Hi All, just joined this site and new to the BMW world. Recently purchased an '84 318i and love it so far.
Trying to troubleshoot non-working Air Conditioning. I know the system is charged and compressor is good because I can apply voltage directly and it kicks on and gets cold. Getting voltage out of the A/C power switch when pressed, but I don't know where to go from here. Any suggestions or know of a good troubleshooting chart for this. I'm assuming the compressor needs to cycle on and off so I can't just connect a toggle switch. Thanks! JP
I know the later cars like mine have a hi/lo pressure switch mounted on or near the receiver dryer. Make sure you have one if you are supposed to, and make sure it works.
Edit: you said M30 (the engine) -- did you mean E30 (the body style)? So is this a stock 318 (with the M10 engine), or did it used to be a 318 but is now a 334 or 335 (with an M30? Also, I'm sure the Bentley manual would have some electrical troubleshooting info for the AC system. If it is a swapped car you'll need to know a lot more about what is in there.
9/2004 Chevrolet Suburban Z71, black, purchased March 2016, 270k miles.
6/99 740i Cosmos Schwartz M Sport, 214k miles, purchased May 2017
2001 740i OrientBlau M Sport, purchased March 2023
1984 MasterCraft Stars and Stripes, Blue/White, PCM Ford 351W, PowerSlot, 912 hours, purchased September 2012 (not a car )
4/99 323is/5. Titansilber, 211k miles. Straight body project.
past BMWs: 5/1994 325isa (Arktisgrau), 3/1997 328is/5 (cosmosschwartz), 9/1990 535i/5 (calypsorot), 9/1990 318i/5 (brillantrot) 7/93 325i/5 convertible (samoablau) 2/92 325i/5 cabriolet (lagunengruen).
SÜNDE REISEN
Thanks strad. I did unplug that and jumped across the connections in the harness, but still nothing.
Oops, typo there. It's supposed to be E30, and yes it's a completely stock 318i
My e23 has an evaporator temp sensor to cycle the compressor on and off so the evaporator doesn't freeze. I assume the 318 has something similar. Make sure that is working. When the ac quit working in my e23, the evap temp sensor went out and wouldn't let the compressor turn on. It took me a while to track that sucker down lol.
Sent from my iPhone using BF.com
Thanks, I'll check that out. Is that the one located under the dash above the glove compartment?
Thanks for your help.
I did trace it down to the evaporator temperature switch.
Now to hunt down the part...
Check RealOem for it and order it at the dealer.
http://www.realoem.com/bmw/partgrp.d...02&hg=64&fg=55
