How do u test the auzilery fan can anyone tell me how to test it wat wires go to wat if u hav to use jumper cables to the possitive terminal i mean i dont kno how to do this lol
Ideally you can just jumper the switch at the radiator. Its a thermal switch. If you jump the switch the fan should run.
How do i jump it
Just turn on the A/C
auzilery.... gonna have to use that one.
1992 525iT, Manual Swap, Bilstien Sport struts, H&R springs, Style 32 17" wheels (17x8 fronts, 17x9 rears), ACS exhaust, Euro cluster, Wilwood SL6R BBK on E38 rotors
But he could cheat and read post four though
OP, last week I came across some good info for methodically checking aux fan issues. My googler is pretty sweet though
One thing I'll say: if you're like me and don't really know what you're doing, at times google can be a bit panic inducing and/or dangerous..
buy a power probe, isolate the component from the circuit and actuate it manually
Unplug plug from sensor on side of radiator, there are three terminals, use paper clip to jump a terminal to ground, there will be a low and high speed.
The first and easiest check is for a seized motor, poke a tool through the grill and check if the fan blades turn. It ought to spin freely, if not it's junk. To check a motor that spins free connect ground to the brown wire and apply 12v to the blu/blk wire for the low speed. If it does not operate apply 12v to the solid blue wire, if it operates the motor is good and low speed resistor is open(bad).
