Great looking swap, I'm definitely going to follow.
Which seller did those headers come from? I'm looking into headers for my swap and it seems to be a crap shoot depending on what seller it's from.
NICE BUILD
Its interesting to see how corrosive some Non BMW coolant can be on aluminum cylinder heads.
Noted!
Thanks Rob. Looks like all I need are the o2 sensors from steve and we are good to go
http://www.ebay.ca/itm/Stainlese-Ste...d=483311850086
All day! cheapest on the market, supersprint replica design and fitment looks to be spot on w/ better than expected welds!
Thanks!
NOTE #2
VAC does not have a Rod Bearing Install guide. Does anyone have any info as I cannot find any in the bentley manual
The people spoke and gave their recommendations, so I acted accordingly! All seemed to agree that the VAC rod bearings and ARP connector bolts were a must. After doing a ton of research and sending a million PM's, I agreed! I also read a bunch of pieces on the vanos bolts shearing and grenading the motor... better take care of that as well!
Vanos off and safely out of the way
See those 6 little guys on the wheels? Those are our culprits!
New ones in! Although the old bolts were in fine condition, It was nice to have the peace of mind of new materials w/ a little blue loctite for added protection of backing out
ARP bolts in! Everything was plasti-measured, tq's to spec and quadrouple checked! Only one of the bolts gave us an issue coming off.. Pretty smooth sailing
We mocked up the headers yesterday as well. We lucked out on one set, but the other is completely off and clocked in an odd fashion. Calling my fabricator today but I believe the plan is to heat that bad boy up and see if we can bang it out a bit. I'll get another photo of it before we fix the issue.
Ordering shims for the valve adjustment today! Install still on schedule for Friday! Ahhh!
Patrick
didn't take any photos of the bearing install, but obviously those made their way in as well.
The bearings seemed in spec for 62k with typical wear. Nothing dramatic, but again it's good to have fresh parts in problem areas. My mind will be at ease when I'm clocking 8500rpm on Road Atlanta
What is the typical break-in mileage for new bearings? Anyone know?
i was dreading every step of all of this...but it's actually going really smoothly so far. ::knockinonwood::
as much as i traditionaly hated anything DTM, im really enjoying working on this thing!!
o2 sensors arrived today along with the 3 shims I needed to complete the valve job and such. Picked up some BMW coolant while I was at the dealership. fluids, gaskets and filters are sitting at the shop to pick up on Friday.
Still on Schedule
There is no breakin on bearings. In theory the bearing should never touch the crank so nothing to wear in.
It's not speed that kills, it's the speed difference that does. Obviously you aren't going fast enough.
Turning Benjamins into noise since 1997
I read a list of the 100 things you MUST do before you die. Funny, "Yelling 'HELP'" didn't make the list!
The builder who did mine in the UK said to take it easy for the 1st 500 miles with revs below 4,000 then change oil. Even with varying opinions I did it anyway
for peace of mind just because I spent alot on the swap
I've heard several explanations and opinions. Trying to find some solidity on the bearing question.
Awesome. Nothing like some 10-60 TWS in and out in less that 500 miles LOL
Also the metal drain plug we spoke about,other than that excited to get the ball rolling.
M52 comes out tonight!!
Two and a half days of BMW nonsense filling up my entire garage. yaaaaay.
(dont tell anyone i said this, but I am kind of excited, lol.)
....and I'll make sure plynch takes lots of pics in the process! could be a reference if we document it well enough.
The VAC bearing option was the best IMO. I also checked with them ans they said 100% sure there's no break in period what so ever. I'll still take it easy but this makes things a bit more interesting. Clip is off and motor is out. Cleaning and prep for front akg subframe reinforcement finished as well.
Stay tuned! BIG moves today!
hey clean guy!
wheres piktars?!?
B.J. Walker
90 Miata Turbo stickmanBUILT
Splendid job. Make sure you let that oil warm up before going over 3k and that thing will be around for very long
This^^^ listen to gobuffs. I've learned a thing or two from him in the past. Hes one of the few mebers you should actually pay some attention too.
Id do this but like gobuffs mentioned above they aren't break-in/wear-in items so as soon as your oil is up to temp, in theory you should be good to go. However if it makes you feel at ease, take your time for the first 1k or first oil change...
If your clutch is new then break it in like you'd normally do. That should be enough time.
What a weekend! Motor is in and scheduled to hit the pavement tonight! I'll post more photos and info once we finish up.
www.mr5racing.com
2001 BMW 330ci 5MT (Sold) -- 2003.5 BMW M3 6MT (Sold) -- 2007 BMW 335i 6MT [441 whp 483 wtq (not stock)] (Sold) -- 1994 BMW 325i 5MT [202 whp 178 wtq (not stock)] -- 1999 BMW M3 5MT [263 whp 233 wtq) (not stock)]
It's been a couple of days. Any updates? Pictures? videos? I'm curious about the AC and the cruise control.
I'm currently at a crossroads with my S50 and considering the S54 swap but I want everything to function and not ready to give up cruise or AC.
Excellent Build and great work with keeping up with the updates. Can you come up with a total build price without labor as I'm looking at just about copying your build.
Ted Teten
1995 M3 Coupe - S52'd
Car is on all 4 wheels and drove around the lot for the first time today! Ill write a thorough update tomorrow complete with photos and info. Total build cost will be added at a later date as I need to chase down all my receipts.
Patrick
