor Noico sound deadening mat/foam application
In Progress:
A/C refresh
Schuh prep maintenance
Misc parts acquired/waiting install:
Misc center console switches (spares)
ACS flippers (2000mkoop reps)
Bespoke ND splitter
OEM plastic hatch spoiler with holes (for a project )
Spacers: 3, 7, 12
DSSR 390
996 Calipers
Rallyroad 996 adapter brackets
Rallyroad 996 brake lines
Bimmerworld SS front brake caliper pistons
Randy Forbes ESTS intake gasket(s)
Randy Forbes rear end kit
3.46 differential with 3clutch
E36M3 rear diff cover
E36M3 diff ear bushings
Maintenance:
Misc OEM seals/replaceables when removing the trans (946xx)
Oil changed Mobil1 15W50 (95000)
Bank2 Sensor1 O2 replaced (946xx)
Rebuilt Alternator (948xx)
Driver door handle cover replaced (949xx)
Derusted and sprayed small spots on side skirts till replacement ones can be painted and replaced (946xx)
Bumper adjustments Front and rear
Removed 13 years of dirt from inner fender pockets (946xx)
Front tow plug replaced (946xx)
Passenger brake duct sourced and fitted (949xx)
Driver brake duct fitted (949xx)
New spring clips installed for front grill (947xx)
AC button rebuilt/replaced (946xx)
Auto-dim mirror fixed (before leaking) (947xx)
Second key (946xx)
Replaced broken dash defroster vents (950xx)
SCRUBBED carpets (946xx)
Oil filter housing to block gasket (948xx)
Black radio/shifter surround (95xxx)
Replaced broken dead pedal (95xxx)
FAG rear wheel bearings (95xxx)
Glove box sag fix (preventative) (95xxx)
Center console bulbs (guages & heater controls) (95xxx)
Brake light switch (97617)
ECU fan (97617)
Fresh coolant (97617)
Injector Orings & Pintel caps (97617)
Manifold to head gaskets (97617)
OEM fuel filter (97617)
Driver door window spot weld repair (97617)
Door window weather stripping (97617)
Brake wear sensors (97617)
Driver & Pass. window sliders (97617)
Driver window glass replaced used OEM (97617)
OEM BMW Coolant fill (4/23/14) (97617)
Oil changed Mobil1 0W40 (976xx) (4/29/15)
Oil pan gasket (100030)
Good condition x-brace (100030)
Oil changed Mobil1 0W40 (1033xx)(06/01/20)
Interstate Battery (103625) (4/22/22)
Oil changed Liquid Moly 5-40W (Leichtlauf) w/ Mahle filter (103625) (04/23/22)
ZF power steering reservoir (104880) (2/18/23)
Bimmerworld engine mounts (104880) (2/24/23)
Power steering fluid refresh (104880) (3/3/23)
NGK BKR7E sparkplugs (104880) (3/10/23)
BMW throttle cable PN 35411163164 (104880) (4/7/23)
Used Walbro GSS342 (104880) (4/10/23)
BMW cruise control cable PN 65718380083(104880) (4/12/23)
Conti 4060780 (6PK1980) serpentine belt (104880) (4/16/23)
Driver rear ABS sensor (Hella 6PU 010 039-501) (105000) (5/2/23)
A/C refresh, all new o-rings, evap valve, accumulator-dryer, re-charge (105xxx) (7/xx/23)
Literature acquired:
Bentley's Manual
2000 Owner's Manual
Things coming in the mail
Things planned for short term:
6-speed 420g trans (winter 2024)
3.46 diff (winter 2024)
RF kit (winter 2024)
Long to-do List: (in loose order)
BBK (Porsche 996)
Tint
Wire tuck
Paint
- 1of1 rebuild (build thread) -
- Wanted Car items - FS: PnP aftermarket alarm details -
- Coupe Custom Subwoofer box - FS: Z3 Coupe LED 3rd brake lights -My Website for DIY content and parts: Double Bee Garage
This is gonna be good. Sub'd
Looks like the start of something awesome!
Where at in Norfolk are you? I live in Newport News. I love to come check it out sometime.
i must take credit for talking Rob int this... sold his pretty slick tastefully modded E36 328i what, a year ago, and almost got lost in 4runner modding culture... i kept harping on him, when are you getting a bimmer, when are you buying that M3...All i heard was, i only want a shoe, nothing else will do, so until you buy it for me, fuk you too... rhymed just like that... then he'd spot them and some were meh, others were already done up and stupid expensive, then he up this one, i was like quit BSin and get it, you kno you wont regret it... i guess that was the nudge he needed... next thing i know, like 2 weeks later he buys it and few weeks later we're changed the clutch and all kinds of stuff..
so excited for him, and to see what he does with this beast. Theyre such sick cars, i could never own one, id get locked up instantly. street legal gokart is how i describe it... woot woot...
i are very excite.!
M driver, RSV4 Rider, Powerstroke roller
Looking forward to the resurrection. That car was rough- hope you got a killer deal.
Mods: Remus 76mm exhaust, CDV delete, ASA AR1 18in staggered wheels, Turner 12 mm spacers, custom red tails, Kenwood deck/Sirius/BT/USB, ZHP knob, Redline boot, LeatherZ armrest, Amsoil all around, red needles, Akebono Euro brake pads, 34k original miles!
No need for the 15w50....10w40 maybe but normal is 5w30
Love the color...
I bet a ride around some entrance and exit ramps will get that CAI et al off your list....
and put FI near the top.
/.randy
Thanks. I'll PM ya
let's hope
Me too.
Stay tunes. I think so.
I used to run 20w50 in my 328. I can't fathom putting in 5w30. Ugh.
Yea yea, just need to get that powerball ticket and it will.
Love it! Looks like the awesome beginning to a great project. Steel Gray<3
Subscribed. Nice to see one of these being brought back to life.
For a DD I prefer SG/beige over SG/imola, so I think you made a good choice. SG is the only color I like a beige interior in
PRICE CUT on ALL FABRICS
Sweeeeett color! Congrats on the ride, glad to see some love going into it.
Whatchutalkinbout!?!? I'm building stuff all the time
Why I actually *just* finished building something for myself
Next up on the roster is a 2000 ///M Coupe that's going to be fitted with my former Dinan/Vortech supercharger system (after getting a head gasket, rings and coated bearings)
Robb, is there even any brake fluid in that reservoir?
DIY/Project Links:_TC Kline D/A & Suspension Refresh_|_Oil/Engine Cooling Options / Install_|_
Dinan/Fikse FM-5 Build_|_Stereo Install_|_HID Retrofit_|_
Steel Gray is amazing. Thanks
I usually dislike beige as well, but I think it goes well with the SG. My DD is also a beige interior.... I dunno how this has happened to me. It's not my first pick for interior colors, but I dont think I'd want Imola either. I dont DD it so something more "exciting" wouldn't be a bad thing.
building sure. posting? I haven't seen anything lately.
Feel free to shoot that Dinan over to me to keep it warm for you while you do that other work. No rush on completing it, take your time, just ship the SC kit to me ASAP to make sure the bearings stay rotating
Second to last picture, line is visible, about 1/8 from the "max" line
^this guy
Thanks for all the compliments guys (and lurker girls??). The underpanel showed up last night. Still waiting on the filters, its the first time Amazon Prime failed to deliever within 2-days, weird. Also figure I need to go grab a filter to block gasket to swap in too while I'm at it.
It's a S54 SC kit..... I'll hold onto it for him instead. Although my bearings and a valve adjustment are on the list first as well.
Can't wait to see you bring this thing back to life even more, I am kinda in the same boat bringing my 01 back to her glory.
~Ken~ '99 M coupe THE "original" TT Stage 3 - HTA3586R; 701 whp 672 wtq @ 26.5 psi ; NeverSell - CoupeCartel
He's putting it into a 2000, so we can test fit and run it on mine first
That's boring then.... Randy the 01 needs some boost!!!
You could always do a test run on my car just to make sure it's ok...
UPDATE 8/9/2013
Miles: 95111
Oil change complete (mobil1 15w50)
Diff oil changed (Royal Purple 75w140)
Tranny topped off (Amsoil)
All photos taken with my trusty toaster.
Motion motorsports undertray fitted:
The mail came today:
Some light reading material
And the harness for my next project came
Thats all for today...
or well I'll give ya a teaser for what else is HOPEFULLY to come. I put in an bid on a place that has living space for the Shoe to get it off the streets (I'm excited and nervous).
word is RP diff fluid breaks down quickly... thats the word on M3 forums... i stick to redline.. yrmv
I figure knowing what's it is is better than guessing. I'll get redline next when I can order it on the interwebz. RP was local
Word. It'll be goo for a quick rinse.
Looking good! That MM undertray is sexy...
