Page 2 of 12 FirstFirst 1234567891011 ... LastLast
Results 26 to 50 of 288
Thread: M Roadster maintenance log (example)
  1. #26
    Dec 2012
    Just got her out today, she run great after a long winter!!!
  2. #27
    Dec 2012
    Mileage when she got out
  3. #28
    Dec 2012
    At 106000 km, oil filter change at Heroux, painted the galiper, new rotor and pad for the front wheel.
  4. #29
    here & there
    01 LSB 367M
    If you want to save yourself some $ oil changes are easy DIY. Especially easy when you use a fluid evacuator pump like the Motive 1708 or similar products by the Mityvac brand. No need to raise the car up, just suck all the oil out with the Motive or Mityvac through the dip stick tube and replace the oil filter. Then, you can take the used oil to your local recycling center or service station that accept used oil.
    Detractors of this method claim this method would not remove contaminants from the bottom of the pan. But, that is the reason you are suppose to replace the filter with every oil change regardless of extraction method.
    2001 S54 LSB/NAPA. 1 of 7.
  5. #30
    Bloomington, Illinois
    2011 E92 M3, 2007 335i
    I started a log a long time ago with the thought I'd have it for when I may sell the car. Eventually, started doing so much pre-emptive maintenance and service (like two oil changes a year on less than 8000 miles) and modifications (some irreversible) that I just threw in the towel. Anyone locally who knows my car, knows the level of care. It will likely sell locally just because of its performance.
    Now in E92 M3 ZCP -- Absolute beast
  6. #31
    Dec 2012
    Thanks for the advice. I like to have it done at Heroux near Mtl. They only work on BMW since 1976, I appreciate the fact that they look at the car too.
  7. #32
    Dec 2012
    Stored for the winter, snow soon in Mtl
  8. #33
    Apr 2013
    Dayton, TennUnited States
    1998 BMW Z3 2.8L
    While a car is in storage the gas tank should be 100% full with 100% gas/no ethanol. This prevents as much moisture from accumulating in the tank.
    Start the car often and let it run long enough to get the oil hot enough to evaporate the moisture out of the oil.
    Reinforcing the welds on the cross member in the trunk alone is not enough. The differential flopping about can rip the trunk floor. I attached round spring steel to the bottom of my differential and attached the spring to the car's frame with roll bar linkage. So far so good. It is only necessary to attach to the car's frame on the passenger side. I did all the work at a cost of $30 for materials. On my 1998 Z3 2.8L roadster I found four holes on the bottom of the differential suitable to tap and attach a steel plate that I welded the spring steel to. This is likely the cheapest way out of this nightmare. A torsion bar from a junkyard is a good source for round spring steel. I used round spring steel because there isn't much room to work with back there.
  9. #34
    Might want to store it on jackstands to prevent flat spots on the tires
    PRICE CUT on ALL FABRICS
  10. #35
    Dec 2012
    Season 2015 is on.
    When for esthetic stuff this year, got the lower front bumper re painted, changed the sidelight to the euro model (white with orange bulb), got the euro licence plate holder painted to the car color and got a new german plate. This when for 550$ canadian dollars
    Also met a guy who love to do esthetic on car, he did a glare and wax, buffed a scratch I had on the side, cleaned the engine buffed all light and treated the leather of the seat, 220$ canadian dollar
    She is all set for the season
  11. #36
    May 2015
    Annandale, VA
    2002 BMW M Roadster
    Looks nice! I like the side picture with the hood up.
  12. #37
    Dec 2012
    Dec 2012
    Here is that storage time of the year
  14. #39
    Dec 2012
  15. #40
    Dec 2012
    Season is back
    Sent from my HTC One_M8 using Tapatalk
  16. #41
    Aug 2009
    Goodyear AZ
    2002 Z3 M
    Nice to see a pampered Estoril roadster.
    Pandora
  17. #42
    Dec 2012
    Got 4 new tires on
  18. #43
    Dec 2012
  19. #44
    Mexico
    02' Z3 2.2
    Beautiful roady, but i'm a little confused
    I thought Canada got euro spec cars with the S50, smaller glovebox etc?
    I find it a bit strange seeing as here in mexico we only got the S50, not the S52
    Daydreamer.
  20. #45
    Dec 2012
    We have the s52 up here
  21. #46
    Dec 2015
    Canada
    1999 M Roadster
    Where did you order the tires from?
  22. #47
    Dec 2012
    Tire rack
  23. #48
    Dec 2012
    Did the sub modification with 8" kicker, loving the new sound
  24. #49
    Dec 2012
  25. #50
    Quote Originally Posted by Yazure View Post
    Canada got US spec cars for this era. They got a very small run of special edition E36 M3's that came fitted with the euro S50.
    This is actually the first I've heard that Mexico got the euro S50 as well. Though, I'm not even aware of a large sales effort of these cars in Mexico to begin with, so maybe they are imports. I'd be curious to look up the VIN on S50-equipped cars in Mexico to see the destination country.
