Results 1 to 11 of 11
Thread: Turbo Oil / Water Feed Lines and Sizes
    Ship, Pa
    Red Sled, RC51
    Quick questions, getting ready to finish up my engine and I'm going to go ahead and do the water and oil lines for my GT4094r before it's in the car. Top mount manifold, etc.
    I'm going to do Summit AN fittings and stainless steel hoses, like so obviously:
    http://www.summitracing.com/parts/sum-230006/overview/
    What size do I need for the oil feed and return? -6 feed and return? And where do I find a restrictor to use with these lines? I'm really clueless here. Same thing goes for the water lines.
    Thanks guys!
    "Believe nothing you hear, half of what you read"
    New Westminster, B.C.
    1994 840ci,'97 M3
    When i had a gt4094r it had the restrictor built in check in the oil inlet you should see it in there
    Joliet, IL
    Out of Service
    -4 feed oil, 0.035 restrictor from ATP turbo, -10 oil drain, -6 for water lines.
    It's been a while since I've gotten a restrictor so hopefully someone else can confirm or suggest another size.
    Ship, Pa
    Red Sled, RC51
    Thanks man, perfect info.
    Summit the best place for this stuff?
    Ship, Pa
    Red Sled, RC51
    Any problem with running - 4 for oil feed AND water lines, or - 6 for oil feed AND water lines?
    Sounds dumb, but I'd like them to match.
    Joliet, IL
    Out of Service
    Quote Originally Posted by Fender13Bender View Post
    Does sound kinda dumb. LOL. If I had to choose I would go -6. You still have to run a -10. Your however going to have a hard time finding an adapter for your turbo oil inlet. Probably going to have to run a reducer at the turbo.
    I personally like Fragola parts.
    Ship, Pa
    Red Sled, RC51
    ATP stuff on the way
    T4 divided gasket
    -6 AN water fittings
    Oil feed flange with built in -4 AN fitting with gasket
    Oil drain flange with built in -10 AN fitting with gasket
    Looks like on my turbo there is a restrictor built in, so I should be good there.
    Ship, Pa
    Red Sled, RC51
    Alright, for those running water cooled turbos, where are you doing your water feed and drain?
    I'm thinking engine block drain plug for the turbo drain, and using the location where one of the throttle body coolant hoses goes? Its next to 2 sensors under the imtake manifold, it's a threaded piece so I'd add an AN fitting.
    I don't want to have no flow through the turbo or have it hooked up wrong. Will this work?
    Joliet, IL
    Out of Service
    It will work
    Jul 2010
    Underground, WA
    secret squirrel
    that is how i had mine set up.
    Garrett TiAL
    Ship, Pa
    Red Sled, RC51
    Cool, thanks guys.
