Page 3 of 5 FirstFirst 12345 LastLast
Results 51 to 75 of 104
Thread: BF.c FI - Big Torque Club (>500wtq Dyno Results)
  1. #51
    St Paul, MN
    1 bewsted, 1 boring
    Forum Username: Harvington
    Chassis Code:e36
    Engine: s52 stock block
    FI Type / Size: hta3586r
    Engine Displacement: 3.2
    Compression Ratio: ~8.5
    Fuel Type: 110
    Manifold Pressure: 21psi
    WHP: 531
    WTQ: 544
    (dyno image: two pulls at 21psi, one pull at 14psi for baseline to use at road course - read fault with rpm - 1400tq )
    e36 '97 M3 “Built” S54 Velocity Stacks TTFS AlphaN
  2. #52
    Jul 2002
    Long Island, NY
    98 Turbo M3, 04 E53 X5
    Nice to see my old set up is still going strong! Congrats! Probably could of done that on pump gas.
  3. #53
    St Paul, MN
    1 bewsted, 1 boring
    You've been great inspiration, thank you!
    Probably could have gone on pump. Jordan recommended something higher than 93 if I'm playing above 20, this being on an mls gasket. The setup has been running now strong and putting a lot of surprised faces on people. Can't wait to have a built bottom.
  4. #54
    Huntsville, AL
    95 M3
    Quote Originally Posted by Harvington View Post
    (dyno image: two pulls at 21psi, one pull at 14psi for baseline to use at road course - and one of the two 21psi pulls I hit it with a 900 shot of nitrous and pulled - 1400tq )
    I fixed it for you
    WOT
  5. #55
    St Paul, MN
    1 bewsted, 1 boring
    It was a dyno day event. The "audience" had a several "holy s---!" Rolling out. DUDEBRO 1400!!
  6. #56
    Jun 2015
    uk
    m1
    I guess I can be considered to previously have been on this list... your determination to add or not.
  7. #57
    Jun 2015
    Texas
    1999 E46 M3
  8. #58
    Jun 2015
    uk
    yes
    I'll post a dyno sheet when I find it.
  9. #59
    Ft. Lauderdale, Fl
    E36 M3, Mk2 GTI
    Forum Username: Jamdun17
    Chassis Code:E36
    Engine: 1jzGTE
    FI Type / Size: SC6169 T3 .63
    Engine Displacement: 2.5
    Compression Ratio:8.5
    Fuel Type: E85
    Manifold Pressure:26
    WHP:582
    WTQ:1606..
    ..534+
    Build Thread Link:
    http://www.bimmerforums.com/forum/sh...build-and-swap
    Dyno Sheet Image:
    MODS
    1JZ, BC 264 cams, BC TI Springs and Retainers, Ferra Keepers, Arp Head Studs, Arp Main studs, Arp rod bolts, Custom Emerald Performance Dual Plenum intake, 70 mm TB, SC6169 T3 Turbo, full 3 inch SS exhaust, Ar5 Transmission, 60lb injectors, Walbro 400 fuel pump, GTR intercooler. Porsche Turbo Calipers, Gutted Tein SS coilovers with Koni Race shock inserts , Tein Pillowball Camber Plates, UUC Swaybarbarian bars....needs more mods and a tune!!!!
  10. #60
    M5Hunter is offline 800 Wheel Torques Supporting Vendor
    Nov 2009
    Hanover, VA
    Turbo LS1 E39
    Forum Username: M5Hunter
    Chassis Code: E39
    Engine: LS1
    FI Type / Size: Turbonetics TC78
    Engine Displacement: 5.7 346ci
    Compression Ratio: 9.5:1
    Fuel Type: 93octane / Methanol Injection
    WHP: 764
    WTQ: 800
    Build Thread Link: http://www.bimmerforums.com/forum/showthread.php?1888893-My-e39-LSx-swap
  11. #61
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Forum Username: E36 hater
    Chassis Code: e36
    Engine: stock block m50
    FI Type / Size: turbo/ 66.6mm hx40
    Engine Displacement: 152ci 2.5L
    Compression Ratio: 11:1
    Fuel Type: E85
    Manifold Pressure: 26.5
    WHP: 717
    WTQ: 550
    Build Thread Link: http://www.bimmerforums.com/forum/sh...uild-part-Deux
    Dyno Sheet Image:
  12. #62
    Jun 2005
    virginia beach
    Turbo S52 E39 M5
    Forum Username: Litemup
    Chassis Code: e39
    Engine: S52, 87mm Cp/eagles, SS Oringed, +1mm intake valves, S52 cams
    FI Type / Size: Turbo - PT6266 CEA, T3 .82 a/r
    Engine Displacement: 3.2L
    Compression Ratio: 8.5:1
    Fuel Type: 100 octane
    Manifold Pressure: 35psi
    WHP: 813
    WTQ: 819
  13. #63
    air, dirt, fire, water
    95M3 92525iT 78810 95525
    Forum Username: milKt
    Chassis Code: E36
    Engine: M52, 84.5mm CP/eagles, SS Oringed, S52 cams
    FI Type / Size: GT4088r, T4 .85 a/r
    Engine Displacement: 3 L
    Fuel Type: 93 oct
    Manifold Pressure: 21 psi
    WHP: 621
    WTQ: 599
    BUILD THREAD: Haiku
  14. #64
    Jul 2011
    Meriden, CT
    97 M3 sedan, 2015 STI
    Quote Originally Posted by milKt View Post
    Forum Username: milKt Chassis Code: E36 Engine: M52, 84.5mm CP/eagles, SS Oringed, S52 cams FI Type / Size: GT4088r, T4 .85 a/r Engine Displacement: 3 L Compression Ratio: 8.5:1 Fuel Type: 93 oct Manifold Pressure: 21 psi WHP: 621 WTQ: 599
    Awesome!
    Sent from my iPhone boosting SPA-7000h
    THE TIME DRAWS NEAR!
  15. #65
    Mar 2012
    Renton, Wa
    98 m3
    Forum Username: Vollosso
    Chassis Code: e36
    Engine: S52
    FI Type / Size:
    64/65 billet turbo, Maxpsi T4 manifold, 3.5" ss exhaust, Fx725 twin ceramic, Synapse 50mm WG, Synapse DV, Spearco intercooler, Vibrant resonator and muffler, Arp 2k Headstuds, Ces 87mm Cutring, Custom solid rear subframe bushings, Akg 85d diff bushings, 14mm diff bolt conversion, Custom Ms41 60# tune.....
    Engine Displacement: 3.2l
    Compression Ratio: 9:1
    Fuel Type: 93 pump
    Manifold Pressure: 19psi
    WHP:500
    WTQ:500
    Build Thread Link:
    http://www.bimmerforums.com/forum/sh...s-schapenwagen
    Dyno Sheet Image:
    Attachment 555844
    Attachment 555845
    1989 535i - sold
    1999 Tiag/Dove M3 - sold
    1998 Turbo Arctic/black - current
    2004 TiAg/Black - Current
    PTE6870 | 1.15 ar | Hp Cover, Custom Divided T4 bottom-mount, 3.5" SS exhaust, Dual Turbosmart Compgates, Turbosmart Raceport BOV, 3.5" Treadstone Intercooler, 3.5" Vibrant resonator and muffler, Arp 2k Headstuds | Arp 2k Main studs | 87mm Je pistons | Eagle rods | 9.2:1 static compression, Ces 87mm cutring, Custom solid rear subframe bushings, Akg 85d diff bushings, 4 clutch 3.15 diff, , Poly engine mounts, UUC trans mounts W/ enforcers, 22RPD OBD2 Stock ECU id1700 E85 tune, 22RPD Big power Transmission swap w/ GS6-53
  16. #66
    Vancouver, B.C., Canada
    '97 M3
    Here is an update......
    Forum Username: Chikinhed
    Chassis Code: e36
    Engine: S52
    FI Type / Size: GTX3582R
    Engine displacement: 3.2 L
    Compression ratio: 8.5:1
    Fuel Type: Pump 94 e10 + water/meth
    Manifold Pressure: 24 psi (based on my datalogs)
    WHP: 660 whp
    WTQ: 628 wtrq
    Build Thread Link:
    http://www.bimmerforums.com/forum/sh...s-FI-Solutions
    Sheet Image:
  17. #67
    Nov 2009
    Georgia
    EVO II, LADA
    Forum Username: GeorgeGG
    Chassis Code: E46
    Engine: M52
    FI Type / Size: Single Turbo Borg Warner s471
    Engine Displacement: 3.0L
    Compression Ratio: 8.8:1
    Fuel Type: 100 Octane + 50/50 water/Eth injection
    Manifold Pressure: 29PSI (Peak)
    WHP: 683
    WTQ: 827 (WNM)
    Build Thread Link:
    Dyno Sheet Image:
  18. #68
    Miami, FL
    '02 530i & '15 X1 35i
    Forum Username: JackEatsEmoKids
    Chassis Code: E39
    Engine: M54b30 all stock
    FI Type / Size: PTE 6262 T4
    Compression Ratio: 10.2:1
    Fuel Type: Pump E85
    Manifold Pressure: 22psi
    WHP: 596
    WTQ: 558
    Build Thread Link: need to find it
    '02 E39 530i/5sp Topaz Blue/Black Interior - MegaSquirt3x - Garrett GTX3582R turbo - E85 fuel - Apex FL-5 - 265/295 tires - Custom Porsche Brembo BBK - 600whp @ 22 PSI
    '15 E84 X1 35i M Sport Alpine White/Coral Red Interior - H&R Sports & Bilstein B6 - Velgen VMB5 - 265/305 tires - ETS FMIC - MPI Charge pipe & DME Flash - 3.5" down pipe
  19. #69
    Quote Originally Posted by JackEatsEmoKids View Post
    Congrats sir
    and tell Rey I said Happy Holidays and Merry New Year.
  20. #70
    Mar 2012
    Renton, Wa
    98 m3
    Chassis Code: e36
    Engine: S52
    FI Type / Size: 9.0:1 Je 87mm pistons, eagle rods,
    6465 billet JB turbo, Maxpsi T4 manifold, 3.5" ss exhaust, Fx725 twin ceramic, Synapse 50mm WG, Synapse DV, Spearco intercooler, Vibrant resonator and muffler, Arp 2k Headstuds, Custom solid rear subframe bushings, Akg 85d diff bushings, 14mm diff bolt conversion, Custom Ms41 80# tune with soft timing.....
    Engine Displacement: 3.3l
    Compression Ratio: 9.2:1
    Fuel Type: 93 pump
    Manifold Pressure: 18.5psi
    WHP: 537
    WTQ: 519
    Build Thread Link: http://www.bimmerforums.com/forum/sh...nder-The-Knife
    Dyno Sheet Image:
    1989 535i - sold
  21. #71
    Manchester, N.H.
    96 332IS 6466 turbo
    Thread needs updating.
    Maybe a mod could if M Coupe is busy.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  22. #72
    Jun 2004
    Youngsville, Louisiana
    2001 M Coupe
    Forum Username: E.Hands
    Chassis Code: e36/8
    Engine: s54
    FI Type / Size: PTE 6266 GEN2 CEA Stock engine, factory ECU - Mike Radowski, Nick Glantzis
    Compression Ratio: 11.5:1
    Fuel Type: MS109
    Manifold Pressure: 18 psi
    WHP: 703
    WTQ: 510
    Build Thread Link: coming soon
    Dyno Sheet Image:
    -Ed Hands
    MaxPSI Stg2 Turbo
    R.Forbes magic F&R
    100K Original owner miles.
    Proud member of the BF.c FI - Big Torque Club (>500wtq Dyno Results)
  23. #73
    This is so dirty (base tune) but it is a start.. also need some small air hardware changes to get afr in line...
    Forum Username: Tramontane
    Chassis Code:E36
    Engine:S52
    FI Type / Size:Precision 6466 ball bearing
    Engine Displacement:3.2
    Compression Ratio:9.0:1
    Fuel Type:Pump - 93
    Manifold Pressure:19.4 psi
    WHP:542
    WTQ:502
    Build Thread Link:Haven't made one yet
    Dyno Sheet Image:
  24. #74
    Los Angeles, CA
    #Project333Ti & Z3 Coupe
    Quote Originally Posted by tramontane View Post
    Chassis Code:E36
    Engine:S52
    Fuel Type:Pump - 93
    WHP:542
    WTQ:502
    Dyno Sheet Image:
    Whose tune?
  25. #75
    m3mods's Avatar
    m3mods is offline Boost Addict BMW CCA Member
    Sep 2011
    Oregon
    ACS3 Sport CLS
    Forum Username: M3Mods
    Chassis Code: e36
    Engine: S52 (87mm)
    FI Type / Size: Single turbo, Garrett GTW6765 tuned by 22rpd
    Fuel Type: 100LL Avgas
    Manifold Pressure: 26psi
    WHP: 732
    WTQ: 669
    Build Thread Link: http://www.bimmerforums.com/forum/sh...Breaks-700whp-
    Dyno Sheet Image: Attached
