Page 38 of 41 FirstFirst ... 132829303132333435363738394041 LastLast
Results 926 to 950 of 1015
Thread: my build thread, e30 with a 9 inch
  1. #926
    Feb 2010
    Texas
    01 530i
    Congrats!
  2. #927
    DeWitt, Michigan
    '97 540i/6, '97 328i
    Damn, big congratulations! You got the bulk of the work done on your car just in the nick of time.
  3. #928
    Jul 2005
    PEI, Canada
    2001 330i
    Congrats!
    Big "family" mod. :P
  4. #929
    Chicago
    '99 M3
    Congrats dude! The kids are where it's at.
    TEC-3R, T4 GT40, WISECO, EAGLE, SUPERTECH, O-RING'D "FRANKENSTEIN" STROKER.
  5. #930
    Vancouver, B.C., Canada
    '97 M3
    Are heated tracks a common thing?
  6. #931
    May 2013
    Australia
    E30 M50B28 Turbo
    Double congrats mi amigo!
    Can't wait to see what that TH400 beast can do.
    1989 E30 - M50B28 Turbo - ZF 8 Speed
  7. #932
    Jun 2004
    PA
    Too many to list...
    Congrats!!
    '97 M3/4
  8. #933
    Bellingham, WA
    e30
    Congrats on the newborn!
    Car seems OK too
    -Nick
    91 E30 M42 on VEMS
    Turbo Camshaft Thread
  9. #934
    Mar 2012
    Renton, Wa
    98 m3
    Congrats!
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  10. #935
    Apr 2006
    Minnesota eh?
    86 325es
    Thanks all
    Couple things I forgot to post about. The shifter that I chose to use in the car is a hurst promatic 2 ratchet shifter.
    https://www.jegs.com/p/Hurst/Hurst-P...45831/10002/-1
    Reason I chose this shifter is it is a full ratchet shifter from neutral to 3rd gear, has an NHRA approved reverse lockout, and unlike most ratchet shifters it does not have any levers or latches to pull in order to put it in park. To go from neutral to Park you just lift up on the shift lever and push it forward.
    This video shows the shift pattern, except my trans would be PNN123
    https://m.youtube.com/watch?v=KkQpa3vgJCs#
    The idea was to fit this under the factory center console and not have any latches or anything showing. In order to fit it under the stock console I had to drop it down into the trans tunnel so I made a box to mount it into and cut a hole in the tunnel for it.
    There was a couple things I did not like about this shifter. The handle was at a goofy angle and too short, and I did not like the shift gates on it. I took it apart to modify to my liking.
    Here is the shifter disassembled.
    Here is the shift gate. Park is on the upper right and the slot on the lower left would be to ratchet from neutral-1,2,3. I forgot to take a picture of it afterward but I reshaped these slots so in neutral you can just lift up the shifter and go straight to park without clunking through reverse. Same for going from park to neutral. On a transbrake th400 in order to put the trans in reverse you actually have to put the shifter in neutral and push the transbrake button, so you never use the reverse shifter position anyway.
    For a shift handle I cut off the original and tig welded the stainless steel handle that I had laser cut for my T56 and angled it to get the shift position right.
  11. #936
    Jun 2004
    PA
    Too many to list...
    Ma man!! Nice work!!
    '97 M3/4
  12. #937
    Apr 2006
    Minnesota eh?
    86 325es
    Here is the parachute mount. Its just a piece of 1-1/2 dom tube going through the rear bumper into the trunk and welded to my rear frame crossmember. There is a piece of 1-1/4 dom tube that telescopes inside it and acts as the actual mount so it’s removable by just taking out one bolt.
    Here is where I F’d up. I just eyeballed the length without the bumper trim on.
    shit
    I had to cut out the bumper trim for the bolt to fit in and out because I’m a retard
    The clevise for the drag line is made from a piece of rectangular tubing. It’s important that the drag line can rotate around the pin without friction or it will tear up the loop so I made an inner and outer sleeve and greased it so it rotates freely.
    cable release handle
  13. #938
    Jun 2004
    PA
    Too many to list...
    Rippin' off good times yet?
    '97 M3/4
  14. #939
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by douglee25 View Post
    Tracks are all closed for the winter in MN. I want to try to get to a track in Wisconsin this weekend but I'm in the middle of a bunch of remodeling so I don't know if that will happen.
  15. #940
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Impressive. Huge work done.
    e39 540i 6speed Supercharged,
    E36 v8 m62 with m60 headers, Turbp HX-40 0.6-0.5bar or 9psi, custom exhaust & Turbo manifold, injectors 440cc, ECU Invent EMS-2, Mishimoto Intercooler and oilcooler, etc…
  16. #941
    Jun 2004
    PA
    Too many to list...
    Dang. Sounds good. Come to TX... We're still running here!
    '97 M3/4
  17. #942
    Aug 2009
    Dakota County, Minnesota
    1997 BMW 328i
    So glad to see you are still chugging away on this thing man - that motor you put together for me is still on the streets!
  18. #943
    Apr 2006
    Minnesota eh?
    86 325es
    Picked up two more victims today. Pair of non vanos m50’s. One will get built to go in the car, current motor will be the backup, and the third will be a spare to go on the shelf till its turn comes up.
    The bores on both of them gauge out less than half a tenth wear due to the moly faced rings that the non vanos motors used so I don’t even need to bore them. Just dingle ball hone them and drop the pistons in.
  19. #944
    Dec 2014
    Des Moines, IA
    '97 M3/4/5.0
  20. #945
    Sep 2008
    Wilmington NC
    96 Oil Gobbler
    Did you have another kid!?
  21. #946
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by GT35Rm3 View Post
    yeah I have a 5 month old a 3 year old
  22. #947
    Apr 2006
    Minnesota eh?
    86 325es
    Starting to get this pile back in shape to fight. We start racing two weeks from today and I have some a small list of stuff to do before then.
    First some electrical housekeeping. Last year while I was putting the car together I had some feature creep in the build by adding two stages of nitrous that I hadn't planned for, so my fuse and relay setup was getting overloaded. I had bought a small fuse and relay box in the glovebox but because of all the stuff that got added I had quite alot of circuits on each relay and fuse. Also I had an intermitent issue last year where the starter solenoid would not work when the car was warm. I traced that problem back to that there was too much resistance through my start button and the safety switch on the shifter to reliably put enough current to the starter solenoid to engage it. To fix all this I built a new fuse and relay board and relocated it on the firewall.
    The new fuse and relay panel has room for 20 fuses, 15 mini relays, a time delay relay, and my two solid state relays for water/meth and transbrake. Now I have new relays for the starter solenoid, the vanos solenoid, both stages of nitrous, and for reliability I split the main relay, injectors, ignition, and the cooling fans to have two relays each. The fuse holders are just cheap ones from amazon, but for reliability all the relays are OEM toyota relays. The fuse holders are also cheap amazon parts. They have LED indicators to show if a fuse is blown.
    I put it on the firewall just ahead of the MS3. Fuses and relays can be replaced by reaching through the glovebox. This location considerably cleaned up and shortened the wire harness. I also got the room back in the glovebox which will be nice. I made the loom going to it long enough to be able to pull the whole thing out between the cowl and the dash bar. The dash only takes maybe 15 minutes to pull should I need to rewire something.
    Also got a new set of wheel to put my slicks on. They are Bassett dirt track steelies in 15x12 with a 5" backspace. Tires are the same 28x10.5W MT's I had on the old 15x10 rims. I put my old MT 325/50-15 radials on the 10's for the street.
    Really like the look of the tires on the wider rims. It pulled the sidewalls out considerably and flattened out the tread face.
    I've been working on getting the two junkyard heads I picked up ready. Before cleaning them up I ported the intake side on both of them. One I did a pretty mild bowl blend and opened up the area going past the guide, and the other I removed the guide hump entirely and opened up the bowl as I did on my current head.
    After I got them pressure washed and started scrubbing off the carbon I found that one head had an exhaust seat that was pounded out at a weird angle. Turns out the valve from that cylinder was bent pretty badly and the previous owner just kept running it till it pounded the seat out to the same shape. Obviously that need to be fixed.
    I tig welded a washer to the OD of the seat and pulled it out. Luckily the seat register is still round so I just need to get another seat, press it in, and get it recut.
    Today I was cleaning up the other head and after removing the carbon I found an exhaust seat on that one that is pounded out as well. Notice the groove in the middle of the seat. This one will need to get fixed as well. I suspect this one is from a dead lifter letting the valve bounce on the seat for a long long time.
    In other news I got the last of the parts for the new short block I am putting together. ZRP I beam rods and the same wiseco pistons I have in the old motor. I actually got 7 pistons, one to replace the damaged one that's in the current motor from the bent rod.
    Also got this to put in at some point. Its a S476sx-e compressor cover and wheel to replace my current 72mm.
  23. #948
    Mar 2012
    Renton, Wa
    98 m3
    Very nice update man!
    1989 535i - sold
  24. #949
    FL
    are slow.
    Sticking with the M50 platform for now?
    -Dr. Seuss
  25. #950
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    Quote Originally Posted by Hova View Post
    Bucks : Bang
