Page 4 of 5 FirstFirst 12345 LastLast
Results 76 to 100 of 106
Thread: BF.c FI - Big Torque Club (>500wtq Dyno Results)
  1. #76
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Someone needs to update this list.
  2. #77
    A house
    '86 325e, '14 VW EPA
    Update with 9180, E98, 27psi, 883/792
  3. #78
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by TheJuggernaut View Post
    <img src="http://www.bimmerforums.com/forum/attachment.php?attachmentid=579528"/>
    Doesn't count.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  4. #79
    Los Angeles, CA
    #Project333Ti & Z3 Coupe
    Would love to see what that turbo can do at 32-35 psi!
  5. #80
    A house
    Doesn't count.
    Why?
    Quote Originally Posted by e30polak View Post
    It wouldn't make any more boost without tapering back down up top, so it's pretty maxed out on my setup. Granted it's billed as a 1000hp turbo so that's about right.
  6. #81
    Jun 2006
    San Jose, CA
    98 AW M3/2/5
    Forum Username: ///dean
    Chassis Code: 98' M3/2/5
    Engine: S52
    FI Type / Size: SPA T3/GT35R 0.82
    Engine Displacement: 3.2L
    Compression Ratio: 10.5:1
    Fuel Type: E85
    Manifold Pressure: 18psi
    WHP: 610
    WTQ: 571
    Build Thread Link:
    https://www.bimmerforums.com/forum/s...85-Stock-Comp)
    Dyno Sheet Image:
    2006 CB M3/2/SMG
    1998 AW M3/2/GT35R
  7. #82
    Los Angeles, CA
    Quote Originally Posted by ///dean View Post
    Engine: S52
    Fuel Type: E85
    WHP: 610
    WTQ: 571
    Build Thread Link:
    Dyno Sheet Image:
    One of the best set-ups for the money IMO
  8. #83
    Mar 2013
    Upstate NY
    M3
    Very impressive but it looks like it rolls over on the high horsepower pull. Probably tapped out for the 35r. Awesome graph looks majestic.
  9. #84
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    It is so responsive that I would not care about dropping a few rwhp at 6900. A balance choice in turbo for one of these motors. I really liked mine. I got about the same out of my 0.82 GT3582R at 607/580 SAE but was on 93 pump with supplemental meth and needed 21 psi.
  10. #85
    May 2003
    Irvine
    95 M3, 03 E55, 07 335I
    Im hoping for similar results with my upgraded GT3586 wheel and meth, along with the steed speed twin scroll manifold.
    Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
    New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
  11. #86
    Please update me. Finally built, I guess?
    Chassis Code:E36
    Engine:S52
    FI Type / Size:Precision 6466 ball bearing
    Engine Displacement:3.2
    Compression Ratio:9.0:1
    Fuel Type:Pump - Cam2
    Manifold Pressure:30.2psi
    WHP:771
    WTQ:709
    Dyno Sheet Image:
  12. #87
    Jkpgt96's Avatar
    Jkpgt96 is offline One of those JZ swappers BMW CCA Member
    Jul 2012
    St. Louis, MO
    2JZ 95 M3
    Chassis: E36 M3
    Engine: 2jz
    Compression: 10:1
    Displacement: 3.0L
    FI Type: S366 turbo
    Fuel: e70
    Dyno type: Dynojet 248
    EMS: Megasquirt 3x v3.57
    Boost: 28 psi
    We did 757/710 as our highest pull, but these were the final numbers as the car started heat soaking after repeated pulls and 85 degree temps outside.
    1995 M3 - Forged 9.8:1 2JZ, S366, MS3x, E85, LQ9s, 420g/PMC Motorsport kit, 4 clutch 3.15 LSD Large Case 757whp/710wtq
    2011 X5 Xdrive35d- Blk on Cinnamon, Towing Pkg, Heat Pkg., etc..the tow rig/DD!
  13. #88
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Forum Username: E36 hater
    Chassis Code: e36
    Engine: stock piston m52, eagle rods, s50 cams
    FI Type / Size: turbo/ sxe369
    Engine Displacement: 2.8L
    Compression Ratio: 8.5:1
    Fuel Type: E85
    Manifold Pressure: 29
    Runs were made in 3rd gear
    WHP: 869
    WTQ: 688
    Build thread link
    https://www.bimmerforums.com/forum/s...a-budget-build
  14. #89
    Mar 2003
    NC
    CES Stage 3 Turbo M3
    CES Motorsport 9180 EFR Turbo Dyno #'s
    We still updating this thread? I guess we need to post up our latest dyno info also...
    Forum Username: jgcm3 (CES Motorsport)
    Chassis Code: e36
    Engine: Built S52
    FI Type / Size: Turbo / BW 9180 EFR
    Engine Displacement: Built 3.2L
    Compression Ratio: 9.5:1
    Fuel Type: MS109
    Manifold Pressure: 32 psi
    Runs were made in 4th gear
    WHP: 866
    WTQ: 825
  15. #90
    Oct 2016
    Philadelphia, PA
    E36 2JZ
    Quote Originally Posted by E36 HateR View Post
    Chassis Code: e36
    Fuel Type: E85
    WHP: 869
    WTQ: 688
    Build thread link
    If possible I'd get the 9180 EFR like jgcm3 has. That 2.8 would hit full boost 1500 rpm sooner and put up the same power, more torque
  16. #91
    Los Angeles, CA
    Quote Originally Posted by JOutterbridge View Post
    Turbo isn't the only factor here, Franc has a 2.8L at 8.5:1 CR vs jgcm3 with a 3.2 at 9.5:1 CR. The added displacement and compression are definitely playing a big role in the spool difference here. Also, Franc has super long gears, and his run is being done in 3rd gear, vs 4th gear like jgcm3 which loads the turbo more.
    Obviously the 9180 is a faster spooling turbo, but it also costs a lot more. All things equal, maybe a 500 rpm difference in spool, not 1,500... lol
  17. #92
    Mar 2011
    Canadian in California
    Makes whoosh noises
    An update for my car:
    Same old S54 motor, E85 fuel, Precision 7675 Gen2 0.96A/R Open
    Red Run -12psi on gate
    Blue Run -29psi with 47%wgdc
    Stock HG otherwise I'd bump the boost some more.
    1000+RWHP, Lab22 Built Turbo S54 - BMW Half Mile Record Holder
  18. #93
    Louisville, KY
    turbo m3
    Nice!^^^
    So, when the change of turbos? Are you hunting for peak power now? IIRC, you always wanted transient response? Which EMS are you using, just wondering.
  19. #94
    Mar 2011
    Makes whoosh noises
    Quote Originally Posted by BadBoostedBmwM3 View Post
    Nice!^^^
    I went from the 7168 0.81A/R a few years back to the 6870 0.81A/R and made about 930rwhp with that. The two were actually pretty comparible with the 6870 being slightly better.
    I upgraded about 4 months ago to the 7675 Gen2 0.96 A/R to give it a go. It's a bit laggier but in all honesty it's not as bad as I expected. My goal was to increase efficiency overall with less backpressure. EBP dropped considerably and I'm no longer limited on the turbine with as hard as I've pushed it so far.
    So far I'm very happy with it; there's no question that the 6870 is a fun street turbo but this 7675 has given me that new rush of adrenaline. I'm using the AEM Infinity for an EMS.
  20. #95
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Also stock s50 cams and a stock head, and my setup is still t3. Had her over 40psi this weekend at FL2k.
  21. #96
    Louisville, KY
    turbo m3
    Quote Originally Posted by Commanderwiggin View Post
    I remember that change. The big turbos are stout when they hit.
    Dang! I didn't think that that compressor could go that far on our platform.
  22. #97
    Oct 2016
    Philadelphia, PA
    E36 2JZ
    Good points Polak. The 2.8 was loaded in 3rd so it's the other way around. Also 8.5 to 9.5 isn't a HUGE difference in compression. 6% or so efficiancy. The displacement means the most. Either way, 500rpm makes a big difference especially on a street car..
  23. #98
    Apr 2006
    Manchvegas
    Boosted M3’s
    Very impressive.
    I really love that turbo.
    1997 Cosmos E36 M3/4/5 Boost Logic GT40/94r .85 Technique Tuning
    Stock motor
    1998 Estoril E36 M3/4/c4 Steed Speed2 Gt40/94r 1.06 Technique Tuning,
    Built motor, Best ET ( 9.63 @ 142.61 mph MS100+meth ) 10/08/21
    Best mph ( 10.08 @ 144.66mph MS100+meth ) 9/18/19
    build thread:
    http://www.bimmerforums.com/forum/showthread.php?2269817-Habbit-continued-Turbo-build-V
  24. #99
    Mar 2012
    Renton, Wa
    98 m3
    992 whp
    930 wtq
    will be back for more.
    Forum Username: vollosso
    Chassis Code: e36
    Engine: Built S52
    FI Type / Size: Turbo / PTE 6870
    Compression Ratio: 9.2:1
    Fuel Type: e70
    Manifold Pressure: 46 psi
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  25. #100
    Jul 2014
    Finland
    BMW E36 328i Turbo
    Forum username: Matuh
    Chassis code: E36
    Engine: M50b28tu with m52 pistons, Forged Conrods, Double intake cams.
    FI type/ Size: Turbo / Garret GTW3884R 1.15ar T3 twinscroll
    Compression ratio: 10:1
    Fuel: E85
    Manifold pressure: 21psi
    484Whp
    600ft-lb wtq
