Page 5 of 5 FirstFirst 12345
Results 101 to 119 of 119
Thread: @blake261 E36 drift build '95/obd1 s52/flares/other somewhat cool stuff...
  1. #101
    Apr 2013
    Kelowna, Bc, canada
    1995 BMW M3 coupe
    https://youtu.be/A2ZEpddZhWo
    I found this pretty informative
  2. #102
    Nov 2012
    Atlanta, GA
    1995 BMW M3 Coupe
    That actually where I got the Idea for the loop above the throttle body. I was originally going to put a bleeder in the Waterpump. Thanks for sharing!
  3. #103
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    My lines are pretty similar. I ran the steam vent in to one of the lines. When I need to bleed it I just take the steam vent line off and hold it in the air, flip on the electric WP and wait for water to shoot out it.
  4. #104
    Puyallup, WA,
    95 M3, 17 Superduty
    That at guy was on Daily Transmission a while back. Pretty fast car.
    Quote Originally Posted by Mikestokman View Post
  5. #105
    Nov 2012
    Atlanta, GA
    1995 BMW M3 Coupe
    I was able to get the whole system bled in my driveway (downhill) with the radiator as the highest point and without an engine side bleeder. I still put a bleeder in the front last night to quickly bleed steam out if needed. Took a long time, and the air bubbles had quite a bit of velocity by the time they came out the top of the rad (like a geyser!) but it eventually calmed down and stayed at a cool temperature.
  6. #106
    Nov 2012
    Atlanta, GA
    1995 BMW M3 Coupe
    Just a couple new pics on another test drive. Painted the inside of the doors, cerakoted the headers, turbo, DP, etc.
  7. #107
    Apr 2016
    Detroit, MI
    1997 328i, 89 325ix
    Holy schnikes! This thing is gonna really make the jam.
  8. #108
    Nov 2012
    Atlanta, GA
    1995 BMW M3 Coupe
    A couple new pictures. Almost done with the vinyl wrap, fixed alot of small issues, Brakes work fully now, coolant is fully bled, wastegates are all tight and working. Has an IAT sensor now
  9. #109
    May 2009
    dover
    none
    damn thats looks great!!trim those little pipes a bit
    IG: dimitriantoniou
  10. #110
    Nov 2012
    Atlanta, GA
    1995 BMW M3 Coupe
    Ya, I will eventually trim the wastegate dumps. Forgot to do it before I Cerakoted them, now I'm afraid of scratching them up lol
  11. #111
    Nov 2012
    Atlanta, GA
    1995 BMW M3 Coupe
    Finally got the car out on the track. Went to iTrack's excite GP comp at Lanier Raceplex in GA.
    In the Week leading up to the event, the car was Dyno tuned at Solo Motorsports. Unfortunatly, my 340TW 245's werent enough on the back of the car, and we kept spinning on the Dyno, best numbers were 550RWHP @ 4700 rpm dyno'ing in 5th Gear.
    As for the Drift day, I had a rough start. I went out before the track opened up because I really hadn't driven the car at all, and my PS fluid boiled over causing a small fire in the engine bay. Spent most of the morning patching that up and swapping out hoses. Got it going again and got to drive for the afternoon.
    After a few runs, I was driving comfortably in 4th gear, and did a full throttle transition on the back straight. Welp, something happened and there was a terrible knocking coming from the engine. I was done for the day.
    Turned out I spun cyl 1 rod bearing. I'm not sure if the rod bolt stretched (wasn't broken) or if the oil broke down due to temperature, but it happened.
    This morning, I dropped the now disassembled block off to the machine shop, along with Lunati Rods, Wiseco Pistions, a new crank, and all new bearings should be going back into the car next week if all goes well. I wont be looking to make more power, but hopefully sustaining high RPM won't be a problem now. The machine shop is:
    1. Decking block
    2. Cylinder hone
    3. Cam bearing install
    4. Balancing Rotating assembly (w/ Flywheel and Pulley)
    5. Line hone main bores
    Anywho, here are some pics.
  12. #112
    Apr 2016
    Detroit, MI
    1997 328i, 89 325ix
    Something to note w/ LS Swaps in track/ drift cars is that many people have had oiling issues. I would look at upgrading to a baffled oil pan and/or adding an accusump. A stock F body pan just isn't designed for high G's.
  13. #113
    Nov 2012
    Atlanta, GA
    1995 BMW M3 Coupe
    Quote Originally Posted by beat328i View Post
    I had the Improved Baffle in my Fbody pan, and an oil cooler, but nothing else.
    Last week I bought the 3qt accusump for the new engine. Admittedly, I decided not to get it last time. Maybe it would've saved my motor.
  14. #114
    Apr 2016
    Detroit, MI
    1997 328i, 89 325ix
    good idea! Hope it works out for you. Oiling issues can be hard to treat effectively w/o proper data.
  15. #115
    Nov 2012
    Atlanta, GA
    1995 BMW M3 Coupe
    Shes back running, new mods other than the forged Internals are:
    LS9 cam
    LS7 Lifters
    LS2 lifter trays
    80mm Throttle body
    Accusump
    Large Oil Cooler
    ARP main studs
    Tube Front (still needs to be finished)
    She has not been retuned yet, there are some hot start issues and timing issues that need to be worked out hopefully this week.
    Heres an updated engine bay pic!
  16. #116
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    looks good.
    what paint did you shoot your bay with?
    instant grams: doktor_b
  17. #117
    Nov 2012
    Atlanta, GA
    1995 BMW M3 Coupe
    Quote Originally Posted by doktor b View Post
    looks good.
    Thanks, its Machine Grey single stage paint off amazon
  18. #118
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    Quote Originally Posted by blake261 View Post
    word. i have a trunk, interior, and an engine bay to paint and i'm exploring my options.
  19. #119
    Nov 2012
    Atlanta, GA
    1995 BMW M3 Coupe
    Seems to be an good paint. I didn't do too much prep, and you can easily pull it off the super smooth panels like its plastidip (bare aluminum, underneath of grease covered frame rails, etc) but it's my fault for skimping on the prep work. On may cage and interior, its holding up very well.
  1. Joe's E36 Drift Build Thread
    By joeemartuccii in forum Drifting
    Last Post: 06-25-2013, 03:47 PM
  2. e36 drift build, advice
    By 325iSmannn in forum Drifting
    Last Post: 05-22-2013, 08:14 PM
  3. Replies: 12
    Last Post: 04-05-2013, 09:30 PM
  4. E36 Feeler/FS: 95' M3, S52 OBD1, RMS Stage II+, CCW Classics, BBK, Recaro
    By BimmerMan3 in forum 3 series & Z Series
    Last Post: 06-07-2011, 10:26 PM
  5. Fs: 95' obd1 s52 m3
    By autowaune in forum 3 series & Z Series
    Last Post: 09-16-2008, 03:56 AM
