jake, I have some fittings that you may be interested in for your CCV set up. I will send you a text.
Garrett TiAL
Now we're talkin'!
By the way...for anyone who mentioned it I had a triple gauge pod on my a-pillar and it was a pain to look over as well as ricey and not to mention "hey cops please pull my ass over" and "oh you wanna jack my ride bro just follow me home and you will know where I live!"
You already look at the tach especially and the speedo. So there is no better place for AFR and boost or AFR and fuel pressure cause you be looking there anyway son.
Cool, I have a grinding wheel at my house so that shouldn't be a big deal. Thanks for the heads up though!
Not sure what TRM kit comes/does not come with here in terms of CCV? Maybe someone can chime in here, I'm going to ask Gary tomorrow if not.
I'm super excited to have my gauges there. Love the placement and boost and AFR are the two I'd like to be looking at the most. I'll do water/oil temp and oil pressure in the obc slot probably next year, for now I need to save the $$ for other areas.
A little off turbo topic, but super frustrated. Can't get a single bushing out on my rear suspension using hammers, pullers and a holesaw.
You talking rear sub frame bushings ? Torch the metal around the bushings then pound them out
Garrett TiAL
Exhaust ccv's and unicorns have something in common.
Sent from my GTX3582R
A little update from last night:
Tried using some heat to get the bushings out of my messed up subframe:
Proved ineffective, probably just going to pay someone to press in/out my bushings.... Feel so defeated by this car
Picked up some e30 seat belt receptacles for when I run my aftermarket seats (still undecided on what I want)
And I wasn't going to let my bushing failure stop me from getting more done:
Elongated holes/ground down my transmission brace to fit e21 mounts
New OEM pilot bearing/rear main seal
Put the f1 pilot/throwout bearing where it belongs
FINALLY got the right clutch plate from the f1 clutch people......... What a pointless hassle to get the right part. Defiantly paying a little more and getting southbend next time around
All installed and ready to go
Used UUC's recomendation for transmission fluid to help the gear rattle. 1 bottle of 75w140ns gear oil and then fill the rest with D4 atf and mix it around.
Transmission all sealed up and ready to go back in!
Glad to see you finally received the proper clutch... It took me 5 weeks to get the right one. Never again will I deal with Grip force I bought my f1 from a company in NJ called axidworks. Looking good btw
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
For all that hassle, I'd just rather go through a more reputable company next time. I had to threaten to call mastercard to even get anywhere with these people... I emailed and called multiple times for weeks when I found out they gave me the incorrect part, and when I finally got through to them they were claiming it had been past 30 days and they couldn't do anything for me.
At least I have the right part now!!!!
Been super backed up with school/work lately, but finally made some real progress tonight:
Picked up a set of corbeau seats
Put in a new steering wheel bearing/rally road gauge pod and wired up my AEM truboost/afr gauges
Prepped camber arms for welding
FINALLY pressed out my subframe bushings
Got a majority of my rear suspension bushings pressed in/cleaned up
Put the transmission back in, need to bleed the slave tomorrow
Hooked up my Bear SSK, zhp knob and alacantra boot
I'm really getting excited to go out and drive this thing, hopefully by next week I'll get my welding done and rear suspension in. Then I can begin the turbo/front suspension/oil pan and finish this thing up
Powertrain: Big Bore 87mm S50| Boost Logic Gen 2 Mani | BorgWarner S366 | CP 8.5:1 pistons | Eagle Rods | O-Ringed block | Tial 50mm | Precision 46mm | LINK G4 standalone | ZF| F1 stage 3 clutch/15lb ltwfw| UUC Black TM/E| Vorshlag MM's | 3.23LSD w/AKG race bushings| AKG race subframe bushings| 'Bear Motorsports' Re-enforced subframe | Walbro 525lp fp| VPD pulleys| 4'' DP into 3.5 straight pipe"||
Handling: FK konigsports| '95 M3 strut mounts| Rogue Engineering RSM's| UUC RTAB's| 20mm front spacers| 2915lbs Full interior
Aesthetics: M3 bumpers| 18''x 8.5/9.5 BBS LMs| ZKW's| 50w 6000k HID| Smoked Corners| 50% wndshld/5% all around| M3 sedan seats F&R| Black headliner| Black/Grey suede door panels| ZHP knob| M3 steering Wheel|
