Season is back on
Sent from my SM-N960W using Tapatalk
Did the oil change
And air filter change
Did the direction tuning
New set of tires
Did some maintenance work, changed shifter rod seal and output shaft seal
As a comment I note that some of the amounts seem a bit high, but I see them in a better context after returning from Vancouver and realizing the exchange rate (0.75 $US =1.0 $ Can).
Season 2019 is finish
2020 is on
Sent from my CLT-L04 using Tapatalk
Big project ongoing, full new paintjob for her 20 years
shiny!!
Wip
Paint job completed, new roof and oil change
Très belle Z3 M, et magnifique peinture! Vive les BM bleues!
90,700 miles 1992 BMW 735iL Azure Blue Metallic with Silver Grey leather interior ‣My car ‣My YouTube channel
Merci
Bimmers and a golden
Changing the spark plug for NGK platinum and the rubber clutch line for a SS line.
Part
Work in progress
Done
New spark plug
New spark plug and clutch line
Getting caught up on the maintenance for the new to me 2000 M. Oil change, tranny fluid, spark plugs, and a new braided clutch line. Shifts so much better now. New fluid really smoothed out the shifts and the clutch line works much better. Previously, I had to jam the pedal all the way to the floor really hard to get it into first, second, and reverse. And forget it if I held the pedal down for too long and then tried to shift. I had to let off the pedal and shove it down again. Spent maybe $150-175.
Hardest part was getting some of the clutch line fittings loose. After 20 years, they were not giving up easily.
Brian
2000 M Roadster
I agree, changing the clutch line is great really make a difference!!
Big work this week, RF kit will be installed, with new sub frame bushing, new short stick speed shifter, new rear brake pad, hopefully new rear shock if I can receive the Koni...
