Engine w/Tranny $2500
Full M3 Brake Conversion Front Spindles/Calipers/Paged Brake Pads/Rotors $500
Shell $500
Dove Grey Front Door Panels $300
Engine Wire Harness $250
Trunk Lid $250
VANOS unit $150
AC Compressor & Hoses $150
Catalic Converter w/o2 sensor $150
Spark Engine Coils $100
Oil Filter Housing & Alternator Power Steering Pump Bracket $100
Fuel Injectors $100
Full AC System $100
Headers $100
Front Control Arms $75
AC Controls $75
Factory Amp $75
Passenger Air Bag $75
Ignition $75
Valve Cover $50
ABS Computer $50
AC Evaporator $50
Ac Evaporator 2 $50
Engine Smog Sensor Tube w/hoses $50
Steering Rack Piece $50
Front Sub Frame $50
Driver Rear Window $25
Passenger Rear Window $25
Cat Heat Shield $25
Side Center Console Panel $25
Side Glove Box Panel $25
Center Trunk Panel $25
Driver Trunk Panel $25
Passenger Side Trunk Panel $25
Ignition Surround Top Panel $25
4pc Springs Caps $25
6pc AC Vents $25
Fuel rail cover $25
Trunk Spare Tire Cover $25
Radiator Blade $25
E-Brake Handle Arm $25
14 Cam Shaft Brackets $25
3 AC Metal Hoses $25
3pc Air Vents $25
3pc Big Hoses $25
3pc Fuse Box $25
2 Unknown Interior Module $25
Muffler Heat Shield $25
Small T Hose $25
Dip Stick $25
Two Under Car Brackets Holders $25
Seat Belts $25
Steering Wheel Adjuster Lever $25
AC Unit $25
Above Glove Box AC Vent $10
ECU Cover Panel $10
Water Tank w/cover $10
Thermostat Housing $10
Fuel Gas Cap $10
2pc Dash Wind AC Vents $10
Front Map light $10
Door Latches $10
Ashtray $10
2pc Behind Dash Board Panel $10
1st & 2nd Radiator Hose $10
3rd Radiator Hose $10
2 Rear Brake Sensors $10
Rear Ac Vent $10
Dim Switch Panel $10
Fuse Box Relay Cover $10
Passenger Door Lock $10
Battery Tray $10
3 Relays Under the Wheel $10
Cowl Rubber Strip $10
Injector 6 Clips $10
Oil Cap $10
Seat Belt Adjusters $10
2pc Hood Popper $10
Throttle Body Spring $10
Trunk Door Lock $10
Fuel Pump Covers $10
Rear Windshield Defrost Computers $10
Small L Hose $10
2 ABS Hoses $10
Bosch Platinum Spark Plugs 6 $10
2 Timing Belt $10
Negative Red Cable $10
2 Brake Cables $10
E-mail sent.
I e-mailed you back, so check your e-mailOriginally Posted by ElSupremo
Here is the link to the page that shows all my current ebay auctions http://cgi6.ebay.com/ebaymotors/ws/e...sort=3&rows=50
Do you have the rear trailing arms ?
i got the whole car. show me pics of trailing arms and make me an offer and they will be off next day
Here's a PicOriginally Posted by bmwm3parts
Another Pic.
make me an offer
I need the complete 5speed conversion.. There a list of main parts.. 5 speed tranny, shift linkage, shifter, shifter boot, . Basic I need the WHOLE thing from Tranny all the way to the back. Everyparts to convert automatic to 5 speed. PM or Email me your price.
I'll pay for shipping
Also I might be interested in the engine, PM or email me your QUICK selling price.
-peter
i will sell the whole car : full engine/exhaust(not the muffler part)/suspension Billstein/Complete Rear End differetial etc/tranny/ecu/shift linkage for $4000
I talked to you yesterday and called you right now
EUROPROJEKTZ-WORLD.COM
www.KCollection.org
how many miles are on the engine?
as far as i now 131k but it could of been rebuilt because it runs very good. it keept up with 13.9-14.0 GTI.
Estoril Blue didn't come out intil 1996, yet you say the car is a 1995 model?
BMW Cigar And Gun Club Member #7
I left a message on your voicemail call me up.
I was the one interested in the rear end.
www.KCollection.org
the car was painted estrosil 4 months ago read the post.
i got the messege yes $4k for whole car i will call you back in 5 min
How much would it be for the front passenger side fender, and the nose panel?
$250
intrested in your cupholder/coin holder. what else would i need to get it to fit a 1993 325is that originally did not come with the cup holder?
thanks, steve
arm rest panel/ashtray/cup holder w/coin slots everything for $100 shipped
is there a difference between with the consoles that come with cup holders and those without? can you send a pic of the whole assembly to schen27@hotmail.com.
thanks, steve
its on ebay right now. user id cellem-inc check it out
Paypal sent for the clears
interested in the armrest console. what does it come with? is the armrest included?
do the floor mats have M3 embrodiered on them and do they have the holes so u can latch them down to the little tabs in the floor?
