E39, 523i, 1999, M52TUB30, 5 SPEED MANUAL, UUC SHORT SHIFTER, EURO SPECS, KONI YELLOWS, OEM SPORTS SPRINGS, OEM SPORTS SEATS, ALCANTARA HEADLINER AND /A/B/C PILLARS, OEM M-TECHNIC AERODYNAMIC, OEM M5 FRONT GRILLS, OEM M5 REAR FOLDING MIRRORS, OEM M5 REAR SWAYBAR, OEM M-TECHNIC II FRONT SWAYBAR, REMUS DUAL TIP MUFFLER, TITANSILVER, BIXENON, M PARALLEL SPOKE 66 STAGGERED, OEM M-AUDIO SYSTEM, NAV SCREEN 16:9, INTRAVEE II iPOD INTERFACE, OEM TCM WITH BLUETOOTH, Y RESONATOR DELETE, INTAKE HORN DELETE, CDV DELETE, CHARCOAL TITANIUM BRUSHED TRIM, FAN CLUTCH DELETE, ELECTRIC FAN, 3.15LSD DIFFERENTIAL, ESS TS2+ SUPERCHARGER, AQUAMIST METHANOL + WATER INJECTION
PANAMA, CIUDAD DE PANAMA
Not sure why I didn't think of this yesterday... if EWS isn't in sync the car will crank but not get spark/fuel, so your car not cranking isn't related to EWS sync.
No, it won't unlock EWS. That would require re-flashing the DME with new software that has been modified.
S54 swap DME flashing - $100
S54 swap CAN interface board (for proper A/C & check engine light) - $275
e36 SAP sim/secondary air pump simulator: $75 - standard or $170 - plug & play
e36 post-cat O2 sims: $115 shipped, plug & play
I just read the BMW EWSII description: http://www.docstoc.com/docs/40351318...andthe-EWS-BMW and you are correct. I came up with a way to test if it is the EWS is disabling the starter, so I'll give that a shot tomorrow. I obtained INPA and still need to set it up on my computer, too.
Thanks again!
Update:
After ews syn successfully, car won't start.
The problem is new ISN address different with original ews.
So ISN EWS different with ISN DME.
ISN DME = 4B8
ISN ISN = B48
Ok, I'll try to get a different version of the app out today that will write log files for debugging purposes. Reading the ISN from the DME the way INPA does it is a bit weird, they encode it oddly and I figured there may be issues with my implementation.
What did you use to pull that binary file?
any luck on this?
I'm not having much success with my INPA, I guess the first problem is installing the driver for the vagcom cable, then getting it on the right COM port.
and I wanted to align my ews2 before spring break was over to get my S/C on : (
Download link is in post #6, I can't remember about soldering pins 7 & 8 but no harm to give it a try.
I just created a new version, you can download from the same link.
bram2011 - can you please try the new version? It will create a log file (EWSLog.txt) in the same directory as the exe. If you get a chance can you please read the ISN from your DME then PM the log contents to me?
EWS can be strange in the way it is implemented.
In the older cars, like the 325i M50, 318iS M44 etc you get something like this in the binary data-
Hex values (0-FF)
30 30 30 31 35 33 30 38 39
Convert that to ascii (almost all hex editors show it at the side) and it looks like 000153089
I've been following through those files, and that number counts up with age, 000004435 would be a younger car for example.
Take the last 4 digits, 3089, and convert from decimal to hex again, and you get C11
http://www.mathsisfun.com/binary-dec...converter.html
That's the ISN, and that will usually be found in the EWS dump hex as 0C11.
I would assume the program does a "call", ie it will ask the ECU for the ISN and not just read a certain area, because as you can see, the ISN of C11 isn't written in the file.
Hex converts to Ascii, Ascii is treated as a decimal number, and that decimal number is converted back to hex.
Newer ECUs just writes the ISN in hex.
It might not be interesting or useful to the majority of people who just want to sync an ECU, but it you have a chip file from an older Bosch ECU, Look for that 9 digit ascii string starting with a few zeros near where the hardware and software numbers sit, and use the method of treating the ascii as decimal, and converting to hex to read the ISN.
Giftschrank Projekt
It would be easier to troubleshoot if you told us what it "DID" do in INPA.
Aside from modifying the cable there are a few minor software steps that tend to get skipped and it won't work right.
Also knowing what version of INPA you are installing would help as well, I would start with v3.01 and go from there since some of the "updates" to v5.02 will screw things up.
You should have no problems reading a 98' once it's setup properly.
After getting INPA going...then... I would try the EWS stuff.
actually I just got the drivers done for my vagcom, at first it was error 0018, but now after re-installing and what not I am able to view my ISN for the EWS2, just not sure the procedure after that....I don't want to thread jack Gpetersons awesome work, but if someone would lie to pm me
p.s. I will still try ur app
Stuff like this makes me smile!
Nice work!
i have had Success syncing my S/C tuned MS41.1 using this app.
thanks gpeterson!
I just wanted to take a second and give you a big THANK YOU.
I had been trying to align EWS to a new DME on a customers car for almost an hour with DIS and INPA to no avail. Tried Progman and that too failed and gave an error.
Your program worked, and in like 3 seconds.
97 528i /w S52 swap and matching e36 M3 DME.
Win7 64bit /w vagcom cable and self made 20pin adapter.
Tenured Automotive Service Professional - Avid BMW Enthusiast
woow Excellent work mate
Have tested with my 318is M44 (Bosch M5.2 ECU) it's reading my ISN in 3 seconds !!!
haven't tested writing ISN because my ECU-DME are already aligned.
I will test it later with my friends 328i (M52) we couldn' sync EWS with DIS.
This will become soon a must have tool !!!
By the way how is The Key/EWS sync working in E36 ??
for example if i replace my EWS, sync with DME will just take me 3 seconds with this tool, but how can i sync my old keys to the new EWS ?
You won't be able to reuse old keys with a different EWS unit, so keep them together.
Giftschrank Projekt
How the dealer add keys to an EWS Module ?
@gpeterson : I want to understand a bit more how it is handling errors, for example if the EWS writing is unsuccessful does it throw an error message ?
and also i want to know if there is a way to add reading ISN code from EWS ? This will be very helpful to identify if the problem is either from EWS module, keys or DME.
Zied.
