So first things first. My vacuum lines that are all around the intake and come out of the valve cover ( i guess they are the PCV lines) are shot. does anyone know of a place to buy new molded hoses or what will work? This could be the problem to my hesitation issue that I get while driving.
So when i'm accelerating I get that "pushed back in your seat" feeling right up to about 3800 rpm once it hits there it stops accelerating hard and feels like there is a miss/lack of power and accelerates very slowly from here.
My thoughts are it is:
-the vacuum lines
-fuel filter
-fuel lines by the gas tank
-timing (even though I adjusted to spec and even advanced just a smidge [about 27 degrees before tdc at 2200 rpm])
Thanks for the Help Legion
Edit**** both fuel pumps are less than 2 years old. the accumulator is fairly new, I just did a lower and top end rebuild if i'm missing something I will answer the questions as you ask them.
bump! will rubber hoses from advance auto work? or will they collapse from the vacuum?
'83 320i in the works
Hoses
Autohausaz
11151272798 AAV(top) to CSV holder $3.08
11151272799 From Tee to air boot $10.12
11151272798 Valve cover to tee $2.67
From Pelican parts or local BMW dealer(price probably more, less wait)
11611267837 AAV(Bottom)to air boot $5.50
AAV - Air Axillary valve
CSV - Cold Start Valve
thanks
