I'm looking into running an oil cooler setup like the one from rallyroad.
http://www.rallyroad.net/content/oil-cooler-cap
However my oil filter cap is not the one with a bolt and nut fastener. I have a plastic cap where the oil filter body is threaded and the perimeter of the cap is threaded, like in the image attached.
Is there a way I can swap to the other style cap so I can run this oil cooler cap?
You can probably get the s52 oil cooler housing pretty cheap on the forum. I just sold my old one for like $60
1999 M Coupe
My filter housing is available... please PM me.
DIY/Project Links:_TC Kline D/A & Suspension Refresh_|_Oil/Engine Cooling Options / Install_|_
Dinan/Fikse FM-5 Build_|_Stereo Install_|_HID Retrofit_|_
As the guys above stated you'll need to convert from the M52 oil filter housing to either the M50, S50, or S52 housing (all three of these are the same) to use the RallyRoad, UUC, etc oil distribution caps.
-James
From some searching I found that I may need a new power steering pump bracket. This was for the M50 housing though, so I'm not sure if it applies to the s52 housing.
Edit: if they're all the same then it seems so.
Since you have to change the filter housing anyway, why not skip the crap and go straight to the S-54 housing that has built in provision for an oil cooler, including a thermstatic bypass, for faster oil warm ups (from cold starts)?
With the cap-type, you're dealing with extra hoses and seals every time you do a simple oil change. Not something I'd want to deal with.
Or you can go really simple with the Champion plate, see this thread.http://forums.bimmerforums.com/forum...light=champion Dave Weaver at EconMotorosports in PA sell's them new. I did the s54 housing on my 99M3, I think the plate would have been simpler. 2cents
While this is geared toward S52s, it might give you some information to consider.
http://forums.bimmerforums.com/forum...Options-thread
That's pretty cool, but I have to wonder how that affects alternator mounting (and non-standard belt length) and clearance to power steering pump. I'd like to see what both sides of the block look like, and with it all on an assembled engine.
Dedicated Accusump port is a nice feature.
I don't like the fact that all the sensor ports on that Champion plate are located at the back. Not that there's any room to accommodate them on the front, but being back there doesn't exactly make them accessible!
