Have some e36 stuff left, refer to the list. call/text (8zero5)5seven0-8one7seven for fast response.
Engine
-m50 manifold/fuel rail/harness-SOLD
-Throttle bodies/sensors
-s52 EGR valve with tubes/gaskets/pipe
-Knock/ping sensor OBD-II
-rear exhaust rubber mount/hanger/bracket
-Oil separator-SOLD
-Coolant hoses-SOLD
-DME unit-SOLD
-ABS control unit-SOLD
-Injectors-SOLD
-Ignition coils-SOLD
-Coils harness set-SOLD
-O2 sensors-SOLD
-PS pump-SOLD
-Belt tensioner-SOLD
-Driver's engine bracket-SOLD
-Vibration damper-SOLD
-Chain tensioner(lower)-SOLD
Transmission
-Cross-brase-SOLD
-Hub/flange for driveshaft(4bolt)SOLD
-Auto shifter assembly, burl wood knob
-Oil cooler-SOLD
Suspension
-Stock springs-SOLD
-Axles/half shafts for 318ti or z3-SOLD
-Front wheel hubs-SOLD
-Tie rods-SOLD
-Rear non-M brake calipers, pads-SOLD
-Rear slotted/cross-drilled rotors
-SACHS Super Touring front struts-SOLD
-ROGUE Engineering rear shock mounts-SOLD
Interior
-Pedal bracket/housing with switches
-Brake pedal for auto
-Leather e-brake boot/handle-SOLD
-Coupe drovers power seat(for parts)
-4dr seals/weatherstripping
Exterior
-1 hood shock(OEM)
-Passenger taillight for 2dr
-Side markers/repeaters
up??
what did you do?!!!!how did that thing come apart like that?
the giant hole in your intake?
it was dropped...not by me, so it hurts even more ;-(((
up??
have good upper and lower radiator hoses? if so PM me
up
bump
Are you willing to part with the s52's cams? If so please PM me with a price.
~Russ
up
bump
up
u p up
bump
Secondary pump and valve?
bump
