Page 11 of 12 FirstFirst ... 23456789101112 LastLast
Results 251 to 275 of 276
Thread: EWS sync without installing EDIABAS/INPA/DIS using a $10 vagcom cable
  1. #251
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by cartoonz View Post
    Any chance this'll work with an E31, DWS II and motronic 1.7 DME's ?
    Probably not, looks like Motronic 1.7 uses K line for TX and L line for RX. You would likely need a pc with a real COM1 serial port and ADS interface to use with DIS or Tool32 (recommended).
    With Tool32 you would run the isn_lesen for motronic 1.7 and feed the value into isn_schreiben for EWS.
    S54 swap DME flashing - $100
    S54 swap CAN interface board (for proper A/C & check engine light) - $275
    e36 SAP sim/secondary air pump simulator:
    $75 - standard or $170 - plug & play
    e36 post-cat O2 sims: $115 shipped, plug & play
  2. #252
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    thought so, but I had to check
    '91 850i 6sp (mint) (sold)
  3. #253
    Sep 2016
    Montreal
    E36 m3
    @gpetersom
    Thanks a lot ! It worked like a charm. It gave me a check engine at first (4a63 BMW Fault Code – EWS Tampering or EWS Manipulation) but erased it and never came back.
  4. #254
    Aug 2014
    kentucky
    '98 Z3 M Roadster
    Cable is correct, drivers installed, now program keeps crashing.
    description: stopped working
    problem event name: CLR20r3
    problem signature 01: ewssync.ews
    problem signature 02: 1.0.0.0.
    problem signature 03: 5169ed2
    problem signature 04: mscorlib
    problem signature 05: 2.0.0.0
    problem signature 06: 53a11de1
    problem signature 07: 2591
    problem signature 08: 0
    problem signature 09: system.io.filenot foundexception
    OS version: 6.1.7601.2.1.0.256.1
    locale ID: 1033
    Built S52 w/Dinan ISR-3 kit, NickG Stage 2+ Tune, Dinan Vortech V2 Supercharger, Dinan Air to Air Intercooler, Dinan CAI, Porsche 803 HFM, Buldogge 6" crank pulley, Griptec 2.90" blower pulley, Eurosport UD pulleys, Dinan 3.38 Diff, Dinan front/rear Swaybars, Dinan springs, Koni Yellow Sport Struts, Ground Control end links, South Bend Clutch Stage 3 Organic, AASCO Light Weight Flywheel 18.5#, Zionsville Radiator & Oil Cooler, Riot Racing BBTB, Schrick Intake Manifold, 42# Injectors, Schrick cams 264/256, Forged Wiseco pistons 9.0 comp., Forged Eagle rods, Supertech dual valve springs & valves, VAC crank & bearings, Supersprint mufflers, Euro Z3 midpipe, Raceland euro headers, Walbro 255, Bevauto ignition coils, Vortech Mondo bypass, Bailey Diverter DV30, Ireland Rear Subframe Bushings, Mason Engineering Strut Brace, Mason Engineering Clutch Petal, Apex 18" EC-7 Wheels, Full Custom Sound System, two trunk lids (with & without OE spoiler), Hardtop, Trunk full of AK's...
  5. #255
    Mar 2013
    Texas
    98' Hellrot M3
    Worked perfect on my Ti s52 swap, took a couple seconds to sync thanks!! @gpeterson
  6. #256
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by bubbafett View Post
    locale ID: 1033
    What version of Windows are you running? Any idea if .NET is installed?
    Quote Originally Posted by Grimm5698 View Post
    Awesome, glad it worked for you.
  7. #257
    Nov 2018
    Laredo, Tx
    1998 323is (x2)
    Awesome program, hoping to use this on my 98 323is. I’m ordering the vag com cable and adapter right now, hopefully I’ll have it ready in a week or two
  8. #258
    Nov 2018
    Laredo, Tx
    1998 323is (x2)
    Worked on 98 323is 👍🏻
  9. #259
    Jul 2019
    Canada
    BMW E39 528i 1998
    It worked on my E39.
    Unfortunately my key is still not recognized and the car wont even crank
  10. #260
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by Bmwe39528i1998 View Post
    You may want to check the wiring for the ring antenna, transmitter/receiver module (if present on your car), and park/neutral or clutch switch unless you have reason to believe something happened to your key. INPA would be helpful to see what your EWS and DME are thinking. The EWS has a relay that will interrupt the starter unless the key matches and it thinks the car is in park/neutral or clutch pushed in.
    There is info available at http://www.e38.org/EWS.pdf.
  11. #261
    Jan 2015
    AUSTRALIA
    1997 BMW 328iC Man.
    Hi all!
    I am 12 months into my issues that I have outlined earlier. One thing i thought to post/query is - does the difference in being manual or auto make a diff with this terrific little app?
    Reason I ask is; I have 2x 328i verts; one manual, one auto. I mixed up the ews modules at one stage and then ended up with both having conflicting signals. My DD was unable to be driven for 2 wks while I sought a solution, downloaded INPA etc and no success until I tripped over this program. It did not respond to my auto- write to ecu conf.. but it did to my manual!. I am back in the same place again with the auto..trying to start it and will not write to the ecu (both cars are Siemens MS41.0.
    I bought a Julie emulator but got bogged down in the technical side some time back...not an easy solution it appears if you are not coding proficient.
    The car originally ran A1 as it has only 60kmiles on it but I have to push it to move it and I am tiring of the issue!
    any input much appreciated on both issues..the Julie and the diff between auto/manual.
    Cheers
    wintech
  12. #262
    Dec 2019
    Virginia
    1997 bmw 328i
    Anyway to use a chromebook for progran or is there a chromebook version available
  13. #263
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by AsunderTech174 View Post
    No, not currently.
  14. #264
    Dec 2019
    US
    1997 328i
    So i have finally got the program on windows 10. It only allows com port 3 regaurdless of which port vag com is in than when you hit read isn it just freezes does nothing and i cant get inpa to properly install to see if dme has vin and can be read. I do have CEL on
    Sent from my LG-AS993 using Tapatalk
  15. #265
    Jun 2014
    Austin, Texas
    97 civic sedan, 98 328is
    I have .NET framework 4.7 but the install wizard says I need 3.5. When I try to skip .NET installation the wizard just shuts down. Anyone else have this issue?
  16. #266
    Jun 2014
    Austin, Texas
    Post
    Quote Originally Posted by munozisdead View Post
    Scratch that. Dumb. Laptop just messing up.
  17. #267
    Oct 2018
    Hong Kong
    E39
    Thanks, the tool worked great for my e39 (3/98) which has a ms41.0 and an ews 3.2
    Of course it can be done with inpa too. But your tool is much more convenient.
    ps: the last 4 digits of the dme production number are equal to the ISN. Must be converted to hex and if >4096 (decimal) need to subtract 4096 first
  18. #268
    Mar 2021
    Portugal
    e36 318is
    @gpeterson do you think this cable will work? Thx!
    https://a.aliexpress.com/_mPquS2B
  19. #269
    Jul 2020
    Long Beach Ca
    e36 325i
    it worked for me thank man!
    I used these under hood port
    CABLE
    https://www.amazon.com/dp/B017IG81SQ...vopqNqPon2Ni_g
    adapter 20pin
    https://www.amazon.com/dp/B07D8RQWKL...U_FVRrk2NwnmpI
    and your software !!!!!!!!!!!!
  20. #270
    Jan 2022
    covasna
    1997 bmw m3 e36
    Hi
    can anyone help me find ISN from dump m5.2
    which address to convert to what?
    thank you for any help!!
  21. #271
    Aug 2022
    Indonesia
    1997 BMW E39 528i
    Quote Originally Posted by bram2011 View Post
    Thanks for the software.
    Testing has been successful in DME MS41 5WK90322 and EWS2 61.35-8 375 840
    I use WinXp Sp3 and INPA cable.
    Attachment 452958
    Quote Originally Posted by CityHunt3R View Post
    CABLE
    adapter 20pin
    Nice. I guess it works with K+DCAN cable too.
    Great information. I may test this with my unsync e39
  22. #272
    Feb 2017
    UK
    bmw e39
    Hii guys
    trying to download this tread but no succes:http://e36-electronic.com/photos/EWSSync.exe
    Any one can help
    Feb 2022
    New York
    1995 E36 M3 Luxury
    So I have a 1995 e36 M3 with a suspected unaligned ews2 and DME. With the proper cabling and a windows laptop will this software work for my car. It is obd1 with ews2
  24. #274
    Mar 2014
    Mexico Distrito Federal
    X5 E70
    You can download? on my case the problem is from antivirus.
  25. #275
    Apr 2024
    Brazil, Sao Paulo, SP
    BMW 328i 1996
    Hi guys, i don`t know if anyone answer this post, but, i need to put the 20-pins adapter on write mode (jump the 14 and 18 pins) ?
