So what do I need to throw in the s54 2002 z3 m coupe clutch? will that bolt up to the 5 speed and s54?
while using the m52 flywheel?
Yes.
Wanganstyle Powertrain
http://www.wanganstyle.com/
S54B32 E36 M3 DTA S100 Sedan Street car full swap:
http://forums.bimmerforums.com/forum....php?t=1437471
Can the s52 flywheel be resurfaced?
sorry to write here but still cant send you message since im new member. Ive done 2.8 stroker project and now im planing on putting m54b30 intake camshaft on my m50b25tu head, i saw you have exp with that, also red that you wrote somewhere you need lifters and trays from m54b30, somewhre you wrote you dont need lifters and trays, you can use stock ones from m50b25tu, just grind front of camshaft and thats it. Again sry for this in wrong topic, can you answer here also please, do i need trays and lifters from m54b30 also for this swap
^ -_____- Anyway, I just ordered AKG rcab pocket, front and rear subframe reinforcement plates. came out to be 149 bucks shipped. I just noticed I do not have a fan on my S54 pullout.... Can I reuse my m52 fan? - Patrick
Correction- I know the fan will screw on but can the whole assembly transfer? I'm not sure if those pieces were included. I will confirm this weekend.
This is turning into post spray, my apologies. I also cannot find the bottom end specs for installing the VAC rod bearings and connectors. I obv do not want to miss spec on those items.
Speak to VAC about assembly torque, if not I am sure B.J. can pull it up in Motor All Data.
Edit- Regarding the Oil pump nut on the S54, is it the same nut on the S52. Looking at purchasing the Rally Road OPN and unsure if they were the same part.
Double edit- Yes they are the same part number I guess rally road needs to expand their application chart.
I'll call VAC on Monday.
European Cluster with true 8k redline and oil gauge picked up. No dead spots!
More Packages! The ebay headers came in yesterday... boy am I impressed! Looks like all the bungs are there!
The welds look higher quality than I expected as well
all the flanges are nice and flush.. to my surprise with all the nasty ebay write-ups
I have NO CLUE what these metal circles are used for.. they look awful whatever they are
Here's our trusty VAC Rod Bearings
Rod Connectors ordered through VAC (11mm)
AKG Motor/Transmission Mounts... Beefy!
New Guibo was ordered today along with rear main, front main, valve cover and oil gaskets. All hardware has been ordered! Wiring Harness and DME will be shipped to Markert Motor Works for Performance Tune and Complete Plug and Play Harness and A/C Integration. !!!!!
The metal circles are gaskets.
Wrong gasket style for the collector end anyway
Trash for sure
hmmm. I have the oem triangular shaped gaskets for the headers from bmw.. do i need another set of gaskets??
I ment for the metal circles
Good Morning!
Rob and Dave are on pace to have my wiring harness, performance tune and A/C integration in my hands by next Thursday... which makes the build next weekend! AHH!
I had a question for the people-
I am trying to figure out what I need to allow the oil temp sensor to work on my European cluster. Can anyone help me out? The threads I found were not very clear.. hopefully you all can help me out.
Patrick
Never done it on the s54, but here it goes for a euro swap. You just need to find the oil temp sender line from the x20or??.
You need to cut the line from the gas mileage sensor from the connector that goes into the back of the cluster(x16). Connect the oil temp line to that empty line to the connector(x16). Then you have to take the connector apart and move it to the appropriate spot in the connector, #13 on the x16(I believe).
Thanks for the info!
I spoke with Dave this morning and he is including a plug and play with my harness when he mails it down.
Are you going to be able to easily keep cruise control?
99 M3
I just emailed Rob about the cruise control. I am not sure.
I forgot to pick up the primary s54 o2 sensors so those are on rush. all fluids and gaskets are in today as well.
We measured out the valves last night. a handful were a thousandth off. Those will be replaced as well. My morning coffee hasn't kicked in yet s oI apologize for the bland post haha.
Is the harness and tune going to be available to purchase?
Please send me a PM in regards to acquiring a harness and tune.
There will be cruise control on the final version of our product, but right now we are continuing testing on our development car to ensure nothing happens similar to that of Toyota (LOL).
Thanks everyone.
Way to go Patrick, it is looking nice!
NOTE: Do not use the exhaust gasket to the cyl head that came with those headers. Genuine BMW please
