Well, I figure its time to start a thread with my stage 2 kit shipping out from trm on friday !
My plan is to try and get it on the road by june but we'll see. My plans for this year are:
TRM Stage 2 kit: gt35r, .86 housing from stage 1 kit for faster spool, walbro fuel pump kit, .140 mls w/ arp's
M50 Manifold swap
Hyper Silver Apex 9.5x17 concave arc8's wrapped on 255/40/17 star spec's square
TC Kline 400/500 DA Coilovers
AKG 95A Bushings all around
DIY Oil Cooler Setup
Euro S50 Dual Pickup Oil Pan
AEM Truboost/AFR Setup
Euro Steering Wheel wrapped by tainik
Bear Motorsports SSK, Shifter Bushings, AKG DSSR, ZHP Knob
F1 Stage 3 Clutch Kit
Retrofitted Headlights
Anddddd lots of little parts along the way.
A little about me:
My car history starts with a 1994 318is that I brought from my cousin for a couple hundred bucks. It was in need of some serious love, and I brought it back from the dead:
After flipping that car and having a few years of work under my belt I bought a 1998 M3 and did a few suspension and na mods with it and started getting into autocross and tracking:
Build thread for that car is here: http://forums.bimmerforums.com/forum...-not-so-new-M3
After I had finished that car, I needed some money to pay for college, so I ended up selling it. But then I found a 2003 wrx that was wrecked on the passenger fender for sale. Put a new fender, wheel, ball joint and control arm on and it was good to go. Did a stage 2 tune with intake, intercooler and exhaust, some coilovers and sway bars and it was a total beast:
ANYWAYS, on to the new car... I had flipped the wrx and changed from going to a university and living in a fraternity (i ended up dropping out because it was nothing like I thought it would be) to moving back home with my parents for the time being and going to community college. I have some money freed up and I was looking for a new project, as the timing was perfect and my dad was more than eager to lend me a hand. I picked up my 180K hellrot m3 for a steal (5800) and started ripping it apart for this project the second it got home:
Looking forward for the next steps here, and you guys are welcome to follow me on instagram where I post a lot of pictures about the car too "jacobijackson" and #2013build is where I put all my car stuff.
I'll plug in my iphone in a bit here and upload the pictures I have and get this build thread going!!!
Let's try to keep this one right side up....
Nice looking build. Looking forward to more pic/updates.
Daily: E90 M3
Weekend: Viper GTS
Wifey's: 2011 Forester
As promised, a few pictures from the start of the build!
The dual pickup oil pan
Euro M3 steering wheel, planning on mounting it today with a new center steering wheel bearing and the gauge pod. Will update that with a picture when I finish.
180k shocks/mounts, vs my new DA TC Klines
Bought Technom's 3.5'' exhaust that flows to a dual tip vibrant muffler. Going to have to weld a 3'' to 3.5'' downpipe adapter to make it fit though. Beautiful piece, I think I'm going to sand the black paint off of the tips and try to make them somewhat metallic/shiny again
Painted my wood trim black while i wad bored waiting for parts, hoping it will last me until I bite the bullet and buy LTW trim
OEM Floormats that came on the car..... to be replaced with oem floormats.
Scrubbing the transmission down
Old clutch
F1 Clutch doesn't fit the flywheel plate.... now I have to wait for them to ship me the correct clutch plate........
How she sits now
So many boxes......
New Apex wheels!!!
Retrofitted headlights
My new license plate frame!
And my rear subframe mess. Hoping to get that and the clutch all back together before my kit shows up at my door.
I'll work on taking more/better pictures and make them bigger next time I upload, but that's all for now!
Win the lottery?
Looks like a great build,
Subscribed
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
I just did the same trm kit to my car the base tune I made 450 whp at 14 pounds of boost
You move quick!
1. I have a euro wheel on order as well.. Do I have to replace the bearing? If so part # please
2. Gauge pods on pillar or steering column? Debating it my self. Also can you please document how you run and setup your AEM guages. Have the same setup just havent gotten around to installing everything yet.
3. Did you win the lottery?
1. 32311158835 I believe, this diy should help you although its not the exact same wheel it should all be the same connectors/parts http://www.frankies-bmw.com/3series/...ring_wheel.php
You don't necessarily have to replace the bearing, but mine was shot so I thought it would be a good idea
2. http://www.europeanautosource.com/pr...36-3-series-m3 here's the piece I got, seems very well made and snaps in just like the stock top piece does. I just have them mounted to the pod, but when I get further into it and wire it all up I'll try to explain/take pictures for you
3. No, but if I ever want to move out I'm going to need to lol
I had the ATI and it was a pile. Gauges sit crooked, super cheap, and rattled. The rallyroad piece is insanely nice. Once I mounted to the column, the back of the pods hit the dash. It was a joke. nothing is better than having the TRM kit show up, and tearing every box open like christmas day. Once the blood pressure goes down, then you put it all back. Awesome.
I guess that comes down to personal preference? Having the boost gauge on the steering column on my wrx, I just knew I wanted something similar for my m. Sucks to hear about the ati pod. Maybe I'll be able to modify some of the pieces so they don't rattle? The rallyroad one was sold out when I tried to buy it.
The column is clean. Pillar gauges scream "steal me I'm a racecar". I would test fit the ati pod asap. That way if you don't like it you can return it. the rallyroad setup is not even comparable to the ati. What are you doing with your ccv? if you do the exhaust setup go with vibrant. I ran the Trm one and it didnt work.
also, keep in mind where you place your gauges. I put my AFR and boost down low and my oil/h20 up top. Now i wish my AFR and oil were up top. Hopefully you can make it to the Mary hill event this year. We'd have two turbo e36's. Yes.
1996 332IS
Built 3.2
Make sure they include EVERYTHING that is needed. They missed about 5 different parts they needed to ship me while I was in the middle of installing the kit.
98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
2017 Toyota Tundra Crewmaxx - Family Whip
2011 Pierce 75' Quint - Fire Apparatus West Islip FD
Not sure at all about the ccv setup yet, was going to look into it more when I was doing the install I guess? I believe the exhaust I bought was vibrant too.
I'm shipping them my ecu after receiving the kit, so if they miss anything they can ship it back with that.
Thanks man! I'll give you a ring if I get snagged.
A little update from today, I figured out how to take/upload better pictures, and my AKG bushings/reinforcements arrived!!!! Just waiting on my oem ones now.
Also, called the people I bought the ATI gauge pod from and I'm going to try and return it. I bought rally road's setup today
All the sun we've been getting in the PNW lately really wants me to finish this thing up already!!!
Just FYI. Unless AKG has changed their RTAB reinforcements, which it doesn't look like they have, be prepared to trim them up a bit to make them fit. The point part near the top of them in your picture is what needed to be ground down when I installed mine.
