Page 3 of 5 FirstFirst 12345 LastLast
Results 51 to 75 of 110
Thread: E36 Vert 5.0 SBF Daily/Drift/Stancecar Swap
  1. #51
    Nov 2013
    Houston
    09 Challenger R/T 93 RX7
    There is a lot more room in there than I expected, easily could fit a 351w in there, there is an engine you can go crazy with power
  2. #52
    Northeast NJ
    X5/5MT || Z4MC
    Quote Originally Posted by motocaddy View Post
    Yeah, I feel you on not rushing. I'm totally prepared to head to uhaul on Saturday and trailer the car to the show.
    Power wise, this setup will be at 200whp/280wtq, with a good looking torque curve. With pretty much any head/cam/intake setup, I'll be at 300whp. If I need anything else, I'll be running nitrous. Not crazy power, but pretty good for the cost of admission.
    Definitely man, plus for a drift car being different is always more exciting. Pretty sad how the entire valvetrain upgrade on those cars, new, are less than JUST cams for your old stock motor hah. Keep it up man.
    Past Builds:
    S54 E36 Compact Build|Thread|IG|@_goldfinger|
    Current Fleet:
    Z4 M Coupe - Black Sapphire Metallic over Black
  3. #53
    Nov 2011
    Houston, TX
    E36 vert 5.0 V8 swap
    Quote Originally Posted by Classy View Post
    There's probably room, but some things would need to be changed up, like brake booster and oil pan. Those 351s can handle quite a bit more power for sure.
    Quote Originally Posted by Ragnorak View Post
    Yeah, to get the M52 to decent power levels, it was going to take a complete rebuild and turbo setup. That was going to cost much more than this complete rebuilt swap and not sound near as good.
    Lot of little things to hook up in the next 36 hours, but it's getting closer for sure. Last night was finishing oil setup, wiring everything up, reworking harness to look a little better, and fabbing up radiator brackets/cutting support.
  4. #54
    Jun 2008
    colton, ny, usa
    95 M3 turbo V8, GSXR 600
    Looking good I can't wait to see it running.
    1995 E36 turbo v8
  5. #55
    May 2010
    Ozark Missouri
    04 Stang ,96 328 coupe
    what MAF is that? is is monstrous!
  6. #56
    Nov 2011
    Houston, TX
    Quote Originally Posted by svt4me View Post
    the 70mm that came on 93/94 Cobras and later mod motors. it's supposed to be good for 5hp or so. it has a 4 bolt pattern, so there is a 4" adapter on there.
    so far the car cranks, but won't start. not sure what is going on. I can see spark on coil wire and by holding plug up to block, but nothing on plug wire with timing light. it has fuel pressure and injector pulse.
  7. #57
    May 2010
    Ozark Missouri
    It may sound dumb but take the intake tube off and spray starter fluid down the intake while cranking, (takes 2 people) I had to do this on my old 302 turned out to be he idle air control valve. Also wondering if that Maf is talking to your computer right, I think the Maf has to be pair with certain injectors like 24# injectors with 24# Maf. Hope Ive sparked an idea somewhere. Not trying to dog on your engine building skills,but have you checked for compression ?
  8. #58
    Nov 2011
    Houston, TX
    Thanks for the input. I'm sure it's going to be something simple that finally fires it up. I've tried starter fluid with no difference. I read up on these MAFs before getting it and they work with 19# injectors. I haven't checked compression with a gauge, but I can tell it has some from turning it over and all the air its forcing out. Either way, it would show some signs of life with low compression. Currently, its not trying to fire at all. Occasionally, 1 or 2 cylinders will fire, but that's it.
  9. #59
    Northeast NJ
    X5/5MT || Z4MC
    If starter fluid doesn't fire up the car, it's most likely an ignition or ignition timing issue. How's the distributor?
    If you have fuel pressure and the injectors are pulsing, you'd get some combustion but it may not idle. Also, check your engine grounds. If the straps are corroded or weak, you may be getting a shitty spark.
    Past Builds:
    Current Fleet:
  10. #60
    Oct 2008
    West coast
    '00 540 6.0/4L80e/S480
    I had a very similar problem when I did a 351 swap a few years ago. The magnetic pickup in my distributor was weak. The TFI module is another possibility. Good luck!
  11. #61
    Nov 2011
    Houston, TX
    Thanks, guys! I think you're on the right track. I'm gonna first improve my grounds and add one from the block to the battery. Then start replacing parts in the distributor.
    It's killing me having this thing stuck at 90% complete and not being able to do some burnouts.
  12. #62
    May 2010
    Ozark Missouri
    If this helps, I think the 86 is the non-HO which has a different firing order.
  13. #63
    Nov 2011
    Houston, TX
    Nah. It's an HO in the GT. The difference is the '86 has E6 heads and the pistons don't have valve reliefs (I upgraded to '88 pistons/rods though).
  14. #64
    May 2010
    Ozark Missouri
    any good news after the weekend?
  15. #65
    Sep 2013
    San Francisco, CA
    e39/6.0 LS turbo project
    That motor looks good in all black!
  16. #66
    May 2013
    Largo, Florida
    1996 e36 convertible
    Nice progress man! I read your first build thread as well and this car has come a long way! good luck on getting it to run.
  17. #67
    Dec 2013
    Keizer,Oregon
    2000 328i sedan
    Until today I didn't know anyone was doing swaps like this, very cool!
  18. #68
    Nov 2011
    Houston, TX
    I improved all the grounds with no change. I ran a ground strap from block to chassis and 8-gauge wire from block to negative battery. I'm going to install a new distributor next and see if that makes any changes. If not, I'll trailer it up to work and start a full diagnosis and test each connection.
  19. #69
    Jan 2013
    Naperville, IL
    1993 318is
    Maf matched to pcm/injectors? Distributor 180? Tfi module, coil etc...in that order
  20. #70
    Jun 2008
    colton, ny, usa
    Any luck yet?
    1995 E36 turbo v8
  21. #71
    Nov 2011
    Houston, TX
    Quote Originally Posted by masat03 View Post
    All this has been checked or is new and seems to check out. To me, it's either ignition based problem (as shown by weak spark) or something is going on with the BMW side of things. It turns over, so I believe that means the immobilizer is bypassed, correct? Also, I checked the x20 pinouts between '97 318i (car that harness came from) and my '98 323i and it seems to be the same.
    Quote Originally Posted by natem31995 View Post
    Any luck yet?
    Nothing yet, but I honestly haven't tried a lot with holidays and crap weather. Right now I'm finishing up the last few things on car, such as front end, cooling, and put bay together, even though it doesn't run. Then I'm going to tow it up to work and see if we can't figure it out. I work at one of the best speed shops anywhere, so confident between the lead tech and tuner, they can get me sorted out. But if y'all can think of anything else I should check, please let me know!
  22. #72
    Feb 2013
    Houston, TX
    e36
    Ben this might sound contrary to the work, however have you checked voltage across all the main positive terminals? Alt, starter, battery post, etc?
  23. #73
    May 2010
    Ozark Missouri
    Must have update !!!!! P.S. What radiator is that ?
  24. #74
    Nov 2011
    Houston, TX
    Quote Originally Posted by DatTugrut View Post
    I think I'm good on voltage, but I could check more. I've tried two batteries and the charger with no changes.
    Well the car is mostly put together and ready to haul up to work. My hope is that the geniuses up here will have it figured out in a few minutes and I can properly break it in on our track and dyno. Fingers crossed!
    It's probably 90% done here. Got all the cooling system finished and the front end back on. The wiring is as clean as I can get it for now without cutting anything. Once it runs, I plan on reworking the engine harness, so that it's mostly tucked away. The radiator/fan/shroud/relay combo is from Summit.
    Got some sweet valve covers from my parents for xmas, so painted and sanded the engine badge to match.
  25. #75
    Jul 2004
    Austin, TX
    AA turbo 332i
    Covers and badge (among other things) look awesome! Somewhere up there Henry sheds a tear...
    Best of luck getting it all squared away, can't wait to see it on the track this summer
    1995 325i | OBD1 S52 | S50 cams | AA Turbo TD06 20g / 42lb / Porsche maf | .140 MLS | F1 s3 clutch | Ultimate SSK | AKG 75D subframe/diff bushings | 3.23 LSD | Powerflex LCAB/RTAB | e46 fca | Raceland coils | BMP rear arms | DEPO HID | AEM Failsafe | Aeromotive FPR | Walbo 255 | 3" Magnaflow muffler/cat/res | 17x8.5/9.5" 225/45 & 255/40
  1. E36 bmw e36 vert wanted $2k
    By eurohead in forum 3 series & Z Series
    Last Post: 08-05-2011, 02:28 PM
  2. E36 fs/ft 1997 bmw 328ic e36 vert queens
    Last Post: 12-15-2010, 03:54 PM
  3. E36 Steal of the decade: MINT e36 vert with 57k on it. FIFTY SEVEN! $5,000
    By SixSquared in forum 3 series & Z Series
    Last Post: 11-03-2010, 03:06 PM
  4. E36 WTB E36 Vert
    By ny2tx in forum 3 series & Z Series
    Last Post: 10-14-2010, 11:06 PM
  5. E36 WTB e36 vert complete interior
    By germaniac in forum BMW Parts Wanted
    Last Post: 07-22-2010, 01:03 PM
