Page 1 of 12 1234567891011 ... LastLast
Results 1 to 25 of 280
Thread: M Roadster maintenance log (example)
    Dec 2012
    Hi,
    Being the new owner of a 2000 M Roadster (92500 km, Canadian model), I had the idear to post the log of all work that were done on the car. This to give reference to future new owner like me (I m also a Noob in the Bimmer world) as to what to do and how much it should cost (estimation).
    Also, if you noticed that I paid too much for some item, please share your comment (so that Noob like me will know what to expect price range wise) All price are in CAD.
    I live near Montreal, Qc and go to a garage named JJ Heroux in Chambly, they guy run his garage since 1976 and only deal with BMW. He is a passionate as far as I can tell!
    So log entry 1:
    This week, after inspection of the car before purchase, I had the following done:
    Price include labor and part (I ll got the breakdown but was around 900$ for part, rest in labor, car was in for 3 days)
    Flex disk was crack and was replaced 300$
    One of the welding holding the exhaust was broken, re welded for 50$
    The passenger seat belt bucket was replaced (the airbag light was on, now it off) 300$
    Changed the water pup 300$ (preventive mesure)
    Changed one tie rod bushing 180$ General tuning, all liquid and filter were check, prestone was changed, 10W60 oil change (15$ per liter), I had my own air and oil filter with me (bought from Bavarian) 208$
    Total came to 1338$ tax in (we paid 15% tax in Qc…)
    Tomorrow, going in for sub frame welding (crack started to appear under the car…). 600$ tax in. They will remove the differential to go in, they done it on multiple BMW, never had a customer coming back. Carroserie Demers in St-Jean
    Dec 2012
    Log entry 2
    Had the oem spoiler removed, the hole in the trunk filled and the trunk repainted
    500$
    The sub frame was reinforced by welding, the removed the differential to do the job 600$
    Dec 2012
    Log 3
    Had "alignement" done and tire got azote. 87$
    Got a professional appraisal of the car for insurance purpose 160$
    Jan 2006
    Los Angeles
    M Roadster
    I'm surprise to hear your flex disc needed replacing to soon. I've replaced the on a number of different m roadsters at around 75-100k miles as preventative maintenance and observed little to no cracks. Do you think it has something to do with the weather the car is driven in or the driving style?
    Also, although your in Canada, does the 2000 model not have the 3.2 ltr S52 engine? If you're using 10w60, it infers you have the S54 engine released in the 2001-2 models.
    Congrats on the car and thanks for sharing your progress.
    Los Angeles
    Dec 2012
    I have the S52, mechanic recommended 10/60 oil
    Flex disk had crack
    Car was never driven in winter condition
    Nov 2001
    Chapel Hill, NC
    2000 M Coupe, 318TI
    Quote Originally Posted by sepota View Post
    That is not BMW NA recommendation - http://www.bmwusa.com/Standard/Conte...ngineOils.aspx
    Dec 2012
    S52 they recommend 10W60 (preffered) or 10W40
    Nov 2001
    Chapel Hill, NC
    2000 M Coupe, 318TI
    Interesting. Unless my memory is failing me, this section is new
    If Castrol High Performance Synthetic Oil is not available and you need to add oil between oil changes, only use synthetic oils with the following specifications for M vehicles:
    Viscosity - preferred SAE 10W-60
    Alternative - SAE 10W-40, SAE 5W-50 or SAE 10W-50
    Plus my preferred oil, Mobil 1 0-40, no longer seems to be a S52 recommended oil.
    Dec 2012
    Did the glove box fix, cost 30$, took 2 hours, well worth it!!!
    The machine last week end
    mcoupemindy's Avatar
    mcoupemindy is offline Senior Member BMW CCA Member
    Supporting Vendor
    Jan 2005
    Haymarket, VA
    '99 M Coupe
    Any 10 weight is wayyy too thick for the factory engine tolerances on the S52.
    Sep 2008
    Havertown, PA
    02 e367, 08 Acura TL-S
    What OEM spoiler did you remove? Pics? Still have it?
    -Todd
    Dec 2012
    Here
    Dec 2012
    Father and son car picture!
    Dec 2012
    Changed the original sound system for an Alpine no CD usb blue tooth model.
    Labor 135$ tax in with Future Shop
    Radio is around 100$.
    Dec 2012
    Changed the antenna for a stubby look:
    8$ on ebay
    Dec 2012
    Oil change at 99k km. 143$
    Will need to change front disk and pad (vibration when braking at high speed).
    Dec 2012
    Hit 100k km
    Springfield, Ohio, USA
    1998 Z3 Roadster
    I like your idea of keeping a maintenance log. I do the same, but add more detail, particularly the manufacturer and part number for most parts that I replace. If a part works well, I'll know what to order next time. If it doesn't. I'll know to look for other recommendations. Specifically for something like the flex disk there are many choices such as different materials and manufactures. The same goes for brakes, belts, hoses, tires, filters, fluids, etc. Even for BMW parts, I sometimes use non-model-stock parts. It's also possible that later-on, I can assure a potential buyer that I used quality parts for the repairs I made.
    I used to keep a log book on each vehicle, much like an aircraft maintenance log, but now I use a computerized document (MS Word) and I sometimes add pictures and scanned documents.
    Dec 2012
    Indeed!
    I have a big binder at home with all documents related to the car
    Dec 2012
    Did a small cosmectic mod, adding a M logo up front
    Not really a fan of the grill badge... especially one so big. But then again I am the type to remove the badges from my car... badges distract from the beauty of the car IMO
    Quote Originally Posted by SoCalDan View Post
    At 75-100k miles the flex disk has probably already been replaced once.
    PRICE CUT on ALL FABRICS
    Dec 2012
    Please note that I m running a canadian car, mileage is in km, so I now at 60k mile
    I agree that the logo is quite big, wonder how big are the oem one? One standard size?
    Apr 2013
    Dayton, TennUnited States
    1998 BMW Z3 2.8L
    If you haven't you may want to consider removing the clutch/mechanical fan before it explodes/flies apart.
    http://forums.bimmerforums.com/forum...4#post26801354
    Apparently you live in a cool climate so the stock thermostat (198F) and aux fan dual contact temperature switch should do fine (The stock temperature switch is 91c/99c or 196F/210F).
    there is an engine over-temperature light that comes on at 125c (257F) as measured by the block coolanttemperature sensor monitored by the DME..
    Dec 2012
    Store for the winter. 335$ until may. Battery on battery tender.
    Dec 2012
