BAVToys
Results 1 to 12 of 12
Thread: LED lighting for new headlights and current taillights
    Sep 2010
    Redford, MI
    93 325, 97 Z3,
    I recently purchased the following 1 piece headlights http://www.ebay.com/itm/390625628664...84.m1439.l2649 for my 1994 BMW 325is. They require H1 bulbs for the low beams, and H3 for the high beams. Im curious if these LED's are a good buy.
    http://www.ebay.com/itm/360709042279...84.m1423.l2649 for the H1
    http://www.ebay.com/itm/161073979276...84.m1423.l2649 for the H3's.
    Im thinking an amber LED for the side markers (front and rear), and I want to run a red LED for the taillights, but want to run the factory EURO fogs, and another LED for the reverse lights. Looking for options and opinions. Thanks
    Mar 2005
    Connecticut
    ( ͡° ͜ʖ*)
    Return the headlights you bought, they are complete junk. They are cheap, lead filled, chinese trash. The light output will be horrible no matter what you do, they will fall apart and leak and look horrible. Please, I'm not trying to be mean, just set you on the right path. Look into Depo, or DJ auto headlights, and if you want the best, retrofit some good projectors into them (look up marketmasters threads on the subject).
    As for your other question, no those LED lights will not work. Sure they will light up, but they aren't powerful or bright enough to be used as headlight bulbs. You wont be able to see more than 5 feet in front of the car, if even that.
    Sep 2010
    Redford, MI
    93 325, 97 Z3,
    Thanks for the input.
    Sep 2010
    Redford, MI
    93 325, 97 Z3,
    Okay, so obviously I'm messing up here. I don't want to go in the wrong direction with the fogs. What fogs should I order?
    Mar 2005
    Connecticut
    ( ͡° ͜ʖ*)
    Stick with OEM fogs, they look the best and perform the best on e36's. I tried many different ones when I had my car and the OEM was the best. As for bulbs, that's debatable depending on what look/function you want.
    Sep 2010
    Redford, MI
    93 325, 97 Z3,
    Quote Originally Posted by spoonerDee View Post
    I want the max visibility possible with a halo.
    Mar 2005
    Connecticut
    ( ͡° ͜ʖ*)
    For max visibility, buy the depo/dj auto headlights I mentioned, then retrofit in Fx-r projectors (look up marketmaster's awesome work) then get a decent set of Xenon's (HID'S) to put in them, you can find a lot of stuff at www.theretrofitsource.com. Keep the factory fog light housings and get a nice set of bulbs to put in them, Piaa, Phillips etc. and call it a day.
    Sep 2010
    Redford, MI
    93 325, 97 Z3,
    Sounds good. Thank you
    Mar 2005
    Connecticut
    ( ͡° ͜ʖ*)
    Best of luck to you.
    Sep 2010
    Redford, MI
    93 325, 97 Z3,
    Thank you sir. And to you as well
    Aug 2009
    East Bay, CA.
    1995 m3
    Those types of led's are good for side markers or blinkers, but not recommended for low or high beam because they do not have the same output as HID's or halogens and they are not as reliable because the individual led's you see tend to go out one by one without you noticing. You are better of with a standard halogen is my personal opinion.
    Sep 2010
    Redford, MI
    93 325, 97 Z3,
    I was planning halogen bulbs for her. Thank you
