Page 10 of 12 FirstFirst 123456789101112 LastLast
Results 226 to 250 of 276
Thread: EWS sync without installing EDIABAS/INPA/DIS using a $10 vagcom cable
  1. #226
    Jul 2004
    Houston, TX
    36 Cylinders
    The link and instructions are literally on the first post... You don't need to read through the thread.
    You can use any USB diagnostics cable with FTDI chip. It doesn't have to be a VAGCOM cable. It can be the usual INPA K+DCAN cable attached to your 20-pin adapter.
    And yes it works. It's very simple.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  2. #227
    DeWitt, Michigan
    '97 540i/6, '97 328i
    I'm having an odd misfire error above 4psi of boost on my '97 540 I turbocharged. M5.2 DME, with a very decent tune in it at this point, so I don't think the tune is the fault. I think it looks like I should be able to install one of my spare DMEs with matching part number to the original, and use this program to sync the new DME to my existing EWS, correct?
    If so, I will probably give it a try. Then I'll flash in my current partial tune to the new DME, and see if the problem persists. There is no way to do this sync of the new DME to the old EWS with just INPA, is there? I'm obviously confused on this, haha...
  3. #228
    Jul 2004
    Houston, TX
    36 Cylinders
    The early M5.2 (88-pin) dmes should work with the ewssync.exe application, and INPA as well.
    -Abel
  4. #229
    Belo Horizonte, Minas Gerais, Brazil
    E24, E32, E34
    Does anyone know if this program works with E34 M5 1995?
  5. #230
    Aug 2009
    London, UK
    E46 M3
    Are there any plans to make a version that works with newer EWS versions,like in the E46 series cars ?
  6. #231
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by ac427 View Post
    No, newer DMEs do not let you re-sync to a new EWS repeatedly.
    S54 swap DME flashing - $100
    S54 swap CAN interface board (for proper A/C & check engine light) - $275
    e36 SAP sim/secondary air pump simulator:
    $75 - standard or $170 - plug & play
    e36 post-cat O2 sims: $115 shipped, plug & play
  7. #232
    Aug 2009
    London, UK
    E46 M3
    Quote Originally Posted by gpeterson View Post
    Oh i didn't realise there was a limit. I am sure you can write the ISN with INPA, by manually typing it in.
    Is the DME's EWS sync limit linked to the DME software write limit count ?
  8. #233
    Northern CA
    1998 M3/4/5
    It isn't a limit, they are paired once and I don't think you can "virginize" the DME via k-line. Here is some info on MSS54 - http://www.m3forum.net/m3forum/showthread.php?t=528013
  9. #234
    Aug 2009
    London, UK
    E46 M3
    Ah i see, thanks for the link.
    Is there a protocol standard used to communicate via OBD ?
  10. #235
    Feb 2018
    CT
    2006 330xi, 1997 Z3 1.9
    I just purchased a complete lock set for a 1997 BMW Z3 that I am restoring. The seller included the ignition key and EWS unit. He told me that the EWS is plug and play. Everything that I have read says that the EWS unit needs to be aligned to the DME. Two Questions: In my case, Does the EWS need to be aligned to the DME? If so, will this program do the trick? Your help is greatly appreciated.
  11. #236
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by addysdady View Post
    Yes, you need to align DME to this new ews.
    This program will do it. You need the usb cable and 20-pin adapter. All done under the hood.
    -Abel
  12. #237
    Manila, Philippines
    2005 BMW X5 4.8is
    Wow! I finally got it to work! Used the same cable I use with GT1 and Windows 8 64-bit. Thank you soooo much 328_Power_04 for this wonderful program.
  13. #238
    Jul 2004
    Houston, TX
    36 Cylinders
    All credit goes to gpeterson and his awesome program.
    -Abel
  14. #239
    Feb 2018
    CT
    Can anyone confirm where the EWS module is on a 1997 Z3? For some reason I thought it was behind the glove box but no go. Before I go ripping apart the drivers side dash, confirmation that it is there would be great. Thank you!
  15. #240
    Feb 2018
    CT
    Never mind! It's behind the glove box. I didn't realize that I had to rip the whole thing out.
  16. #241
    Feb 2018
    CT
    Thanks a million gpeterson!!! $12 cables, $45 lock set and your program allowed my Z3 to have one key and an ignition that actually works. Priceless!!!!
  17. #242
    Sep 2016
    Montreal
    E36 m3
    Quick question,
    I bought a tuned dme and want to replace my stock one. (USDM E36 M3 MS41.1)
    If let's say it doesn't work and it doesn't write correctly or doesn't write at all, will putting back stock DME work. Don't want to brake anything and not be able to go back to stock.
    Edit: went through the 12 pages, I'd have to re-sync to get the original dme to work.
  18. #243
    Jul 2004
    Houston, TX
    36 Cylinders
    Tuned ebay dmes are crap, just in case.
    -Abel
  19. #244
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by Schweeeebs View Post
    Quick question,
    If it doesn't work (likely due to cable or wiring issue) the EWS will still be paired with your old DME. If it does work it should work just as well to re-sync with your old DME. The risk here is pretty low.
    If you are paranoid you have have EWS deleted from the tuned DME. That would let you switch back and fourth without doing anything.
  20. #245
    Sep 2016
    Montreal
    E36 m3
    Rk tuned dme
  21. #246
    Sep 2016
    Montreal
    E36 m3
    Im a bit paranoid, I just dont want to end up with a bricked tuned dme and a ews that wont work with my original dme.
    Worst case I delete the ews
  22. #247
    Sep 2016
    Montreal
    E36 m3
    Also is there a better cable you would recommend ? I have a vagcom hex-v2, the cable used with eurodyne and the one from rk tuning.
  23. #248
    Northern CA
    1998 M3/4/5
    That should be fine. Just keep in mind you need an adapter and must use the 20-pin port under the hood. The OBD2 connector under the dash is not wired to the EWS.
    You can safely test your cable and DME communication by reading the ISN from the DME.
  24. #249
    Sep 2016
    Montreal
    E36 m3
    Thank you.
    Yes I know I need the 20 pin adapter already have it.
  25. #250
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    Any chance this'll work with an E31, DWS II and motronic 1.7 DME's ?
    '91 850i 6sp (mint) (sold)
