Page 4 of 20 FirstFirst 1234567891011121314 ... LastLast
Results 76 to 100 of 485
Thread: Mindy's Reincarnation
  1. #76
    May 2005
    Virginia
    1980 Firebird
    Quote Originally Posted by mcoupemindy View Post
    I'm going to start digging up some pictures for you, but I'll respond with text for now. Remember that the Z3 tank is a bit different than the E36 tank, so things will probably be a bit easier for you.
    I'll detail from pump head to return.
    For wiring, I truncated the factory positive voltage and used it as a trigger for dual 30A relays. I ran this back to my battery box where it hits both the relays and dumps to ground. This way, the factory prime function is kept the same.
    I took a factory fuel pump carrier and installed lugs (used bolts) through the top. Additionally, I cut off the factory feed and hot pressed two 1/2" NPT bungs in it. Those two are the fuel feed ports.
    The ground lug is going to the chassis with a 6AWG wire. It is important as this can carry up to 40 amps with dual pumps. From each of the relays in the rear, I have a 10AWG to a common lug on the carrier top. Inside the tank on the bottom of the lug, I used the supplied wiring harness with the pumps. Everything was then sealed up with E85 epoxy. I first tried o-rings, but even gasoline ate right through them in time.
    The pump carrier was modified to hold dual pumps that essentially are right next to each other. Each of them have a 5/16" submersible fuel line - must use minimum standard of 30R10 in the tank. I chose to use Gates 27093 due to this:
    Gates Submersible Fuel Line Hose is capable of handling gasoline, alcohol-extended gasoline, ethanols, biodiesel or diesel fuel in fully-immersed, mobile and stationary applications.
    Now, one thing to remember, and I found this out the hard way, is that submersible line does not like bends. I actually had one rupture because I asked too much of it. If you need to make bends in the tank, use fittings instead. Shouldn't be a problem for E36 guys.
    Then it goes through the bulkhead fittings that I hot pressed and epoxied.
    Over the tank, I ran 2x 5/16" Goodyear 65152 SAE 30R9 Fuel Injection Hose. I originally made hard aluminium lines to do this, but was unhappy once I saw how it rubbed on the body. My opinion is soft might be better. Don't even think about using anything braided around the tank as it will eat the tank through.
    The 2x 5/16" soft lines merge under the car using a y-block into a single aluminum -10 (5/8") line. I bought all the flare tools, etc. to do it. I like using flare nuts and collars - simple and I can make them easily. From there it runs up to the stock fuel filter location into a Aeromotive 12335 40 Micron ORB-10 Red Fuel Filter. Off the top of my head, I can't remember the fitting, but think it's a -10AN to -10 o-ring. It is secured up using the factory hanger and a pipe repair sleeve from home depot to make it the same OD as the factory filter. Pretty slick.
    Out of the fuel filter, I come off with a PTFE -10 hose up to the front of my fuel rail. Yes, I feed front to back. It has a 90 degree end fitting and goes into my Rally Road rail with an AN-10 to O-ring -8 connector. Due to space limitations, I have to run a VERY tight 90 degree fitting off the rear. This is the reason I feel from the front - always want to keep restrictions on the return. I run a -10 braided line covered in heat shrink tubing (it's close to the starter, and yeah, not taking any chances) to the fuel pressure regulator - an aeromotive A1000. It's important to buy the gauge to go along with it too as you'll need to tune your fuel pressure to the 3.5 bar.
    From the FPR, I run an aluminum line back to the rear of the car and that merges with another piece of goodyear hose that runs to the return in the tank.
    The fuel sensor arm needed to be modified. The drawback is that I really don't have an accurate gauge - especially true since the gauge from the factory isn't accurate either. Pretty much, as soon as the gauge starts moving off full, it's time to get fuel. I only have a 12.9 gallon tank, and since fuel is essentially fuel pump coolant, you never want to really run it very low. The half tank gauge is 5 gallons left until absolute starve.
    Some things to note - if you use epoxy in the tank, you must use E85 compatible epoxy. There is only one supplier in the US that can make it, and it is VERY, VERY, VERY expensive. Normal epoxy will not hold up to E85.
    Dual pumps use a stupid amount of power when they are at full pressure. Do not EVER undersize wiring. Not only do you risk voltage drop, but you risk hot wires and melting things.
    I can control fuel pressure down to 36 psi - nothing lower as the dual aeromotives flow a stupid amount. It doesn't bother me as I run a 51psi (3.5bar) normal pressure that only drops to 42psi under the hardest vacuum.
    I bought most of my crap off amazon as it's easy to buy from and easy to return if you don't like it.
    I do want to make some changes to it when I have the time. For example, I DO NOT like the aluminum tubing and will be switching out for stainless steel. I also want to get a nicer y-block for the rear as the one I have makes the connections at a wonky angle.
    I hope I covered it, if you need any additional detail, please let me know.
    Thanks. You too will have a very nice car here shortly.
    We need to get together sometime. Bummer that you can't come over on Sat.
    BTW to anyone interested, if you are local and want to come over on Saturday and shoot the shit, I'm holding my annual Z3 fix it day. All are welcome - details available here:
    http://forums.bimmerforums.com/forum...ad.php?1937241
    If I wasn't doing the Tough Mudder I would definitely come on over. The numbers you're making are incredible! I love that Katie chimed in and said you aren't allowed to sell Mindy! That's when you know you married the right girl ahahaha!
    I'm curious what you will trap in the 1/4? My guess is you would have to be in the 140's easily right?
    “If the representatives of the people betray their constituents, there is then no resource left but in the exertion of that original right of self-defense which is paramount to all positive forms of government, and which against the usurpations of the national rulers may be exerted with infinitely better prospect of success than against those of the rulers of an individual State. In a single State, if the persons intrusted with supreme power become usurpers, the different parcels, subdivisions, or districts of which it consists, having no distinct government in each, can take no regular measures for defense. The citizens must rush tumultuously to arms, without concert, without system, without resource; except in their courage and despair.” – Alexander Hamilton, Federalist No. 28
  2. #77
    mcoupemindy's Avatar
    mcoupemindy is offline Senior Member BMW CCA Member
    Supporting Vendor
    Jan 2005
    Haymarket, VA
    '99 M Coupe
    Quote Originally Posted by MMR View Post
    Awesome car and congrats to all involved. Are you running RL and if not how's the traction? Thanks.
    I didn't appropriately answer your question the first time around - sorry about that.
    RL not installed yet as I wasn't about to modify my harness before it was fully tuned.
    I currently run 315/30/17's Toyo 888's on the rear. At the 150KPA boost setting, I get a bit of slip in 2nd and full hook in 3rd.
  3. #78
    Nov 2012
    San Mateo,CA
    1995 325is
    Awesome ///Monster lol. Looks like a blast to drive
  4. #79
    Sep 2001
    NJ
    99 M coupe
    Not sure if I misses this info along the way. Is there an ethanol sensor incorporated into the build/tune?
  5. #80
    Joliet, IL
    Out of Service
    Quote Originally Posted by rukman View Post
    Nope
  6. #81
    Apr 2009
    norcal
    a few e30s
    Quote Originally Posted by cragg56 View Post
    Nope
    Is that going to be safe with how e85 fluctuates in percentage of ethanol?
  7. #82
    baltimore,md
    97 m3
    Quote Originally Posted by dohcdoh View Post
    According to Jordan, he has tuned it accordingly just incase that happens. The kid may be young but he is very intelligent.
  8. #83
    Apr 2009
    norcal
    a few e30s
    Quote Originally Posted by 97mreaper View Post
    How? With no ethanol sensor, I'm not understanding how he does it. Or is that proprietary super top secret info?
  9. #84
    Jun 2006
    Provo, Utah
    GT40R Turbo M Coupe, 71 Datsun VG30 510 "AKASmurf"
    According to Jordan, he has tuned it accordingly just in case that happens. The kid may be young but he is very intelligent.
    That may be a bit naive. If there isn't a ethanol analyzer in the fuel system, I don't know how Jordan could possibly tune for that case. If Jordan is relying upon the knock sensor to figure and sort out a problem, that may prove to be a problem with that is bypassed for the race logic (I am not 100% sure on that detail with obd2).
    With the extreme difference in BTU's, things will really lean out if tuned for a true e70, and you find a pump that pumps e85 or 90 on accident. Many cars have lost motors because of this. When Flexer tuned my flex fuel setup, every time we diluted the 91 octane more and more, and thus increased the content of ethanol, it needed to be dialed in more. It is a linear multiplier for the gradation of e85/e0. But that multiplier had was tuned, and dialed in. Flexer and I discussed this together, and he said there are a few tests you can do on the e85, or I imagine you could install a content analyzer in the fuel system. ($100 for a used GM sensor, and $200 for a anaylizer).
    With all you have invested, it would seem very important to monitor the ethanol content of the fuel entering into your motor Jon. If you think about it, there isn't a single OEM dedicated Non Flex Fuel E85 car out there. That being the case, gas stations know they can dilute the e85 how ever they want. What was interesting in talking to Flexer a ton about ethanol, is that there is a ton of knock suppression that happens once you reach around e50, then above that, there is very little gain until you reach very high percentages of ethanol.
    Jordan is sharp kid. He is really on to something here. If he figures out how to do a flex fuel setup through stock DME tuning, he will have achieved greatness. My opinion on it is that its impossible. EVO's aren't able to do it on their stock ecu's and there is a massive market for it and all kinds of crazy hacks have introduced amazing tuning features for the stock evo ecu.
    Currently, the only way that Jon can change over to the Ethanol tune is to swap in a different ecu. I love the idea of stock DME tuning. But I'll stick with my AEM 1050 box for now. When true flex fuel is achieved, it will be a home run. I don't know if I would bother with ethanol unless it was on a flex basis. I would just assume spend the big money for race gas and call it a day. Too much risk in my opinion to not know what fuel you are working with, especially when that fuel's BTU content is drastically different.
    1999 M coupe, Black/Kyalami Orange, Sunroof Delete; GT4088R turbo, 610 WHP @ 22PSI Pump Gas; 2.79 Gearing; TCK D/A's; Forgelines 19x9 et38 w/265 30's; 19x11.5 et19 w/305 30's. Brembo GT Brakes; Race Logic Traction Control.
    1971 Datsun 510: High Compression VG34e, CAI,Fuji Blue, GC C/O's; system, Penultimate Rear Crossmember R160 lsd 3.70, cv axels; CCW LM16's 16 x 7.5/8.5 w/215 40 and 245 35 T1R's.
  10. #85
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    jordan ran e85 and other terrible mixtures of e60 e70 and the like in his yellow car, the experience that he has had with it may have played roll, but I imagine if he tuned it on the rich side and backed a bit off the timing it would be fine.
  11. #86
    Bellingham, WA
    e30
    Its not that hard to tune the ECU for "E85" winter and summer blends. You tune for the worst case scenario in timing and fuel maps. Studies show the map values dont really need to change that much between the various blends available branded as E85. Also keep in mind how much more tolerant E85 is compared to petrol! The tune wont be gnats nuts for say E70 and E85, but it will still operate just fine even though you are not completely optimised at either end of the spectrum. You are still making WAY more power than you would with petrol even if you are leaving a few % on the table to be safe.
    If he decides to start making random mixes of ethanol and petrol, thats where he will be in trouble. The OP does not seem like an idiot by any stretch so I am sure he is well aware of his setup limitations.
    There is nothing ground breaking or crazy about this method. No need to get tricky when what is available works just fine.
    -Nick
    91 E30 M42 on VEMS
    Turbo Camshaft Thread
  12. #87
    Jun 2006
    Provo, Utah
    Quote Originally Posted by E36 HateR View Post
    If I was the owner, I would want to know the risks, and how/if they are avoided. If for only $300 you could keep tabs on what would cost a ton of time and money in damage, I would not hesitate to monitor the ethanol. I doubt that Jordan would say that he found that there was an acceptable way to run one tune on e60-e85. Its not a timing thing, its a fueling thing. If you are dialed in on e60, and then you get a batch of e85, your driving a time bomb. Imagine pulling out 20% of your fuel on a race gas map. I don't care what the timing is, its going to go kaboom. Other communities have experienced this with Ethanol fuels and running dedicated ethanol tunes. The OEM's figured out a solution to the problem of fueling and dealing with the drastic difference in bTU contents. FLEXing of the fueling. Having to run your tank to zero is also a pain in the butt to switch fuels.
  13. #88
    Sep 2001
    NJ
    99 M coupe
    Quote Originally Posted by jonesmechanical View Post
    Racelogic requires misfire detection to be disabled. Knock detection is retained.
  14. #89
    Bellingham, WA
    e30
    You could always run this: http://www.zeitronix.com/Products/ECA/ECA.shtml to verify ethanol content is within the acceptable range.
    I also think you are really overcomplicating the fueling difference between winter and summer ethanol blends. Its also fairly easy to test the ethanol content with a hand held tester to verify its within limits.
    If you are fueling for ~E85 and you get a tank of E70 you think the engine will have serious problems? Really???
    -Nick
    91 E30 M42 on VEMS
  15. #90
    Nov 2005
    Linden, NJ
    F80, E36, X3"M"
    Nothing is impossible. Nick already has switchable maps in my e46 m3, and the flex fuel coding and sensor is already implemented and ready for testing.
    97 M3 - 8.94@164 - 8 sec street machine, all BMW driveline, factory ECU
    02 M3 - 9.74@145 - Maximum PSI stage 2 turbo kit, stock motor, factory ECU
    16 M3 - 9.3@151 - Built motor/twins
    15 M3 - 9.2@162 - Built motor/single turbo/Ecutek
    BMW SOB's turbo E30 - 8.72@158.39
    follow our latest builds and upcoming events! - facebook.com/maximumpsi - instagram.com/maximumpsi
  16. #91
    Louisville, KY
    turbo m3
    Quote Originally Posted by mike radowski View Post
    Truth; which many said would not happen.
    This is my signature....
  17. #92
    Sep 2001
    NJ
    99 M coupe
    I think jones may have been referring to e36 platform. Then again maybe nick can tell us of its possible (even if he may not be willing to put the time in to make it happen)
    I have no interest in e85 at this point but the prospect of switchable maps with flex sensor would get me interested. Lol
  18. #93
    Jun 2006
    Provo, Utah
    Mike, I knew that you were working on it, but had no idea how Nick was doing this. Obviously, with the way Nick is approaching the ethanol fuel challenge (utilizing a single DME with an analyzer), and how Jordan is approaching it (with separate swappable DME's with no ethanol monitoring) shows a lot in where they are at as far as tuners. I couldn't even comment on how the obd2 DME's differ between the s52 M coupe and the s54 e46M3 and the challenges of each. Maybe the s54 M3 ecu has more options to allow for switching. If Nick is taking the approach of utilizing a content analyzer for e85 tuning, then he is much further along than Jordan is on this subject. I wouldn't touch a ethanol tune without one.
    Ahh. Thanks for the correction/clarification Rukman, I didn't know.
    Quote Originally Posted by wazzu70 View Post
    Yes, for $100 you can have a used gm flex fuel sensor, and for $200 you have that. $300 you have accurate monitoring. Now, what to do with the output of the ziet unit, well thats for Nick and Jordan to figure out. Flexer figured out that the AEM EMS will take its output nicely and allow for fueling modulating.
    And yes, since E85 has 33% less energy content than regular gas, you have to flow that much more fuel to maintain a correct or comparable AFR to what you have tuned for Gasoline. In the example of the e85 vs e70 example, it would be the equivalent of pulling 4-5% fueling out of your tune everywhere. Is that a big deal???
  19. #94
    Bellingham, WA
    e30
    If you are that worried about making fuel trims to fully optimise your fueling, they have boxes that will increase injector pulse width with increased detected ethanol comtent.
    I think you are too focused on completely optimising the tune, which is not what is going on with the method I assume Jordan is using (although maybe he will chime in and correct me).
    You are completely missing the point of what I am saying.....What happens if no fuel is removed for E70 if the fueling is mapped for E85? Your engine runs a bit rich. Does it really matter? Does it kill your performance? Is there any real consequense besides consuming a little more fuel?
    -Nick
    91 E30 M42 on VEMS
  20. #95
    Supporting Vendor
    Jan 2005
    Haymarket, VA
    '99 M Coupe
    Quote Originally Posted by Mscire2 View Post
    Someone needs to update their sig... 511wtq is cute now.
    I'm trying to figure out a sig that shows the comparison of 3x the S54 torque to 1x the S52 torque :P I love you bro.
    Congrats! Now put some miles on her and enjoy it
    Thanks again Ruk. Right now it's just sitting all ripped apart in the garage waiting for the cams to come out again. I'm going back in to make sure the headstuds are still properly tight after tuning. I'd much rather waste 4 or 5 hours now to ensure the headgasket doesn't leak.
    Quote Originally Posted by ar design View Post
    715 ft-lbs?! WOW!
    Quite honestly, I was expecting we'd get to 700/600. Never to the level of torque we saw.
    Yes, I think this has to be a record for a T3 manifold/turbo on a BMW I6 regardless of displacement.
    I can care less about records, etc.
    If you want to talk about records, here are a few:
    This may be the most powerful M Coupe running a pump fuel (I think George is running race only these days);
    This may be the highest powered MS41.1 Stock DME Car;
    This may be the highest torque and furthest pushed SPA T3 setup.
    I am clearly saying "may be" for a reason. There's no way to verify any of that.
    Instead of going for a record, I'm just trying to be happy with what I built. That's the most important thing.
    Quote Originally Posted by RVAE34 View Post
    This is madness. I bet it's just plain silly to drive.
    Yes - but your car will also be madness.
    Quote Originally Posted by EMC View Post
    My mind is made up...E85 will be on the RK Multi-Tune
    Yes, that is a smart choice. I am very glad that I chose to go see Jordan. Hopefully we can get him enough business so he can afford a phone that doesn't drop calls all the time (I hope you read this buddy!).
  21. #96
    N.Y.
    07 335i
    +1 on Ruckman mentioning the misfire dection needs to be turned off not the knock control.
    Jonathan's ecu is already set that way. Knock control is still on.
    E85 (e85-70) is a lot less prone to rich misfire then gasoline.
    He was tuned on true summer blend e85 so if he ends up with a rating more towards the e68 range his car will be slightly richer. Also his ignition timing is backed down quite a few degrees off of a aggressive e85 tune so no worries of det with various fuels.
    A true flex fuel option is very nice to have but other dme tuners have been using these methods for a while and if done correctly their will be zero issues.
    Also if he is crossing from e85 to 93 and his tank is almost empty he can swich over to the 93 map and give the car a few min to adjust short term fuel trims and be off! No getting into boost intill the second round of filling up gas.
    With the multune dme being shipped out tomorow or Thursday their will be
    1 tune for 93 octane and 115lb injectors.
    1 tune for e85 and 115lb injectors (will run slightly richer with e70)
    1 valet mode.
    1 slot still open.
    =( I love my huge Galaxy Note 2. I do hate that I get a ton of dropped and missed calls though =(. Im on my fourth one
    RK tunes
  22. #97
    Joliet, IL
    Out of Service
    Quote Originally Posted by RK-Tunes View Post
    1 valet mode.
    1 slot still open.
    PM me some pricing on this kit please and thank you.
  23. #98
    Nov 2005
    Linden, NJ
    F80, E36, X3"M"
    How is the idle on 93 with the large injectors?
  24. #99
    NY
    skateboard
    A little off topic here, but Happy Birthday Jordan .
    Hi 5
    ― George Orwell
  25. #100
    Jun 2006
    Provo, Utah
    You speak like JR figured out some magic way for AEM to adjust fueling for ethanol. Its just a basic function in the ECU. Plug in the sensor and turn on the function. Nothing to figure out....its built in.
    If it was only that simple, once one has already figured it out. JR has a long standing relationship with engineers at AEM. He is always coming up with crazy ideas, and even tests new products for them. There was multiple people at AEM that said it wasn't possible to do a flex fuel setup on their EMS. This was at the time that PRO EFI was one of the first to really push the whole flex fuel thing. The second the Zeit unit came on the market, JR asked Zeit if they developed it for something like the AEM, and they said no, but it would may work. I haven't seen anyone else anywhere run this simple flex fuel setup on AEM EMS units. It seems very simple, but he on his own figured it out, and it works marvelously. There may be countless others that have done the same, and its a great idea, we just haven't seen any of them.
    Also if he is crossing from e85 to 93 and his tank is almost empty he can swich over to the 93 map and give the car a few min to adjust short term fuel trims and be off! No getting into boost till the second round of filling up gas.
    1 valet mode.
    1 slot still open.
    Nice Jordan, so this whole swapping ECU's that Jon is doing right now is just until this multi tune ecu makes it to him? Very nice.
