Results 1 to 3 of 3
Thread: DIY-SLS (self leveling suspension) pump repair kit
    Nov 2010
    Santa Ana, CA USA
    1988 m6
    Hi Folks,
    Is your SLS pump is leaking, do you want to keep your car origional. This is for the trunk mounted unit.
    The pump is still available from BMW # 37121128247 for $1,225.55 + shipping.
    Here is my latest repair kit. For the following models.
    e23, 733,735
    e24, 633,635,m6
    e28, m5
    e32, 735 only
    This is the link to my DIY SLS repair photo site, please read the captions under each photo.
    https://www.bimmerforums.com/forum/s...rrent-websites
    If you want me to repair your SLS for you, I offer a repair service, see my link.
    Jay
    '88 M6 Cinnabar Red / Nappa Natur Highline Interior (10-87) Santa Ana, California. USA
    My NEW Website, Link : https://www.jaysbmwparts.com
    Booster repair
    A/C Wingcell Compressor leak repair
    e31 Door Handle Fix,
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    it would be good, if you can provide a seal kit for the regulating valve on the rear axle for SLS. In 2008 I made some pice when we disassembled it
    http://www.bimmerboard.com/forums/posts/508927/
    more pics
    http://www.bimmerboard.com/members/jeffc/DSC03361sm.jpg
    http://www.bimmerboard.com/forums/posts/509799
    http://www.bimmerboard.com/forums/posts/511327
    From the technical description of this valve made by the German company BARMAG, Model no. stamped in is VO011 34-1 or 84-1 (??)(difficult to see, although I used a steel brush):
    the minimum pressure valve is to keep the system pressure behind the valve not lower than p = 30 bar.
    The over pressure valve is limited to maximum p = 130 bar and opens then.
    Power steering pump pressure is 130-135 bar, the dual power steering pump feeds the LAD system.
    Pressure inside the regulating valve?
    May 2013
    Canada
    1990/02 BMW 735iA M30B35
    Looking for tool to test automatic transmission solenoids ?
