Hi Folks,
Is your SLS pump is leaking, do you want to keep your car origional. This is for the trunk mounted unit.
The pump is still available from BMW # 37121128247 for $1,225.55 + shipping.
Here is my latest repair kit. For the following models.
e23, 733,735
e24, 633,635,m6
e28, m5
e32, 735 only
This is the link to my DIY SLS repair photo site, please read the captions under each photo.
https://www.bimmerforums.com/forum/s...rrent-websites
If you want me to repair your SLS for you, I offer a repair service, see my link.
Jay
'88 M6 Cinnabar Red / Nappa Natur Highline Interior (10-87) Santa Ana, California. USA
My NEW Website, Link : https://www.jaysbmwparts.com
Booster repair
A/C Wingcell Compressor leak repair
e31 Door Handle Fix,
it would be good, if you can provide a seal kit for the regulating valve on the rear axle for SLS. In 2008 I made some pice when we disassembled it
http://www.bimmerboard.com/forums/posts/508927/
more pics
http://www.bimmerboard.com/members/jeffc/DSC03361sm.jpg
http://www.bimmerboard.com/forums/posts/509799
http://www.bimmerboard.com/forums/posts/511327
From the technical description of this valve made by the German company BARMAG, Model no. stamped in is VO011 34-1 or 84-1 (??)(difficult to see, although I used a steel brush):
the minimum pressure valve is to keep the system pressure behind the valve not lower than p = 30 bar.
The over pressure valve is limited to maximum p = 130 bar and opens then.
Power steering pump pressure is 130-135 bar, the dual power steering pump feeds the LAD system.
Pressure inside the regulating valve?
Looking for tool to test automatic transmission solenoids ?
