Page 3 of 7 FirstFirst 1234567 LastLast
Results 51 to 75 of 158
Thread: Project Hellrotbox E36 328is LS1 swap
  1. #51
    Oct 2012
    Toronto & Amherst, NY
    96 LS1 328is, 06 330i
    Quote Originally Posted by AutoRotate View Post
    Can you post a picture of your clutch line set up? I know I can mate the GM slave to the BMW master but I don't know where the lines should be spliced.
    Paul (BRAAP) did my clutch line.
    You can find more info on how he does it here:
    http://forums.bimmerforums.com/forum...1#post20446921
    http://forums.bimmerforums.com/forum...3#post19369453
    http://forums.bimmerforums.com/forum...3#post20125073
    Hope that helps.
  2. #52
    Mar 2005
    Charleston, SC
    99 528iT
    Perfect, thanks to both of you!
    :: 1999 BMW 528iT ::
    LS3 / T56 swapped
  3. #53
    Apr 2009
    Sandy OR
    '97 M3 sdn, '00 528 sprt
    Autorotate,
    Most any machine shop can handle the mod for you or if you have access to a lathe all the dims you need are in the posts Jai5 posted.
    Or I can do it for you, send me your GM clutch line, (new or used), along with $35 for machine work and drill mod, that includes return shipping within the lower 48 states. Turn around time is typically 12-48 hours, shipping is typically 2-3 business days, PM me if interested.
    Ps, be sure your Master Cylinder outlet ID matches that in my CAD drawings first, BMW used a couple different sizes as Pzary and myself found out. If the ID is larger you'll be stuck with the multi-piece-fitting combo others have done,
    Take care,
    Paul
    '97 Sedan, Cosmos Meconium, Click ME for the build thread.
  4. #54
    Toronto
    1998 E36 M3
    @Jai5
    How are you going to tackle making the car OBD2 and emissions compliant. Are you planning to drive the car in the streets or will this be a track star only? This is likely the only thing holding me back on converting to an LS1/2 as I want to be able to qualify for my plate sticker and drive it in the streets.
    1998 E36 M3
    Dakar Yellow
  5. #55
    Oct 2012
    It's a 96 therefore it's not a "plug-in" e-test just a smog test that tests the following (found image on google)
    http://www.va3erc.ca/Erics_wheels/ci...e-test_sml.jpg
    It will be a street, plated car. I plan to pass emissions by having 2 bullet style magnaflow cats.
    in 2.5" ^
  6. #56
    Toronto
    1998 E36 M3
    Ahh yes, wish my m3 was not obd2.
    1998 E36 M3
    Dakar Yellow
  7. #57
    Oct 2012
    My 328is is OBD2. But they do the newer e-test based on year not obd1/2, 97+ is a plug-in test. Also if you have obd2 u can potentially just program all the codes out and literally pass with no cats. Only problem may be the VIN number that shows up when they plug it in... (not sure if that's an issue).
    No juicy updates. I cleaned up the engine bay a bit.
  8. #58
    Oct 2008
    West coast
    '00 540 6.0/4L80e/S480
    Quote Originally Posted by jai5 View Post
    Ls1 edit will allow you to change the vin in the GM ecu to your BMW vin. In all reality, it's probably easier to "cheat" an obdII system.
  9. #59
    Toronto
    1998 E36 M3
    Quote Originally Posted by unnatrl View Post
    Ok now we are cooking with gas, going to research LS1 edit. Thanks for this info, really appreciate.
    @jai5 really nice looking engine bay, looks like you can eat off of it. Awesome stuff.
    1998 E36 M3
    Dakar Yellow
  10. #60
    Jul 2013
    FL Gulf Coast
    E36 - 1998 328iS - LS2
    How's it coming?
    Tipsy
  11. #61
    Oct 2012
    Start with pictures:
    So motor is mostly built. Need a new oil pan gasket and need to put the clutch in as well.
    Ordered a LS6 intake as well which is on it's way.
    I need to figure out how to remove the front diff bushing from the car. I'm working on the wiring, but also procrastinating quite a bit because of the cool weather.
    On my plate:
    Wiring
    Manual swap
    Replace front diff bushing
    Install diff
    Small diameter brake booster install
    Brake lines
    + lots more.
  12. #62
    Jul 2013
    FL Gulf Coast
    Good deal! Keep at it!
    Tipsy
  13. #63
    Oct 2012
    Been chipping away at the to-do list over weekends. Mostly small stuff, nothing to exciting to report.
    I'm running in to some trouble with the manual pedal swap because of the master/pedal changeover in 1997 (I have a 96). I posted this in the manual swap thread but didn't get any replies. Hopefully you guys can help me out:
    Hey guys, I need some help.
    I'm in the middle of doing a manual swap. My car is a 1996, but the clutch pedal assembly I have is from a 1998.
    The problem is that I wish to use the earlier style clutch master because I already have a custom line made that will only work with earlier style clutch masters (car is going to be LS swapped).
    Okay so I know I need some new parts to make it all work. I already know I need a new connector for the line that goes to the brake reservoir and shorter bolts to hold the master in place.
    Question: Do I NEED #10,12,13? Or can I just use what I have (#14,15)
  14. #64
    Oct 2008
    Columbia, MD
    96 M3 TT LSx
    No, you don't need the clutch helper spring/parts. A lot of LS swappers have removed it and have gotten increased pedal feel.
    96 M3 | Forged LSx | Twin S366 | Injector Dynamics | E85 | AEM Infinity
    90 Schwarz 325i
    IG : sdobart
  15. #65
    M5Hunter is offline Still has a E39 Supporting Vendor
    Nov 2009
    Hanover, VA
    E39
    ^correct, that gets removed from every car I have built
  16. #66
    Buffalo, NY
    2001 BMW 540i/6
    nice swap, don't know how I missed this. I am just across the pond from you outside of Buffalo.
    2001 BMW 560i 6.0 LSx/T56 SOLD
    2000 Corvette Hardtop FRC
  17. #67
    Oct 2012
    Thanks for the quick answer!
    Update:
    Motor is back together with the transmisison. Brake lines are almost done. Pedals are in. Diff is in.
    Problems:
    1) Was trying to bolt in the axle to the diff only realize the ends don't line up. The diff's output flange is wider.
    2) The pinion flange is 6 bolt, not 4 like my old one. How are people working with this? Is there a way to make it work or do I have to swap it to a 4 bolt? I will have to make a custom driveshaft anyway (going with JTR kit that does not come with a driveshaft). I still have my old diff that has a 4 bolt flange, is it a direct swap? Easy to do...with the diff in the car?
    It's a 3.91 lsd diff, I think they came on earlier automatic 325?m3s?
  18. #68
    Oct 2008
    West coast
    Swap the 4 bolt flange over from your old diff and purchase the JTR flange. It will be a very simple driveline for any shop to build.
    Regarding the other problem, you may have to swap the stub shafts as well. I'm not 100% positive, but I believe M3 shafts require M3 stubs and vise-versa.
  19. #69
    Mar 2004
    USA
    96 328is 6.0L
    Swaping the input flange will require veifying that the diff settings didn't get messed up. That you still have the right contact patch, etc. Swapping the output flanges is easy though. They just pop out with a crawlbar, pop into the new diff and are easy swap.
  20. #70
    Oct 2012
    Okay that doesn't sound too bad, was pretty upset to find that the output flange was different and then just frustrated after noticing the input flange is 6 bolt. I hope I can do it without dropping the diff because it's not fun installing a diff without a hoist.
    Trying really hard to get a first start by end of July. I'll post up some pictures for you guys this week as well. This thread needs them.
    Thanks again!
    Edit: Why isn't there a company that makes 6-bolt flange to 1310 u joint adapter? :|
  21. #71
    Jun 2014
    Alberta, Canada
    1997 BMW M3 coupé
    Quote Originally Posted by sdobart View Post
    I deleted ABS on mine and converted everything to 3/8" -24 Inverted flare. Used a Wilwood prop valve. Car doesn't drive yet but the brakes are bled and I forsee no issues. It's just as much if not more work to delete ABS though, honestly probably more simple to relocate the pump and extend the lines. Fuel parts look correct. Can't help you with power steering, I converted my z3 rack to a true manual rack, no pumps or leaking fluid for me. That fuel line looks overkill to me (2500psi), I just got 6 feet of this, works fine. http://www.summitracing.com/parts/sum-240606b. No need for PTFE lines unless youre gonna run e85 or something IMO.
    So would you reconmend just doing the relocation? i was going to delete it on mine, but if the relocation is easier, then why not.
  22. #72
    Oct 2012
    Okay swapped the flanges. I didn't do the "right" way, read multiple posts (and the Bentley) on people just marking the nut with the shaft and tightening back to same spot. Had to drop the diff to do it though - which was actually much easier to do the 2nd time around. Took a total of 1-1.5 hours.
    Some updates:
    Brakes lines:
    A good friend of mine works at GM and he did the lines for me. Inspired by AllMotor
    Test fit the FPR:
    JTR Mount kit:
    I opted to just buy a pre-modified subframe from JTR instead of modifying my own.
    Mount pic 2:
    Going to spray them down with some black paint.
    My plan is to run poly engine mounts and a rubber transmission mount. Pic of the poly mount I plan to use:
    JTR Driveshaft flange:
    Throttle cable:
    MGW Shifter:
    What the motor currently looks like:
    Does anyone have any axle bolt retainers lying around? I need one.
    #2 in this picture:
  23. #73
    Oct 2012
    Dropped the subframe the other day:
    And as expected, I ran in to some problems:
    The shock bolts were seized on there as well, had to torch the shit out of them to get them out.
    That's really it for this week, I'm going on a road trip tomorrow for a week and a bit.
  24. #74
    Oct 2012
    Soon...
  25. #75
    Jul 2013
    FL Gulf Coast
    Looking good!
    Tipsy
  1. 99 328i ls1 swap question
    By needtospeed in forum Engine Conversions
    Last Post: 10-30-2012, 04:46 PM
  2. e30/ e36 328i motor swap?
    By BimmahJosh in forum 1991 - 1999 (E36)
    Last Post: 08-10-2011, 05:44 PM
  3. e36 Vorshlag LS1 swap kit $2500 obo.
    By adriver in forum Race Cars & Track Parts
    Last Post: 04-28-2010, 11:03 AM
  4. FST e36 Vorshlag LS1 swap kit $2500 obo.
    By adriver in forum Engine Conversions
    Last Post: 04-22-2010, 06:59 PM
  5. 318ti or normal e36 for LS1 swap?
    By bmwguru in forum Engine Conversions
    Last Post: 08-08-2008, 09:15 AM
