Results 1 to 15 of 15
Thread: Fixing the trunk lid wiring harness
    Sep 2011
    Finland
    1999 BMW 540iA
    When I first got broken wires in the wiring loom I just soldered the wires back together but that fix didn't last. Under a year and I got more broken wires. So I decided to pull the wiring harness and replace the section that get bent each time you open or close trunk. Since Imageshack is having some issues I made it into a PDF. Due to forum restrictions I had to compress it quite a bit so quality isin't the best possible. Anybody got any comments?
    Update: I uploaded a new version of it on filefactory. The PDF is now over 4 MB, so the quality should be better. Link
    Update: New link
    Last edited by Spirit Force; 03-23-2015 at 04:22 PM. Reason: New link to the guide
    Aug 2012
    San Diego
    97 E39 540/6
    Excellent write up. I've noticed this too after I soldered the trunk release/open and less than a month later it broke again. So the wires are just too short?
    "Life is a numbers game. Increase the numbers, win the game"
    Sep 2011
    Finland
    1999 BMW 540iA
    The wires aren't too short, they just get bent too much. I think the original wiring is PVC insulated, which doesn't take too well being bent that much regularly. Just take a look at the rubber loom when you close the trunk. Wires get twisted into U shape.
    San Jose, CA
    1997 BMW 540i 6 speed
    May have to splice in some very finely-stranded wires.
    West Michigan
    98 540iA (Prd 11/97)
    Thank for the contribution. I'll tow this to the DIY section after comments.
    Fyi, first link in PDF is broken (at least for me).
    SoCal
    7/98 NonVanos 540iA
    Excellent write up. What were the symptoms that made you check the harness? It seems that this only affects blue cars lol.
    Sep 2011
    Finland
    1999 BMW 540iA
    Quote Originally Posted by jamesdc4 View Post
    Thanks for the heads up. I first began writing it on the forum and only discoved the imageshack wasn't working when I was almost ready. I couldn't upload pictures to imageshack, so I just copy pasted it to MS Word. It seem that I forgot to fix the first link after that. Oh well I'll be doing some minor fixing on it anyways. I'll upload a better quality PDF to imageshack and put a link for it in the first post. How long can I edit the first post? Can I edit it after it's been towed to DIY section?
    Quote Originally Posted by GreenTiger View Post
    Thanks. The issues were: trunk wouldn't open via remote, inside switch, or the trunk switch. Only turning the key 90 degrees would open it. What a pain in the ass to use the key each time! Mine isin't blue it's Cosmosschwarz
    Uploaded new version on filefactory. It's a better quality (over 4 MB). Added some more info and few new pictures.
    Jul 2011
    Bydgoszcz/Poland
    e39 530i '01 Touring
    Hello.
    The link is not working anymore. Does anyone have a copy of this DIY?
    BMW Addicted
    Mar 2013
    Bellingham, WA
    1989 325i, 2001 530i 5MT
    I'd love to see this too. Both trunk lights out. Verified broken wiring harness at the pass side trunk lid hinge. For the moment the remote release still works, both at the button at the driver's door jam and via the remote key fob.
    I'll keep an eye out for a fixed link .
    Well this is interesting. Hopefully we're talking about Part #4 in the diagram, not Part #3...
    For that push off the cliff, this one GOES211...
    Aug 2014
    Ooltewah, TN
    2003 BMW 530i Sedan
    New to the forum, just bought a 2003 530i and seem to have all the typical issues for this model/year. Found the trunk wiring harness issue while replacing tag lights. Has anyone found a good fix for this? Right now all I know to do is cut wires one at a time, butt solder together, and cover with heat shrink. Not much extra length in wire to play with.
    Aug 2014
    Ooltewah, TN
    2003 BMW 530i Sedan
    I was able to fix the trunk wiring harness this weekend. I had to cut each wire and solder back with a inline joint. I have too say probably the worst soldering job I have done in my life. It is very hard to keep the wires together in a vertical position in the corner of the trunk with soldering iron in one hand and solder in other. Not to mention it felt like 120 degrees outside with humidity 1000%.....LOL The design for that harness is the worst I have seen. I recommend carefully slicing the rubber harness length wise the entire length, pulling all the wires out and doing the repair. Make sure to use heat shrink on each wire. When done you will be able to slip the wires back into the harness and use 3M Scotch 33 black tape to wrap around entire length of harness.
    ATL
    E39 540i/6
    Did anyone save this PDF and can upload it again?
    Sep 2011
    Finland
    1999 BMW 540iA
    I uploaded it again, but it will dissappear after 100 days, if noone downloads it. Anyone got any suggestions on a good upload site that has no expiration?
    Jun 2016
    tulsa, ok,usa
    2003 525i
    Quote Originally Posted by Spirit Force View Post
    Upload to Photobucket, then just put the link here, but make sure your privacy settings are not requiring a password, lol
    Aug 2016
    Virginia,USA
    528i, 525iT, M5, x5 4.8
    Need a link
    Current Garage
    2005 X5 4.8is Le Mans Met Blue
    2003 525iT TiSi
    2002 M5 TiSi
    1998 528i Champagne
    Former Garage Highlights
    2004 325iTs (2x)
    1973 Pantera
    1971 Dodge Dart Sport "Lite Package"
    1970 Dodge Challenger T/A 340 Six Pack Go Man Go Green
    1969 Road Runner 383
