Page 5 of 12 FirstFirst 123456789101112 LastLast
Results 101 to 125 of 276
Thread: EWS sync without installing EDIABAS/INPA/DIS using a $10 vagcom cable
  1. #101
    Texas
    e70, e46
    ebay (vagcom and ads cable = $16 shipped)
  2. #102
    May 2013
    United States
    1971 2800CS
    Quote Originally Posted by gpeterson View Post
    Not sure, I have only tested on EWS2.
    Would ELM327 cable work with your program??? I need help.
  3. #103
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by rcginc1 View Post
    No, just vagcom + round adapter.
    S54 swap DME flashing - $100
    S54 swap CAN interface board (for proper A/C & check engine light) - $275
    e36 SAP sim/secondary air pump simulator:
    $75 - standard or $170 - plug & play
    e36 post-cat O2 sims: $115 shipped, plug & play
  4. #104
    Finland
    e91, e38, c4, b4
    Hmm, I can't figure out what the point is with this program..? Why just not install INPA? It takes about 20 seconds to load it and sync the ews, and you can use it for many other things like reading the fault codes, live data, clear service lights etc...
    BMW 320d Touring e91 -06 ----- BMW 740iA "ALPINA" e38 -00
    Audi UrS4 Avant 2.2T Twincharged @624hp/737Nm -93 ----- Audi 80q B4 2.2T @500hp/620Nm -92
  5. #105
    Nov 2011
    Australia
    1996 BMW 328i Sedan
    Hey I managed to get your program to read my isn, however I get an error when i try to write it
  6. #106
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by Ryley View Post
    What error? Can you please PM send me the log file that is written to the same directory as the .exe? Thanks.
  7. #107
    Sep 2013
    Australia
    1996 318is coupe
    As mentioned in a few previous posts, the app appears to do nothing, however I believe that it is not communicating with the DME.
    i have INPA loaded and can see the EWS and some other modules but no data from the DME. I think this is the cause of my and the other posters problems.
    i cannot see a log file, thinking the app needs the DME comms before it writes this.
    just a thought but is there any numbers on the DME label that will allow the ISN code to be input through INPA into the EWS.
  8. #108
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by rooboy1 View Post
    Ah, I'm guessing this is because you have a non-US car or possibly because it is a 318. Is your DME made by Bosch?
  9. #109
    m3mods's Avatar
    m3mods is offline Boost Addict BMW CCA Member
    Sep 2011
    AC Schnitzer S3 CLS
    So how much are the cables shipped to 97540?
  10. #110
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by m3mods View Post
    I don't sell them, you just need a vagcom cable and BMW 20-pin adapter, will probably be < $20 on eBay.
  11. #111
    m3mods's Avatar
    Sep 2011
    AC Schnitzer S3 CLS
    Ah yeah sorry just realized that after I posted..
  12. #112
    Jul 2010
    KC, Mo
    04 M3, 02 E39, 01 46 M3T
    So, I have a 1998 328 with an M3 engine and harness. It is running with the 328 DME. I want to use the M3 DME that came with the engine. Is the software sorted to the point of being able to install the M3 DME and have the car start?
  13. #113
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by snaponbob View Post
    Yes, should work fine for that.
  14. #114
    Feb 2010
    Hanover Park, IL U.S.
    TSX, M3, RDX
    This worked for me too. Though it said EWS sync unsuccessful numerous times, I thought what the hell, I'll try it and to my delight it started right up afterwards and runs flawlessly.
  15. #115
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by PARZ M3 View Post
    Surprising... can you please PM me the contents of the log file that that was written to the same directory as the .exe? I can't remember what I called it, but should be easy to find.
  16. #116
    Apr 2014
    Bulgaria
    bmw e30
    hi gpeterson you have made really nice little program... it works with an ads/obd cable in obd mode... when you are in ads mode it just freezes when you push the read button...
    but i have some other question: Why i can't see your ews delete thread which is the first in your signiture?it says i do not have permission to see it? because i'm too new or it's because just few people can read it?
    sorry for the off-topic
  17. #117
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by Bmw e30m View Post
    The thread was deleted for some reason. I can delete EWS from MS 41.1 and MS41.2 as well as SAP and post-cat O2 delete on MS41.2.
  18. #118
    Mcloud, Oklahoma
    '99 323is, '00 323i 528i
    Is the link on the first page of this thread still the current version? (v1.0.0.0)
  19. #119
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by KevinMullins View Post
    Yes, it is.
  20. #120
    Mcloud, Oklahoma
    Cool. I hadn't been keeping up with the thread, so figured I'd ask.
  21. #121
    Nov 2011
    atlanta
    1998 318i, 1998 M3
    I have an EWS1 motor and ecu, and an EWS2 chassis, is this what I need to sync my EWS? or can I just clip some wires?
  22. #122
    Northern CA
    1998 M3/4/5
    I don't think there is anything to sync with EWSI, I'd check the threads on disabling it. You can probably leave your EWSII module in place and still have the protection of disabling the starter assuming you have matching keys.
  23. #123
    Nov 2011
    atlanta
    1998 318i, 1998 M3
    I do have matching keys, but figured the chassis or EWS2 module will be looking for a EWS2 signal from the DME which will not be present. There is so much conflicting information on the subject that it is almost impossible to do a good search. I was hoping I could just re align it with software, since it seems better than cutting a harness up.
  24. #124
    Jan 2012
    SI
    1999 BMW E36 323ti
    Quote Originally Posted by Stück View Post
    To my knowledge what you want to do cannot be done. EWS3 is a completely different beast and isn't able to be realigned like EWS2.
    You need a key set, ignition switch, EWS3 module, and DME from a complete donor car.
    Not true. I had car with EWS3 module. Then I swapped engine and DME for M52 from car with EWS2. Then just opened DIS (running on vmware) and clicked to "align dme ews" and everything worked. So it could be done even if ews2 is something completely different than ews3.
    Now I am going to swap engine and dme from some other also from ews2 car and I will try to sync it first with this application. I will post results!
  25. #125
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by old hag View Post
    EWS2 works the other way - DME is looking for signal from EWS2. It won't care if there is no DME to talk to.
