- DME Self-test error? E36
Hey guys,
I'm running an EWS-deleted ECU in my E36 from a forum member on here. It ran fine for a few days (great, actually, better than ever). After a few days, the engine has started stalling entirely at random, regardless of any other conditions. Had BMW pull the codes to find a DME self-test error routine. Anyone know what this is or what I can do about it?
It means the checksum is not correct.
It's unlikely to be the cause of the stalling though, that could be an electrical issue, or maybe a crank sensor, especially if the rev needle kicks about when stalling.
Giftschrank Projekt
I thought about crankshaft position sensor, but it just.. dies. And then starts up after a few minutes, sometimes immediately. No weird RPM fluctuations, no fluttering, no hesitation just... bam. Dead.
Bump.. did two 30m drives and didn't have issues. Inspected my DME's pins and found no obvious problems other than some dusty leftover flux that I cleaned up. Not guaranteed fixed yet, but looking relatively good.
I would 1st change the crank sensor. Symptoms match 100% (excl the diag fault). The diag fault could be a feature of tampered box. And it is possible that DME runs self-diag occasially at some inverval (just quess)
Have a look at the MAF pipe too, tears in this are common to make the car stall or jump about when trying to drive.
Giftschrank Projekt
///M Power / 99 M3/2/5, VF V3
Hello guys i realize this thread is really old, but im also getting a DTC 100, self test and the car is cranking and fueling but not sparking.
My DME is stock and it has never been tampered with, issue started after car was sitting in the (Very humid) garage for 20 days. And a valve cover gasket job.
The DTC 100 is the only error showing on scanner and had never appeared in the past.
Car is a OBDII 323i
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
