Does anybody have some images of the plenum or a diagram of the DME design?
I have an idea that I would like to try for a nitrous setup, but I need to know how the plenum is designed.
Thanks,
-Will
2006 MS6
let me google that for you?
You're ready to tear that thing down for a rebuild aren't you?
________________________________
Nik
91' M5 3.9L Stroker
92' M5 3.8L
95' 540i6 Supercharged
95' 540i6 4.7 Stroker
95' 550i6 M70 Conversion
Knight what do you want to know? Don't be afraid of nitrous. People think nitrous blows engines up. Stupidity blows engines up. Nitrous makes them faster.
Stupidity is running nitrous on a 22 year old never opened s38 with high miles without being absolutely sure the motor is solid and the HG has all of its integrity. Nothing against you Will. Just be sure it's all good first.
Thanks for the kick in the nuts Jon. Always appreciated.
Nik
91' M5 3.9L Stroker
92' M5 3.8L
I've sprayed a few vehicles with great results. I'm sure it will happen eventually, but so far I have never killed an engine with nitrous. Getting lazy or greedy is when nitrous usually breaks things. I'm not afraid of nitrous at all. I'm currently discussing an interesting nitrous setup for an S38 that I know for a fact has worked very well on LSx vehicles for awhile. It's not the cheapest route, but it is much more safe and "neat" if nothing else.To address the other question that was asked, I'll rebuild it if I have to. It wouldn't be my first engine build, and I doubt it's my last. If nitrous killed it, I can say that it would be the first engine I ever had to rebuild due to nitrous. It has been well maintained, the compression test looked good, and I'm comfortable starting out with a small shot. You are correct, it is a high miles engine. If it blows, I just get to build a better one -Will
Niko, your PM box is full
-Will
2006 MS6
My Current Cars:
E70 2010 X5 4.8i Xdrive Spacegrau
E90 2008 M3 6MT Silverstone II
E34 1992 M5 3.6 J-spec Calypso
E34 1990 535/5 turbo Bronzit
E32 1990 750iL Highline Delphin
E30 1988 325i M54 swapped Schwartz Convertible
No longer with me:
E46 2001 330Ci Titanium Silver
E32 1993 740iL Lazurblau
E34 1992 525iT Kashmirbeige
E34 1990 535/5 Cirrusblau - Former Miller Performance Stage 2 Test Mule Car
E34 1989 525i Cirrusblau - the Slug
E21 1981 320i w/ M20 swap Arktisblau
E21 1979 320i Turmalingrun
it's not a coincidence that 5 s38 head gaskets have failed, they're old engines and who knows what kind of life all of them lived. at the same time, they are long heads and susceptible to gasket failure and warpage. installing nitrous won't necesarily kill ANY engine if a decent setup is installed. the good old days of "spray and pray" are gone (assuming the proper money is spent) and there should be no fear of nitrous as a power adder.
Bump for anybody with a good plenum/intake pic
-Will
2006 MS6
What type of pic are you looking for I have a spare plenum apart and some CAD let me know.
-Greg
"You may all go to Hell, and I will go to Texas."
Davy Crockett
www.Angry-Ass.com
My Build Thread Part 1, Part 2
DIY E31 X-Brace Mod and Install
DIY Rear Seat Backrest Modification for E32 Armrest
Here is a stock photo from the net, funny it shows a groove that would hold a gasket but none of the plenums I've had apart have this or a gasket. So its most likely a pre-production design/part.
Here is my spare plenum apart.
The first pic shows the variable resonance plate and wall. You can also see the effort in the construction BMW put into feed/resonance tube which actually has a velocity stack on the tube ends. Let me know what else you need, like I mentioned I have some CAD files and lots of measurements but they have more to do with the composite plenum I'm building for a few guys.
-Greg
Davy Crockett
www.Angry-Ass.com
Many thanks
2006 MS6
No problem, let me know if you need help with anything else.
Davy Crockett
www.Angry-Ass.com
What's the cannister hanging off the bottom? Just an oil trap?
Davy Crockett
www.Angry-Ass.com
I just learned something. Thanks
-Will
2006 MS6
