Page 1 of 12 1234567891011 ... LastLast
Results 1 to 25 of 276
Thread: EWS sync without installing EDIABAS/INPA/DIS using a $10 vagcom cable
    Northern CA
    1998 M3/4/5
    MS41.x EWS sync without installing EDIABAS/INPA/DIS using a $10 vagcom cable
    I'm making great progress on a standalone windows application that will allow you to sync EWS using your PC, a $10 vagcom cable, $5 OBD2 to BMW 20-pin adapter. It is a standalone application that does not require installation of EDIABAS/INPA/DIS/VMWare, etc. and should be very easy to use.
    It works on MS41.x (OBD2 e36/e39 6cyl cars) and will likely not work on others.
    UPDATE: download it here - http://e36-electronic.com/photos/EWSSync.exe
    S54 swap DME flashing - $100
    S54 swap CAN interface board (for proper A/C & check engine light) - $275
    e36 SAP sim/secondary air pump simulator:
    $75 - standard or $170 - plug & play
    e36 post-cat O2 sims: $115 shipped, plug & play
    Mcloud, Oklahoma
    '99 323is, '00 323i 528i
    Subscribed. Definitely interested to see how this turns out.
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by KevinMullins View Post
    Do you happen to have a vagcom cable & OBD2 to BMW 20-pin adapter? My testing will be limited, hoping to find others who can test soon. Thanks.
    Mar 2002
    Tempe, AZ, USA
    94E36S50,96S52,03Z4,etc
    I can order the cable and adapter and be ready to test it as soon as they arrive.
    Mcloud, Oklahoma
    Quote Originally Posted by gpeterson View Post
    Yes to all of the above.
    I don't have any cars around that need EWS work done to them, but I can certainly poke around with it.
    Northern CA
    1998 M3/4/5
    It is working on my car with 2 different DMEs! It is a bit rough:
    -no error handling (may crash if something unexpected happens)
    -serial operations run on UI thread (may appear to hang for few seconds)
    -requires .NET Framework 2.0
    Usage:
    -connect your vagcom cable to your PC and car via BMW 20-pin adapter
    -turn ignition on
    -run app
    -select COM port that corresponds to your vagcom cable
    -press "Read ISN from DME"... if successful you will see the ISN listed and the "Write ISN to EWS" button will be enabled
    -press "Write ISN to EWS"... if successful it will tell you to turn off ignition for 15 sec
    It would be great if someone could give it a try. I accept no responsibility if it leaves you with un-synced EWS, so please do so at your own risk. It would be nice if testers already had un-synced EWS (nothing to lose) and/or already have other tools to sync EWS in case my app doesn't work. Once others have confirmed it works well I'll make it a bit more polished.
    Mar 2002
    Tempe, AZ, USA
    Awesome! I'll be trying it hopefully by Thursday.
    Feb 2010
    Granada Hills, CA
    1998 M3
    This is exactly what I need to swap out my ms41.1 dme's
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by 1980corvette View Post
    Great, do you have a vagcom cable & OBD2 to BMW 20 pin adapter? Thanks.
    Feb 2010
    Granada Hills, CA
    1998 M3
    lol nope, but looks like it'll run me about $20 all together...does the vagcom cable need any cd program with it?
    i will try anything to align ews on my ms41.1's at home lmao.
    Northern CA
    1998 M3/4/5
    No, the vagcom cable shows up on the USB bus as a serial port, windows likely has drivers for it already.
    Feb 2010
    Granada Hills, CA
    1998 M3
    kool, just to clear it up since I'm ver noob lol, the 20 pin connects in the engine bay, then to the vagcom, then to the laptop?
    Northern CA
    1998 M3/4/5
    Correct.
    Mar 2002
    Tempe, AZ, USA
    Both of my cables have tracking that puts them here on Thursday.
    You say the computer needs to have .NET Framework 2.0.
    My Windows 7 program list says I have "Microsoft .NET Framework 4 Client Profile version 4.0.30319."
    Will this work, or do I need to track down 2.0?
    Mar 2011
    Malang 65163, Indonesia
    E36 M43
    Usage:
    -turn ignition on
    -run app
    Thanks for the software.
    Testing has been successful in DME MS41 5WK90322 and EWS2 61.35-8 375 840
    I use WinXp Sp3 and INPA cable.
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by DaveAZ View Post
    Will work fine on Win7 without installing an additional .NET framework.
    Mar 2011
    E36 M43
    Testing has been successful in DME MS41 5WK90322 and EWS2 (test on bench)
    I use INPA cable on Windows XP SP-3.
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by bram2011 View Post
    Nice! Thanks for testing.
    Feb 2010
    Granada Hills, CA
    1998 M3
    can't wait to try it out!
    Mar 2002
    Tempe, AZ, USA
    My cables arrived.
    On the first try, the program didn't find my COM port. I shut the program and started it again and it found it.
    The program said it worked- I pushed the first button and it found ba7 as the ISN code.
    I pushed the second button and it wrote it to the EWS.
    It prompted me to turn the ignition key off for 15 seconds.
    I turned the key off, disconnected my cable and put the port cover back on.
    A few minutes later I turned the key and I hear no starter.
    I repeated with the same results.
    Since I just put this engine in, it could be something else- but I have no idea what it could be.
    Northern CA
    1998 M3/4/5
    My cables arrived.
    The program said it worked- I pushed the first button and it found Ba7 as the ISN code.
    Hmm... could be many things. You can always setup INPA & use it to read & clear DME errors & try again. I can't remember the specifics of the DME error when EWS is out of sync, but if you see it you will know what it is.
    If you don't get INPA setup I can probably tweak the app tomorrow so that it will tell you if EWS is in sync.
    Just to make sure... is your key and EWS module the same ones that were on the car and known to work?
    Mar 2002
    Tempe, AZ, USA
    Yep. I tried it with the two keys which came with the car. I also tried locking and unlocking the driver's door a few times because I saw mention of that in the EWS document I had read.
    Will INPA work with this cable setup? Is it something I can download? This is my first OBDII experience, so I know very little about this end of it.
    The sync-checker would be an awesome addition, too. Thanks!
    Northern CA
    1998 M3/4/5
    INPA configured for an OBD interface will work with that cable, but you will not be able to access all modules on the car. Some (cluster, ABS, others) require an ADS interface.
    Aug 2008
    Panama
    E39 m52tuB30
    can I program my EWS (with PaSoft BMW Scanner 1.4) after I use this program? I want to put my correct millage in my EWS to turn off the tamper dot in my cluster...
    E39, 523i, 1999, M52TUB30, 5 SPEED MANUAL, UUC SHORT SHIFTER, EURO SPECS, KONI YELLOWS, OEM SPORTS SPRINGS, OEM SPORTS SEATS, ALCANTARA HEADLINER AND /A/B/C PILLARS, OEM M-TECHNIC AERODYNAMIC, OEM M5 FRONT GRILLS, OEM M5 REAR FOLDING MIRRORS, OEM M5 REAR SWAYBAR, OEM M-TECHNIC II FRONT SWAYBAR, REMUS DUAL TIP MUFFLER, TITANSILVER, BIXENON, M PARALLEL SPOKE 66 STAGGERED, OEM M-AUDIO SYSTEM, NAV SCREEN 16:9, INTRAVEE II iPOD INTERFACE, OEM TCM WITH BLUETOOTH, Y RESONATOR DELETE, INTAKE HORN DELETE, CDV DELETE, CHARCOAL TITANIUM BRUSHED TRIM, FAN CLUTCH DELETE, ELECTRIC FAN, 3.15LSD DIFFERENTIAL, ESS TS2+ SUPERCHARGER, AQUAMIST METHANOL + WATER INJECTION
    PANAMA, CIUDAD DE PANAMA
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by jdjg View Post
    I can't confirm as I've never used PaSoft BMW Scanner, but I'd guessing that it won't be an issue.
