Page 3 of 11 FirstFirst 1234567891011 LastLast
Results 51 to 75 of 274
Thread: EWS sync without installing EDIABAS/INPA/DIS using a $10 vagcom cable
  1. #51
    Dec 2009
    tunis, Tunisia
    1997 BMW 328 Coupe
    Quote Originally Posted by mrf View Post
    I second this. Maybe a 'Verify EWS' from the EWS module?
    You can use BMW Scanner v1.4 to add/remove keys I believe. I remember seeing the menu for that and the keys listed but haven't personally messed with it.
    yes that's what i meant. With INPA when you open EWS module you have access to ISN code so gpeterson is probably able to add this feature.
    Like Bram said with BMW scanner you can only enable/disable keys. But if the EWS can have up to 10 keys, there is probably a way to add them.
    Zied.
  2. #52
    Mar 2002
    Tempe, AZ, USA
    94E36S50,96S52,03Z4,etc
    I finally found that my engine wasn't grounded and finally have the car cranking. I'm not sure if I have fuel/spark yet, but I thought I'd double-check this, too.
    I'm not sure what I'm supposed to do with the log file.
    ISN: ba7
    LOG:
    4/16/2013 6:28:40 PM DME ISN: 12 2e a0 31 34 30 36 34 36 34 31 36 30 31 31 30 32 31 31 30 39 38 30 30 30 30 31 31 35 38 35 32 31 32 30 32 39 38 30 39 34 32 39 38 33
    5/3/2013 10:23:24 PM DME ISN: 12 2e a0 31 34 30 36 34 36 34 31 36 30 31 31 30 32 31 31 30 39 38 30 30 30 30 31 31 35 38 35 32 31 32 30 32 39 38 30 39 34 32 39 38 33
  3. #53
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by DaveAZ View Post
    ISN: ba7
    LOG:
    Ok - missing ground makes sense. EWS will kill the starter on its own if there is a key/transponder issue, DME will kill fuel/spark if EWS doesn't send it the correct bits.
    The log file is for me to make sure I'm interpreting the ISN correctly. I just ran some tests and it looks good.
    S54 swap DME flashing - $100
    S54 swap CAN interface board (for proper A/C & check engine light) - $275
    e36 SAP sim/secondary air pump simulator:
    $75 - standard or $170 - plug & play
    e36 post-cat O2 sims: $115 shipped, plug & play
  4. #54
    Mar 2002
    Tempe, AZ, USA
    Right now I have starter and fuel pump, but I have no spark. I'm not sure what's going on...
  5. #55
    Northern CA
    1998 M3/4/5
    Do you have INPA working? If so, you can easily check DME faults, see if my app didn't properly sync EWS.
  6. #56
    Mar 2011
    Malang 65163, Indonesia
    E36 M43
    Use inpa to read DME & EWS.
    Post here screen shot DME code
  7. #57
    Buena Park, Ca
    2002 BMW 540i/6, 2003 BM
    Quote Originally Posted by gpeterson View Post
    this is whats going on with my e39 after having arced the starter on the frame. would this mean i have to get a new dme and ews???
  8. #58
    Mcloud, Oklahoma
    '99 323is, '00 323i 528i
    Quote Originally Posted by setho View Post
    If you arced the stater to frame I would start with checking fuses if you haven't already done so.
  9. #59
    Buena Park, Ca
    Quote Originally Posted by KevinMullins View Post
    that was the first thing i did. i ripped apart the whole car to check every single fues, than checked all relays and replaced them all, and than made sure all grounds were good.
  10. #60
    Mar 2002
    Tempe, AZ, USA
    I struggled for a long time to get INPA working, but my laptop is winning the fight by resisting. It got so bad that I had to system restore and a stupid antivirus quarantined an INPA .exe file and refused to put in back. I was able to us a borrowed code reader, though.
    I finally bought a DME off ebay for $30.00 and it synced immediately and works.
    Finally having this car running is a great feeling
    Thanks!
  11. #61
    Sep 2009
    Staffordshire
    E36 323i
    What version od EWS will this work with? I have just tried on my 2007 E60, it recognises the COM port but when I press Read ISN from DME nothing happens.
  12. #62
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by LinusIT View Post
    Sorry, should have been more specific - definitely won't work on anything that new. Should work on OBDII e36, early e39, possibly others.
  13. #63
    Dec 2010
    Calabash, NC, USA
    96 328i Conv/73 2002
    I and trying to sync a 1996 328i EWS with Siemens MS41.1. I just received the 20 pin to 16 pin and from your mention in another post there should be continuity from pin 16 to OBD pin 1, no continuity so I proceeded with some tools and exposed pin 1 connector and soldered a wire from there to pin 16. I also have an OBD Link SX Multiprotocol OBD ll Scan Tool, will this work or do I need something else. I know just enough about this technology to be dangerous. That means if there are instructions...I can proceed.
  14. #64
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by rooster5merson View Post
    OBDII scan tool won't work as it does protocol conversion. The vagcom cable will send raw bytes between PC & k-line which is what we need here.
  15. #65
    Dec 2010
    Calabash, NC, USA
    I was afraid that might be the situation, would this be what I should order...OBD2 OBD II Diagnostic USB Cable For KKL409.1 VAG-COM 409
  16. #66
    Dec 2010
    Calabash, NC, USA
    It is working on my car with 2 different DMEs! It is a bit rough:
    -no error handling (may crash if something unexpected happens)
    -serial operations run on UI thread (may appear to hang for few seconds)
    -requires .NET Framework 2.0
    Usage:
    -connect your vagcom cable to your PC and car via BMW 20-pin adapter
    -turn ignition on
    -run app
    -select COM port that corresponds to your vagcom cable
    -press "Read ISN from DME"... if successful you will see the ISN listed and the "Write ISN to EWS" button will be enabled
    -press "Write ISN to EWS"... if successful it will tell you to turn off ignition for 15 sec
    It would be great if someone could give it a try. I accept no responsibility if it leaves you with un-synced EWS, so please do so at your own risk. It would be nice if testers already had un-synced EWS (nothing to lose) and/or already have other tools to sync EWS in case my app doesn't work. Once others have confirmed it works well I'll make it a bit more polished.
    http://e36-electronic.com/photos/EWSSync.exe
    I am using a VAGCOM kkl 409.1 and the 20 to 16 adapter. When I open the app nothing happens after clicking Read ISN from DME
    ISN Unknown. Am I doing anything wrong or is it in my cables?
    I am using a VAGCOM KKL 409.1 and 20 to16 pin adapter. After connecting to port and opening app nothing happens after clicking Read ISN from DME.
    ISN UNKNOWN. Am I doing something wrong or is it my cables? I attempting this on a 1996 328i with an ECU Seimens MS41.1 with every number matching except vin.
  17. #67
    Northern CA
    1998 M3/4/5
    Are you sure the com port selected is the vagcom adapter?
  18. #68
    Dec 2010
    Calabash, NC, USA
    When I plugged the VAGCOM into my computer it started to download drivers and selected Com 4 and that is what comes up when I open your app, com 4 is the only one listed on drop down menu. When I select Com 4 theRead button is enabled and that is as far as it goes. When I turned off the ignition yor app functioned the same I could click it and it would blink and then noting. So it looks like it is not reading the ignition...now I'm lost.
  19. #69
    Northern CA
    1998 M3/4/5
    Is there a log file that was created in the same folder as the .exe? Your key is in the run position, correct?
  20. #70
    Dec 2010
    Calabash, NC, USA
    Yes , in run position. It really seems like it is not getting ignition signal. I am just not knowledgeable enough to pursue this on my own. I found a small firm in Southern Illinois that will sync my ecu replacement from original. They only charge $60.00 plus postage. I think I'm on my way to the post Office tomorrow. Thanx for trying to help, I appreciate it very much.
  21. #71
    Sep 2010
    Denmark
    BMW 735iA m62tu 2000
    Can you guys tell me does inpa and dis delete the ews coding?
  22. #72
    Northern CA
    1998 M3/4/5
    Before you send it out you may want to install INPA and see if your DME is working at all.
    Quote Originally Posted by mamij View Post
    If you mean eliminate/bypass EWS the answer is no.
  23. #73
    Sep 2010
    Denmark
    Is there any way to "zero" the dme so that it works with any ews car ?
    how do the ews delete chips work?
  24. #74
    Dec 2010
    Calabash, NC, USA
    Where do you find INPA that can be trusted, I tried several last night and my antivirus stopped them when I hit download.
  25. #75
    Aug 2008
    Panama
    E39 m52tuB30
    Hi there, I-m trying to install the program, but send me an error "Unable to find a version of the runtime to run this application. EWSSync.exe - .Net Framework Initialization Error@....
    I have a MacBook Pro, with Windows XP Pro, and Net Framework 4...
    E39, 523i, 1999, M52TUB30, 5 SPEED MANUAL, UUC SHORT SHIFTER, EURO SPECS, KONI YELLOWS, OEM SPORTS SPRINGS, OEM SPORTS SEATS, ALCANTARA HEADLINER AND /A/B/C PILLARS, OEM M-TECHNIC AERODYNAMIC, OEM M5 FRONT GRILLS, OEM M5 REAR FOLDING MIRRORS, OEM M5 REAR SWAYBAR, OEM M-TECHNIC II FRONT SWAYBAR, REMUS DUAL TIP MUFFLER, TITANSILVER, BIXENON, M PARALLEL SPOKE 66 STAGGERED, OEM M-AUDIO SYSTEM, NAV SCREEN 16:9, INTRAVEE II iPOD INTERFACE, OEM TCM WITH BLUETOOTH, Y RESONATOR DELETE, INTAKE HORN DELETE, CDV DELETE, CHARCOAL TITANIUM BRUSHED TRIM, FAN CLUTCH DELETE, ELECTRIC FAN, 3.15LSD DIFFERENTIAL, ESS TS2+ SUPERCHARGER, AQUAMIST METHANOL + WATER INJECTION
    PANAMA, CIUDAD DE PANAMA
