Page 7 of 12 FirstFirst 123456789101112 LastLast
Results 151 to 175 of 276
Thread: EWS sync without installing EDIABAS/INPA/DIS using a $10 vagcom cable
  1. #151
    Aug 2014
    kentucky
    '98 Z3 M Roadster
    Would this program work on a Z3 (which is an E36) with MS41.1 & EWS 3D?
  2. #152
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by bubbafett View Post
    I believe so.
    S54 swap DME flashing - $100
    S54 swap CAN interface board (for proper A/C & check engine light) - $275
    e36 SAP sim/secondary air pump simulator:
    $75 - standard or $170 - plug & play
    e36 post-cat O2 sims: $115 shipped, plug & play
  3. #153
    Dec 2014
    Worked great on my 1997 328is with a DME bought on eBay. Many thanks.
  4. #154
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by bduff51 View Post
    Nice, good to hear!
  5. #155
    May 2003
    quebec
    |99 Turbo M3 | 2K7 335|
    question: I have a turbo E36, bought a stage 3 ECU for 60# injectors and GT35R. can I use this tool or it might erase the custom tune ?
    thanks ! this tool look awesome !
    _____________________________
  6. #156
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by gnarfy View Post
    It won't touch your tune. EWS sync reads the ISN from the DME and writes it to your EWS.
  7. #157
    May 2003
    quebec
    wohoo ! thanks alot !
  8. #158
    Feb 2012
    Lancaster Ohio
    1998 BMW M3/4/5
    Just used this on my 98 m3. Bought a supercharger kit and got an ecu without the ews deleted. Was about to give up and send the ecu to trm, used this and saved my life. Thanks!!!!!!!!!!!!
  9. #159
    May 2003
    quebec
    tried on the new TT stage 3 ecu on my 99 M3 and got a unsuccessful message.. it did read the code correctly, but can't write..
    2015-06-28 19:06:23 DME ISN: 12 2e a0 31 34 30 36 34 36 34 31 36 30 31 31 30 32 31 30 34 39 38 30 30 30 30 31 31 35 38 35 32 31 32 30 32 39 38 30 34 32 33 32 35 38
    the same k-can cable work with INPA on my 99 M3... any idea ? I can't try to start the car right now as there is no oil/coolant in the car..
  10. #160
    Aug 2014
    United States
    Estoril M3/4/5
    Just want to confirm that these are the 2 items we need to make this work:
    http://www.ebay.com/itm/KKL-VAG-COM-...mtr&rmvSB=true
    http://www.ebay.com/itm/20-Pin-To-OB...272624&vxp=mtr
  11. #161
    May 2003
    quebec
    oh, I tried with the OBD port. I do have the round adapter, I'll try with it..
  12. #162
    Jul 2004
    Houston, TX
    36 Cylinders
    You have to use the 20pin port to reach EWS.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  13. #163
    May 2003
    quebec
    It worked ! thanks alot !
  14. #164
    May 2003
    quebec
    do you take paypal donation, I need to give you something for that beautiful piece of software ;-) My TT stage 3 M3 is faster then ever !!!
  15. #165
    Apr 2015
    Halifax, NS, Canada
    98 E39 528i, 05 E60 545i
    Can you confirm if it will work for a 98 e39. Need to align EWS and DME. Also can you confirm the other posters question about the correct cable and and 20pin adapter? There are so many out there to choose. Also some said the 20 adapter are not all the same due to an ignition pin...? Also is Vagcom cable the same as a BMW ODBII cable the BMW ones are like $50 so what is the difference?
    1998 E39-528i, 2005 E60-545i
  16. #166
    Northern CA
    1998 M3/4/5
    Never thought about it, but sure! Don't want to post email here and get spam, please PM if you are interested.
    Quote Originally Posted by Jayson Wonder View Post
    E39 528 or 540? Should work on a 528, not sure about 540. I'd get any cheap vagcom cable & 20 pin adapter then correct the adapter pinouts if necessary.
  17. #167
    Apr 2015
    Halifax, NS, Canada
    It is a 1998 528i. What exactly needs to be modified on the cable? Will this modified cable work with other software too like INPA, DIS, etc.? I know I need the 20pin adapter also but are these all created equal? I read about battery and ignition reading etc. Just wondered if Vagcom has an impact on this. I am anxious to order a cable but wanna get the correct one.
  18. #168
    Jul 2004
    Houston, TX
    36 Cylinders
    If it is the single vanos 2.8 in that 528, then I would purchase these:
    www.ebay.com/itm/291494545441 quality VAG KKL cable with quality FTDI chip or http://www.ebay.com/itm/271928532534 (another seller)
    and
    www.ebay.com/itm/111222866460 20-pin adapter
    These ftdi chip cables will be very good for diagnosing as well for EWS sync, programming, coding... for any car 2006 and older.
    Do not buy the cable with the CH340 chip, even if it is cheaper.
    -Abel
  19. #169
    Apr 2015
    Halifax, NS, Canada
    Wow this is really helpful. Now you mentioned I may have to modify the cable once it arrives... Would you be kind enough to elaborate?
  20. #170
    Jul 2004
    Houston, TX
    36 Cylinders
    Look through here http://www.bimmerforums.com/forum/sh...xperimentation for all the modification info, drivers, and how to use with INPA. Applies equally to Z3 and your car as well.
    -Abel
  21. #171
    Apr 2015
    Halifax, NS, Canada
    Awesome, so before I order, can you tell me if there is something different or better with this one other than price much higher?
    http://www.ebay.ca/itm/281128248013?...%3AMEBIDX%3AIT
    Thanks,
  22. #172
    Jul 2004
    Houston, TX
    36 Cylinders
    Well, I cannot fully answer that because I have never used that cable, nor would I spend the money on it.
    The FT232BL chip cables work differently. This one might even have a genuine FTDI chip... or maybe it's just another Chinese replica making big money for someone.
    Why I chose to recommend the above:
    The kind of cable I linked you has been my go to for diagnosing (INPA and ISTA, a little bit of DIS), EWS Sync with this thread's program, MS41 ecu flashing and tuning, coding, and programming since around 2010 when I bought it, for all BMWs older than 2007. That includes a few cars older than 1996, a Euro E36 323i I used to own, and a bunch of other cars I help people with.
    It's simply what worked for me, it has done everything I tried to do with it.
    I would love to experiment with the BL cable, but I have too many other cables in my collection... K+DCAN, RossTech's VCDS Hex+Can, VAGCOM clone with CH340, TinyADS, a few programmers, MPPS v13, Galletto, Carsoft, and a few generic OBD2 ELM cables I first experimented with a long time ago.
    Oh my,.... I seem to have a problem
    -Abel
  23. #173
    Apr 2015
    Halifax, NS, Canada
    I'm sold..... What is the problem dude?
  24. #174
    Jul 2004
    Houston, TX
    36 Cylinders
    Constantly wanting to buy more diagnostic cables/ things to tweak. For instance, now I want to get a VW/Audi ODIS interface. I'm not in automotive or computer career at all, but I love tinkering. Also I cannot trust most mechanics, so I try to learn it myself.
    But the "I have a problem" was a little tongue-in-cheek because I really enjoy car diagnostics and repair, but as a hobby.
    -Abel
  25. #175
    Apr 2015
    Halifax, NS, Canada
    Totally get you. I am that way with audio recording gear. I am so anxious to get this cable now
