Results 1 to 5 of 5
Thread: ZF 5HP30 No reverse >>fixed
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Today our wrenching group helped out an E34 540 owner. He came from around 100 miles away to my home, arrived here at 8AM.
    We took the valve body off, and as expected the small .236" diameter checkball located in the bathtub in the channel plate had blown through the spacer plate and had disappeared forever.
    So we cleaned the complete valve body, tested the solenoids, checked the springs for cracks, re-assembled the valve body with a new checkball, added new trans fluid and a new filter.
    He test drive the car and was quite happy and could return home already at 1.30PM.
    While we repaired the trans for him, we also changed the outer door handle gaskets against new ones from my stock, they crumbled into pieces when we took the handle cover off.
    As for the 5HP30 no reverse problem, I copied here for you the relevant info:
    BMW ZF 5-HP-30 NO REVERSE
    COMPLAINT,CAUSE,CORRECTION:
    1991 and later BMW vehicles equipped with the ZF 5-HP-30 transmission may exhibit a no reverse condition, when selector lever is placed into reverse.
    The cause may be, the .236" diameter checkball located in the bathtub in the channel plate has blown through the spacer plate, which will now exhaust "F" clutch (Reverse) oil pressure.
    Install a .250" diameter plastic checkball into the bathtub in the channel plate as shown in Figure 1. The holes in the spacer plate over the bathtub measure .198" and the larger diameter checkball will greatly decrease the probability of this condition occuring again. There is also ample room in the bathtub for the increased diameter checkball to perform its duties. Refer to Figure 1. Figure 2 illustrates the location of the only other checkball in this unit and do not install checkball in the location marked "X".
    special note:
    The checkball wearing and blowing through the spacer plate causing the loss of reverse, may also have caused some damage to the "C" Clutch which is also on in reverse. This condition has also been known to create damage to the "A"/"C" Clutch Housing as well. If the clutch housing has been severly damaged, aluminum material will be evidenced in the bottom pan upon inspection.
    When the unit is removed and the "A"/"C" Clutch Housing is dis-assembled, it is not uncommon for the unit to set for over a week waiting on parts. When re-assembling it is
    very easy to mis-assemble the "B" Clutch Hub on top of the retaining snap ring for the "A" Clutch pack. This mis-assembly will create a neutralizing on the 3-4 upshift, and the Trans light will begin flashing.
    Ensure that you assemble the "B" Clutch Hub on top of the "A" Clutch stack, and then install the "A" Clutch Pressure Plate and snap ring, as shown in Figure 3.
    Those having a 5HP30 in their E32 740, better download the complete info here
    http://www.europeantransmissions.com....BMW/98-61.pdf
    To refill the trans fluid from the bottom of the trans we used a simple garden sprayer (pressure type), just removed the spray nozzle and extended the hose a bit to for the purpose.
    Sep 2016
    Vienna, WV
    1994 BMW 740i
    Shogun where are you located.. would you be willing to do this for me for the right price
    I dread the reverse clutch pack retaining clip has broke off the clutch pack.. but am hopefull in the check ball valve solution.. or a valve body rebuild hopefully!!
    Jan 2005
    Japan
    Sorry, cannot help you, I live in Japan.
    Sep 2016
    Vienna, WV
    1994 BMW 740i
    Lol
    Jan 2005
    Japan
    pics of the valve body overhaul 5HP30 http://e32b12.blogspot.jp/search/label/5HP30
  1. No Reverse? Fix it YOURSELF!
    By cacrawfo in forum 1996 - 2003 (E39)
    Last Post: 10-19-2022, 08:18 AM
  2. which Steptronic ZF 5HP19 has No Reverse problem?
    By Carcrazy in forum 1999 - 2006 (E46)
    Last Post: 09-09-2010, 10:38 PM
  3. BMW ZF 5HP30 no reverse
    By shogun in forum 1988 - 1994 (E32)
    Last Post: 08-11-2010, 06:34 PM
  4. Another ZF tranny with NO REVERSE
    By fleetwood530i in forum 1996 - 2003 (E39)
    Last Post: 02-20-2009, 01:13 AM
  5. No Reverse - ZF 5-HP Tranny problem
    By anbmw323 in forum 1999 - 2006 (E46)
    Last Post: 05-16-2006, 03:19 PM
