Light pods will not go up. Headlights will come on, high beams will not come on, in down position. Checked #7 and #20 fuses they are ok. Replaced K39 relay...no joy. Wiggled all the wires...no joy. Pods worked on the SoCal 8's trip to Nethercutt museum and now they don't go up. Suggestions?
Get a cordless screwdriver with a long bit, and operate them manually!
Seriously though. I believe the headlight relay is a similar color to some others, yet they are not drop in replacements. Make sure you used the correct one.
'89 735i, '91 850i, '81 MB 380SLC (For Sale), Tesla Model 3, and VW Passat TDI -- Yes, I still repair General Modules, DM for info!
There are 3 green ones and 413 controls the concealed headlights. There are also a bunch of fuses that control the head and fog lights - at least in my early 850! 8-)
91 850 (Panzer), 2012 Mini Cooper Countryman (WifeMobile) www.wuffer.ca
I would start by checking if there is power at K39 (Pins 6 and 8) - and if OK there, check for voltage at the Fuses (7 and 20) when the lights are switched on.
My BMW Repair YouTube Channel
I checked the fuses and seem to have no power at the fuses. So far I have power at the K39 (installed a new relay) pods do not raise up, headlights will light up, high beams will not come on, high beams will not flash. Do you recommend I change the relays for k52 and k46? There is power at those locations. Could those relays have an effect on the pods? This is very frustrating.
Is there a control module that regulates everything for the headlights that might be causing this?
The LKM controls the lights but I'm not sure its that. I wondered about it but usually (I think) when the LKM goes wonky the lighting system does weird and inconsistent things. This is pretty specific - pods wont go up, no high beams, no flash...everything else works normally.
Did you check power to the motors? I'd start there and go backwards until you find some power.
Oxford Green Metallic, Parchment leather, 854 badge, EDC stock struts, M-Sport springs, 3.91 LSD, CSI rear sway, 18" M-Pars, M-Sport wheel w/flappy paddles, CD-43 head unit, Strong Strut brace, Euro FTPs, CSI rear defuser
Previous -
'70 2002
'92 525it e34 - Touring
'97 530i e39
'06 325xi e91 - Touring
Or jump them from the + battery terminal next to the heater valves.
The saga continues. All fuses ok. Pulled fuse, checked power to fuse #2 base (all headlights) - power ok. Installed new relays for concealing headlights (K39) and high beam flasher (K52), tested function - still don't work. Swapped K52 relay into K46 relay (same part number), tested function - don't work. When I turn on ignition switch; turn on headlight switch, pull headlight flash switch I do get the high beam indicator light, but no high beams. I cannot get a power reading on fuses #7 & #20, concealing headlight function. Low beam headlights will turn on, no power to high beams or flash circuit at connectors. At the headlight bulbs, I switched low beam connector to high beam light, energized switch and light bulb works. With ignition power on, headlight switch on, high beam lever (not flash) activated, VOM on connector to high beam circuit shows no power to this circuit. The low beam and high beam lights all work off the same ground, since the low beams work I'm assuming the ground is ok. Researching light switch diagram. I'm beginning to wonder if some part of the headlight switch has gone bad. I don't think it is the LKM. Wiring is like an archeological find...pretty brittle coatings, all exposed wiring now has tape (I need to buy an new harness, yuk). I need to find a common denominator that affects the high beam lights, high beam flash, and the concealing headlight operation.
Maybe you are having multiple issues. If it was just the switch and low beam getting power, shouldn't the pods pop?
That could be. I need to get to the pod motors to test them for power and operation. The high beams, flash and pods are the only things that are not working. I'm trying to run down one connection that answers all and so far the LKM is the only thing that seems to be it. I shall go after the pods tomorrow...'sounds like a sci fi thriller.
The LKM is the Lighting Control Box. It manages a large portion of how the lights work although that is a bit of a mystery at this point. Some other better informed reader can fill in with that info. Your winky problem sounds like you need to start with replacing the K39 relay. See info here: Attachment 455773 My problem is still no winky, no blinky.
'Just finished testing the power at the wiring harnesses. I energized the lights (low/high/flash/pods). So far there is power at all four pins at the headlight connector (see pics), there is no power at any pins at the concealing headlight pod connector. Does anyone know if the pods need to pop up in order for the high beams to activate? The high beams work (switched connector from low beam to high and they came on). If the high beam bulbs are good the pod issue could explain why I cannot activate the high beams if the pods will not come up. If this is the case then the issue is only the pods activation.
Attachment 455830
Attachment 455832
So far:
All fuses good
Power to all fuses
Replaced K52 and K39
Power to relay plates
Low beams operational
High beams not operational
Flash high beams will not activate
Pods will not activate
Any help is appreciated.
BTW - Would a battery reset help in this instance? This is a 1997 840Ci and I think that year does not benefit from a reset?
