Results 1 to 25 of 28
Thread: 7-Series M-Parallel Fitment on an E34 M5
    Jun 2013
    Albuquerque
    91 318is, 91 M5
    Hello everyone,
    I was wondering if the M-Pars from a 7-series fit an E34 with the proper tire size? I found a good deal on a set, and wanted to snatch them if
    they can properly be mounted. Any info would be greatly appreciated.
    Thanks,
    Dallas, TX
    e30, e30, e34, e34T, M3
    Yes they will work perfect on an E34.
    The 7-series tires are pretty tall though and won't work on the front. I believe they come with 235/50/18's and 255/45/18's.
    I ran them with just changing the fronts to a shorter tire and keeping the 255/45's on the rear on my E34 sedan.
    Here's a pic for reference:
    Mar 2011
    Vancouver, BC
    too many, see sig
    Yeppers - to confirm Teaguer's post, no issues with running E38 M-Pars on the E34 - no hubcentric rings needed. Just the correct tires for our cars, as the E38's are too tall.
    My Current Cars:
    E70
    2010 X5 4.8i Xdrive Spacegrau
    E90
    2008 M3 6MT Silverstone II
    E34 1992 M5 3.6 J-spec Calypso
    E34 1990 535/5 turbo Bronzit
    E32 1990 750iL Highline Delphin
    E30 1988 325i M54 swapped Schwartz Convertible
    No longer with me:
    E46 2001 330Ci Titanium Silver
    E32 1993 740iL Lazurblau
    E34 1992 525iT Kashmirbeige
    E34 1990 535/5 Cirrusblau - Former Miller Performance Stage 2 Test Mule Car
    E34 1989 525i Cirrusblau - the Slug
    E21 1981 320i w/ M20 swap Arktisblau
    E21 1979 320i Turmalingrun
    Wheels older than E39 will be fine
    Dec 2005
    North Carolina
    540i/6 M-sport GA65474
    Yes! Yes! Yes!
    E38 Mpars fit our cars like they were made for them! Simply buy the appropriate tires for them.
    TireRack.com recommends 235/40-18 for the fronts and 265/35-18 for the rears
    I went with Continental ExtremeContact DW Max Perfromance Summer tires and loved them!
    Gone but not forgotten:
    '95 540i/6 M-Sport. GA65474. Alpineweiss/Parchment.
    Supercharger project
    Apr 2008
    CA
    E34 M5
    E34 M-Parallels were "made" for E34s. E38 fitment is second in line....
    Jul 2010
    Hawthorne, NJ
    '95 6spd 540
    E34 M-Parallels were 18x8 et20 and 18x9 et22 correct? with 235 and 255 tires? I'm less sure of tire sizes than I am of offsets.
    - Hans - Mauritiusblau Metallic - Ultimate Klasse - Progress Thread: LINK
    Apr 2008
    CA
    E34 M5
    Yes offsets are correct, factory size is 245/45 front and back on the staggered setup.
    Jun 2008
    Atlanta, GA
    E53, E38, E34, E39T
    Quote Originally Posted by gixxerboy63 View Post
    Yes! Yes! Yes!
    Gixx is 100 Percent on. Fits like glove, looks like sex.
    Some Places remain unknown because no one has ventured forth. Others remain so because no one has ever come back......
    Aug 2012
    Chattanooga,TN
    1995 540ia M-sport
    SEX!
    Gixxer do you run spacers? Your fit looks a bit more aggressive than mine.
    Jun 2013
    Albuquerque
    91 318is, 91 M5
    Thanks fellas! What tires would you guys recommend I run?
    Arlington Heights, IL
    Z1, M3 LTW, 228
    E34 spec M Parallels: F 8J ET 20, R 9J ET22. Factory Tire Size 245/45 Front and Rear
    E38 spec M Parallels: F 8J ET 13, R 9.5J ET25
    Forged Version of M-Pars: 36-11-2-227-931 and -933
    Why isn't this in the FAQ in some form? Its a common question/search I'm sure.
    Alex Lipowich
    xyobgyn on AOL
    Trying to make the world a better place with 5 extra throttle bodies at a time.
    Jun 2013
    Albuquerque
    91 318is, 91 M5
    Would 235/40-18 for the fronts and 265/35-18 for the rears be a proper tire size?
    Apr 2008
    CA
    E34 M5
    Yes, that is a common setup for e34s on e38 fitment style 37s...
    Dec 2005
    North Carolina
    Quote Originally Posted by M540fella View Post
    SEX!
    Nope. No spacers. I think it's just the angle..
    Jun 2013
    Albuquerque
    91 318is, 91 M5
    265/40/18 not clear in the rear? Why is there a lower profile in the rears?
    Aug 2009
    Greeley, CO
    540i6, 540iA, RX7, RdBlk
    Quote Originally Posted by Dazpoop View Post
    To keep the overall diameter of the tires the same. If you're unsure how this works, tirerack has a lot of helpful articles to help you understand tire sizes and other good to know info about tires in general.
    Fox
    Jun 2013
    Albuquerque
    91 318is, 91 M5
    Thanks for all the help fellas!
    Nov 2011
    Beirut, Lebanon.
    1992 BMW 850i/6
    Yes! Yes! Yes!
    Gixxer, I've noticed something weird. You have 265's in the back, but they look extremely snug on those wheels. They extend quite obviously over the rim, and look awesome.
    Funny thing is, my 275's don't look that good on mine. Are you sure you're running a staggered set? I can't tell from the pics as I'm not wearing my glasses and your M-Pars are oh so sexy and shiny.
    1992 BMW 850i/6speed. Stock as stock can be.
    Aug 2009
    Greeley, CO
    Quote Originally Posted by Shoomakan View Post
    Different tires have different profiles...it's likely that your tires are just more round shouldered than his Conti's. Remember - the width measurement is at the widest part of the tire, not the tread itself. On a lot of tires that's right on the sidewall just above the rim (when discussing low profile tires like these). Some tires are really square shouldered and broad tread, others are 'European profile' and really rounded, with narrower tread. I prefer the former, myself.
    Other than that, you can clearly see the increased width or his real wheels in the pics...they be staggered.
    Fox
    Dallas, TX
    Like Fox mentioned above tire size and look varies between different Brands and even within the same brand.
    Also Gixxers Continentals have the "Rim Protector" built into the sidewalls which give them a different look completely.
    Nov 2002
    Nürnberg, DE
    German Super Saloon
    245/40R18 and 275/35R18 on mine. No spacers no rubbing.
    Photobucket sucks!
    Long live the E34!
    la Praga
    1992 535i E34
    Nov 2011
    Beirut, Lebanon.
    1992 BMW 850i/6
    Quote Originally Posted by K Fox View Post
    Fox
    Valid points. However, my Nexens have curb protectors, too. Gixxer, is your M-Par set E34 or E38 spec? If it's a 9 inch wheel in the back, I think that is my answer.
    My 255's are mounted right now for some sliding action. Will take pics when I re-mount the 275's for comparison.
    If you do have 9.5" in the back, then I guess K-Fox is right. It's simply a different tire design.
    Again, looks great.
    Apr 2002
    Texas
    1995 M5T Elekta
    I need a single 8J for the trailer project if anyone's gotny
  1. What kind of power can be made on an E34 M5?
    By Mann Von Gott in forum 1988 - 1996 (E34)
    Last Post: 10-05-2007, 12:53 AM
  2. Please help! Bleed Valve on an e34 M5 1994??
    By TazE34M5 in forum 1996 - 2003 (E39)
    Last Post: 12-22-2006, 08:18 PM
  3. Another wheels question- 18x8.5's all around on an e34 m5?
    By skateparks in forum 1988 - 1996 (E34)
    Last Post: 02-02-2006, 10:14 AM
  4. Will UUC TME and Bushings fit on an E34 M5?
    By Gop-Dogg in forum 1988 - 1996 (E34)
    Last Post: 01-24-2004, 10:10 PM
  5. OEM M parallels fit on an e34?
    By elusive23 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 09-16-2002, 01:24 AM
