Wow, and I thought your 525 was clean.
Both cars are about as clean as they get in those pics. The lighting, etc, hides the oxidation on the 525's roof, among other things...
Current: '94 MX-6 V6/5 • '72 240Z • '10 Mazda5
Past: '02 330i/5 • '85 RX-7 GSL-SE • '95 540i/6 • '95 525i/5 • '86 635CSi/5 • '88 JZA70 • '86 4K quattro • '85 RX-7 S
Wish list: Type 44 • Manta • Pre-'85 CGT • 405 Mi16 • SVX • W123 Coupe
Wat?
I thought your 525 was clean, and it is, but the 540 next to it is immaculate, so the 525 looks filthy in comparison.
The 525 definitely has its share of dings and scrapes compared to the 540, which is incredibly clean and dent- and scratch-free; I guess I just don't see how you're seeing that from those pics. Sure you can see the spot of bird crap on the hood of the 525, but overall I though the picture showcased the car pretty well and hid most (all?) of its defects.
Eh. Ain't no thang.
Where's the M50 going?
He's scrapping it tomorrow, better get any parts off him now before it's too late.
Get the Konis. You will be happy with the few extra dollars spent. I find that my front Billie sports crash pretty hard on really bad roads.
Be sure to buy new mounts too. I would buy the parts as cash allows and install it all at once.
I got my B&B from LM Performance. They have the best price hands down.
http://www.lmperformance.com/185777/.html
If you can save a couple hundred buying a used one from Tyler, jump on it.
Thanks Pat. I'll hold out for the Konis. Don't want any crashing. Are you still on stock (M-Tech) springs?
No, I have billie sports and eibachs. I really like the eibachs but I want to be a little lower in the front.
I will be selling these off soon. Perhaps you would want the springs? They should work really well with the Koni's.
The LowTec is another option for you. They are $525 shipped from Mel and include springs (your choice of drop), strut inserts, front strut mounts and rear shocks.
I should have this Lowtec setup here in the next week or so. I really liked the spring rates and shock valving and had no crashing on my touring with them.
I opted for 45mm/40mm springs.
Good info. I'm bleeding through my budget pretty quickly, so I'm going to have to be selective at this point about what I replace/upgrade... Will let you know about the springs. I had a set of Eibachs on my old Supra that I liked a lot.
I'm on Billies and stock springs and the ride is perfect and I have never bottomed out. Just want to dispel any billie hate.
Current
2005 E55 AMG
1998 Silverado K1500
1964 Impala
1964 Chevelle 496ci
Past
2000 Avus M5
1988 Suburban K1500
1987 Suburban K2500
2007 Suburban
1999 K2500 Suburban
2000 MGM
1999 K2500 Suburban
2001 Stratus 740i Msport
1990 750iL
1995 540i/6
1996 MGM
Do you have sports?
I don't think there is anything to dispel. If enough folks who actually have sports and have reported the crashing, are giving a subjective substantiated viewpoint, there is truth to it.
I wouldn't necessarily say the car bottoms out, its the internal bump stops that are found in the sports that bottoms out (harshly) before the spring reaches full compression.
The sport rears are actually valved very nicely and never have these problems. Its only the fronts.
Guys who have had their sports custom valved at bilstein seem to fix the inherent problem.
I never had any problems or crashing with H&R's and Billlie sports on my e24, I liked them enough that I bought the same setup 3x for 3 different E24's.
Based on years of driving that car with the Billie sports, I thought some of these guys were nuts and had some other problems till I experienced it myself.
Thanks Mike! And yes, big thanks to Fox.
Yeah I don't want that. I guess I'll pass on these, then:
http://forums.bimmerforums.com/forum....php?t=1999116
You can try to dispel the hate all you want - but for a daily driver, Bilstein shocks suck. I have HD's on my 94, and I hate the way it rides. Still stock (tall as hell) springs, so they're soft and all, and it rides worse than the 6 speed does. Bilsteins are not comfortable - they're more....because racecar. I've also had Bille's on another car of mine for over 10 years, and it totally sucks for daily use. They're simply way too stiff, and the bumpstops in them are too long (interfere too early). I won't buy another set of them probably ever - if I want 'racecar' handling, I'll go coil-overs, and if not I'll want something comfortable.
Also, aren't you currently being rode in OT for driving you car like an octogenarian?? You likely don't push it hard enough to know if the shocks crash...
Fox (being playful today....)
Bilsteins on e34s are terrible, absolutely horrid. Try a Koni and you'll be sold for life.
Then I must hav sports because I don't experience any of that. In fact, I am extremely content with the current set up for daily use.
I haven't been pushing my car lately because the motor mounts are leaking. Which can lead to colossal failure should they fail, namely the driver's side. New poly mounts arrived yesterday.
Current
2005 E55 AMG
1964 Impala
1964 Chevelle 496ci
Past
2000 Avus M5
1988 Suburban K1500
1987 Suburban K2500
2007 Suburban
1999 K2500 Suburban
2000 MGM
1999 K2500 Suburban
1990 750iL
1995 540i/6
1996 MGM
You might have Bilstein Tourings, they do not have the internal bump stop and there are not very many if any, complaints about them. A great shock for a stock set up.
The sports have more of a problem than the HDs due to a shorter stroke. I'm not sure if the HDs have an internal bump stop.
Cosmos Black/Black 1995 540iA M-Sport
BMW Individual Exclusive Edition, 1 of 65 total, 9/25/95 Build
OEM additions include Euro trim, passenger seat mounted first aid kit, tool kit warning triangle, clears all around, black chrome exhaust tips, spare tire well gas can, and rear armrest fridge.
Waiting for install is an adjustable lumbar support, & drivers side glove box...
Konis on the way.
I'm going to order front and rear shock mounts:
Anything else I need?
I'm not sure if the konis require new bump stops or not.
I'm pretty sure I had bump stops on my Porsche spec konis.
