Page 2 of 2 FirstFirst 12
Results 26 to 42 of 42
Thread: Vorshlag Annoucement Thread for all LS1 Swap Development
  1. #26
    Jul 2013
    FL Gulf Coast
    E36 - 1998 328iS - LS2
    Quote Originally Posted by TipsyMcStagger View Post
    What's the latest on the remote reservoir?
    Tipsy
    Does anyone from Vorshlag pay attention to this thread?
    Tipsy
  2. #27
    modernbeat's Avatar
    modernbeat is offline Senior Member Supporting Vendor
    Dallas, TX
    Caged
    Yes, there is no new news on the reservoir.
    Jason McDaniel at Vorshlag
  3. #28
    Sep 2010
    North Carolina
    1998 M3 - Lsx
    Hey Jason what about any updates on the a/c and cooling hose kit? I know when we talked a few months back you made it sound like they were just about to hit the production phase.
  4. #29
    Apr 2014
    Australia
    1992 E36 320i RHD
    BUMP
    RHD news folks?
  5. #30
    Fair's Avatar
    Fair is offline Senior Member Supporting Vendor
    Oct 2003
    Dallas, Texas
    E36 M3, E36 LS1, E30 318
    Quote Originally Posted by hoozdman View Post
    BUMP
    RHD news folks?
    We keep striking out trying to find a RHD car. We had a "front cut" ordered from a local importer but it never materialized. Every RHD car we look at is a rust bucket.
    Terry Fair @ Vorshlag Motorsports
  6. #31
    Apr 2014
    Australia
    1992 E36 320i RHD
    bummed
  7. #32
    Apr 2014
    Australia
    1992 E36 320i RHD
    Tim k I can't respond to you
  8. #33
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    I just ordered the whole LS e46 swap kit from you guys last week, and the first round of parts should arrive tomorrow. Amazing customer service too, by the way. Can't wait to get it all installed! Now if only there was a wiring harness solution, that's the part I am really dreading.
  9. #34
    Jan 2016
    el paso TX
    1996 BMW M3 LS1 swap
    Any updates on the AC kit for the e36?
  10. #35
    Dec 2014
    Los Angeles, CA
    n/a
    Are you going to offer an E39 kit?
  11. #36
    Oct 2008
    West coast
    '00 540 6.0/4L80e/S480
    Quote Originally Posted by JWhitehead View Post
    contact Jesus Freak. He already has a kit, it's well made and the price is far cheaper than Vorschlag could ever hope to be.
  12. #37
    Jul 2013
    FL Gulf Coast
    Quote Originally Posted by modernbeat View Post
    ...there is no new news on the reservoir.
    Quote Originally Posted by Fair View Post
    Updates for April 9, 2014:
    Remote coolant reservoir, heater control valve mount and heater hose kit for E36 LS1. Removes the plastic OEM coolant reservoir tank normally mounted to the radiator and moves a more robust fabricated aluminum tank to the right rear corner of the engine bay.
    I assume this product is DOA?
    Tipsy
  13. #38
    Apr 2015
    1995 e36 sedan
    Interested in one as well. Would go well with everything else I've converted to AN fittings and lines.
    Ls2 e36 sedan
  14. #39
    modernbeat's Avatar
    Dallas, TX
    Caged
    Tipsy
    Not DOA, but in line behind a number of other parts (mainly suspension stuff) that are going into production.
  15. #40
    Aug 2016
    Asheville, NC
    2011 BMW 328i
    Any idea when you might have E90 LS1 swap parts available?
  16. #41
    Sep 2016
    Roseville, CA
    1999 323is
    Hello. My son and I are working on an E36 323is conversion to LS1 with auto. Our biggest question is the rear diff....is there an M3 or other LSD unit that will bolt in and handle up to 400 hp? We're doing this on a fairly limited budget and would appreciate any advise available. Thanks!!
  17. #42
    Fair's Avatar
    Oct 2003
    Dallas, Texas
    Quote Originally Posted by KNOXJASZ7 View Post
    While we normally don't tackle LS V8 swaps when the factory makes a V8 version of the same chassis (E92 M3), we are starting.... just starting to get a few questions about the E90 and E82 chassis. We are looking at them for LS swap viability now.
    Quote Originally Posted by BACINSAC View Post
    Honestly the E36 M3 188mm rear differential unit is a great unit to work with. You can pick up an M3 rear subframe/diff/suspension for about $500-1200 "brake to brake" from a salvage yard. That bolts into any E36 non-M and gives you the limited slip diff, upgraded halfshafts, upgraded control arms, and M3 spindles/brakes. Or just buy an M3 diff and swap in the whole unit, or have your 188mm open diff converted to limited slip.
    We put 500 whp though one of these 188 M3 units for years, using 315mm Hoosiers and even standing starts. For serious road course use I'd add a diff cooler, but otherwise your 400 hp goal seems well within the limits of this completely bolt-in unit.
    Here are more weights from the the 1999-03 Mustang Cobra 8.8" aluminum rear housing (62.9 lbs, at left) and the "medium case" BMW E36 housing (76.9 lbs, at right). The weight for the "large case" E46 M3 unit is above, at 100.4 pounds. All of these weights are complete housings with the factory rear covers, factory gears, and factory differential units. The BMW housings are heavier because they are cast steel - which is stronger than aluminum - but what usually breaks is the actual ring gear.
    Ask around but there are some folks on here who have built a kit to swap in the larger 210mm BMW "large case" differential unto an E36. Its a little "home brew" but hey, if it works, who cars?
    good luck,
  1. Need a engine harness for your ls1 swap?
    By redlinerjetta in forum Engine Conversions
    Last Post: 01-17-2009, 07:35 PM
  2. One Stop Thread For All Your FI Parts!
    By M3Romeo in forum Forced Induction
    Last Post: 07-29-2008, 10:12 PM
