Well I'm starting to acquire parts and start modifications specific to my turbo build so I think its best to start getting the input of the FI forum. The current plan is a Borgwarner EFR 8374 1.05AR turbo using a divided manifold to take advantage of the twinscroll housing along with a custom water to air intercooled plenum. Not focusing on building a HP monster more interested in building a better M5 that has a broader power band, maintains responsiveness, and has OEM or better reliability. A few links to show prior work and parts choices:
- Prior work: http://forums.bimmerforums.com/forum....php?t=1869798
- Matchbot: BorgWarner MatchBot_3.7_8374_15_OP
At the moment I am working on a few cooling system modifications to take some weight off the nose of the car and better integrate the intercooler heat exchanger and cooling needs of the turbo and the wastegates (thinking dual TiAL MV-R). Looking forward to any questions and comments, here are some of the more FI related parts that have finally started trickling in.
-Greg
"You may all go to Hell, and I will go to Texas."
Davy Crockett
www.Angry-Ass.com
My Build Thread Part 1, Part 2
DIY E31 X-Brace Mod and Install
DIY Rear Seat Backrest Modification for E32 Armrest
Subscribed.
All those clamps cost more than my car
http://www.abelvalenzuelastore.com Home interiors; Upholstery, floor covering, window covering, & all kinds of repair.
Haha I doubt it!
So this weekend I'm going to be working on finishing up bending the new rear brake lines and getting measurements for the custom front soft lines. I also ordered in Pagid Sport pads for the N'ring rear brake setup (328mmx20mm rear rotors and new calipers vs 300x20 for U.S. Spec M5's), that was a pain to find in the U.S. haha! Should also make some progress on installing the remainder of the rear suspension bits and swapping my leather and foam from my electric seats to the manual frames I have. Lastly I need to double check that the 5/8 OD .555 ID 316 tubing I have for fuel line will be able to follow the OEM route and see how many Adel clamps and Click Bond studs I will need to replace the OEM mount points. Gonna be a busy weekend!
Davy Crockett
www.Angry-Ass.com
Which manifold will you be going with, and what tuning? I would go with a gt4094 turbo. That would make for a sick powerband.
― George Orwell
I'm building a custom manifold with integrated Laminova cores with a trunk mounted reservoir and pump. Here is a old CAD drawing of the manifold I need to update my Flickr pic of it haha, its changed quite a bit since I've started fine tuning it in CFD but its getting closer to being ready for a test print.
Here is a 3D printed prototype for the end cap with wiggins assembly.
The GT4094 is very nice and I looked at it for a while as its very similar to the EFR8374 that I've planned around, like you said should make for a nice power band especially taking advantage of the twinscroll housing. Planning on a Syvecs S8 or equivalent ECU but I'm not in a rush to decide until all the hardware is finished since ECU's are advancing so quickly. Tuning wise depends on who wants to do it and show me the ropes a little so I can toy with it down the road. Was planning on Neel at Apex but again I'm open.
Davy Crockett
www.Angry-Ass.com
...this is going to be good
Sub'd.
Autodesk Simulation CFD and will do! Thanks guys hopefully it keeps a few of you entertained!
Made some good progress this weekend albeit not quite FI related but hey gotta build the foundation. Anyways managed to finish up the heat shield install for the xbrace and finish the DIY. Here is the tool and insert you need.
Here is the shield bolted in place
I had forgotten to replace the seal ring on the CV joint on the driveshaft so I dropped it and checked the center bearing and guibo while I was at it. Both looked good which they should since both are less than a year old. Seal ring, driveshaft to final drive hardware, and center bearing hardware.
Installed seal ring, grease looks OK.
Also cleaned up a few heat shields and cleaned under them as well as replacing hardware.
Heat shields cleaned and hardware replaced and driveshaft installed and torqued.
With the driveshaft down I replaced the transmission mounts. Hardware.
Ready to go in.
Done.
Noticed I had forgotten some clips on the rear trailing arm so I installed those.
Much better.
Sorted thru my hardware and found all the pieces for the rear pitman arms and got those installed.
Driver side.
Passenger side.
I also replaced the fender liner nutserts.
Much better.
Getting close to being back on the ground so I figured it was time to get the exhaust hardware on.
I checked on the fuel line routing and its going to be tough to use the stock location where it passes over the subframe so I'll have to toy with that a little. On a positive note it looks like the passenger side has the same mount points for lines as the drivers side so I can use those for running the power steering lines coming from the trunk and possibly the washer fluid lines.
Davy Crockett
www.Angry-Ass.com
Dude you are my idol. This thing is going to be better than showroom floor when done. And I'm talking about little stuff, all the little clips,hangers, and joints. Brand new everything, with turbo.
There's nothing finer than a pint of Shiner.....except this build
I can't wait to see how an EFR does on a BMW motor, good luck!
Haha if it ever gets done and thanks for the complement!
I do love Shiner. The 8374 should be a good match with a proper divided manifold, especially since I'm more interested in response and day to day manners than outright power. Thanks!
Well Me78569 and I made it back alive from another road trip to the southwest and I had these waiting on me when I came into work this morning.
F50_4044 by 93FIM5, on Flickr
Brackets are in progress and will allow use with the N'ring 343mm front rotors or if I decide I need a little bigger/easier to source rotor in the future a 355mm (14"). A perk of the F50 caliper is that it has the same piston sizes as the OEM 4 piston caliper so bias is unaffected (I also have the matching 328mm rears and correct calipers) but the system is significantly lighter at 7lbs per caliper vs the OEM 4 piston at 14.7lbs and the sliding front on the US at 11.2lbs. Gonna be a fun week .
Davy Crockett
www.Angry-Ass.com
Is this the 3.5l engine or the 3.6l?
Its the S38B36 since its a 93 US M5, but its still technically a 3.5 being that it displaces 3.535. It will be stroked out to ~3.7liters via the 3.8 crankshaft during the turbo rebuild.
Davy Crockett
www.Angry-Ass.com
Ah, just putting in the b38 crank in there will give you a displacement of ~3.7l, interesting.
The best thing is installing new parts!
1997 Arctic Silver/Black M3
1999 Techno Violet/Dove M3
.. like a brand new car off the lot.
Do you have the laminova cores already? Have a ton at the shop. Shoot me a PM if you're interested.
-Critter
Finally Greg makes a post in FI
Looking good man. Replace the trans mounts with something stronger though - you won't believe how much they torque around.
yep
Yes, 3.6 has single bolt 3.8 has multi. 3.8L is a much more robust system. It's also why the 3.6 hubs fail. Harmonics.
