Hi looking for some help if possible , my 1996 e36 328 is very unstable when driving on uneven roads or over drain covers it feels like the rear end side kicks is the only way I can explain it . It has just today passed its MOT so I can't see it being a bush or stabiliser problem all tires are good so any help would be appreciated thanks
Shocks and struts or rear trailing arm bushings.
Rear bushings trailing arms most likely.
OR do you have wider tires on the back?
If not it is definitely shot bushings
mine would hop around corners. Replaced the shocks and struts and problem solved.
Mine did that until I got new shocks and struts
I had a similar problem where the back end of the car would change direction over bumps, manhole covers, cracks in the road etc.. while at speed
turns out both my rear lower control arms were bent because the car had been towed at one point and they had placed hooks on the arms which are just thin sheet metal and bend easily. Definately check the Rtabs and your shocks, and then the lower control arms to see if they are slightly bent at all
It clearly sounds like a bad rear end alignment. Running 255/40/16 rears I had the same problem. The toe and camber were off. Eventually replaced the RTAB's.
S52, AA C38-81 stage 2 aftercooled supercharger (14 PSI), Meth injection, Gatorback belts, Provent 200 oil separator, ARP studs, VAC MLS head gasket, SAP delete, ASC delete, TB heating delete, CCV delete, post cat O2 sensors delete, vanos mechanical jam delete, M50 intake mani, Mishimoto radiator, 155f thermostat, Stewart pump, euro diesal fan, CES overflow tank, AEM digital gauges, Bavarian coils, BMP tuned headers, Magnaflow true duals exhaust, E60 530i ZF manual 6 speed, UUC EVO 3 shifter, stage 2 E46 UUC clutch with Fidanza FW, M3 front brakes/spindles, E46 328i rear brakes, adjustable rear camber arms, adjustable camber plates on Yellow DPS coil-overs, M3 crossbrace, Staggered 255/45Z and 235/40Z BF Goodrich G-Force Sport 2's on 17's, 3.91 LSD, MM aluminum underpanel, Z3 steering rack, UUC sways.
Would check the alignment and the rear shocks/ springs.
Sent from my iPhone using BF.c
*rear shocks are bad, or going bad
& just in case check that your front sway bar links are not bent,
