Putting an aftermarket radio into your E38? This might help. This info was taken from a 2000 E38 which originally had the 4:3 nav radio.
Ground = Brown
Yellow +12V constant = Red w/ green stripe
Red +12V switched = Purple w/ red stripe
Dimmer = Gray w/ red stripe
For steering wheels controls you will need a PAC SWI module. You will connect the pink wire from the module to the white w/ yellow dots wire from the car.
For FM antenna, you will need a Metra 40-VW10 adapter and either a 12' antenna extender Metra 44-EC144 or 17' antenna extender 44-EC204. You will run the the antenna extender from your radio into the trunk. In the drivers side corner of the trunk where the OEM equipment sits you will find the gray antenna cable w/ euro connector. Use the 40-VW10 and connect it between the factory cable and the Metra extender.
AWESOME .. but too late I all ready did my aftermarket radio
El Cid 1999 ILDUDMD Tune/DINAN CAI/19 in Style 95 Rims/Bilstein's Shocks/Eibach Lowering Springs/OEM Folding Mirrors/Custom Cupholder/Custom Wood Sunshade/Sport Steering Wheel/Euro Center Console/Leather Shifter/Rearview Camera /Luke Custom 10 in Sub Box/Cross Drilled Rotors/Rear view Camera/BMW OEM Monitors/BMW E38 Picnic Tables/Vanity Headrests/OEM Roof Rack/Strut Bar/Dinan MAF and Dinan Throttle Body and Dinan tunning /BM53 Radio upgrade /Custom Innovadrive NXG39 modify and Alpine ILX-W650 touch screen radio.
well, this will help me! THANKS!
any idea what the plug type is on the end of the Metra 40-VW10 lead that goes into the factory bmw antenna amp box is called?
As the leads dont seem to exsit in the UK, and would be easier and cheeper to make my own up.
cheers
I'm learning thanks for the info.............
no worries, no one seems to know, got a bit of time yet to try and sourse one , if not ill import a metra cable
Its in the main plug behind the radio. I had to splice into it. The antenna info is super helpful, I was wondering why mine didnt work.
Also, I used the axxcess steering wheel module, its much faster than the pac sw1.
Sent from my SPH-L900 using Tapatalk 2
So you only plug in one wire from the module? Aka pink one?
