does anyone have a 7.5" wide rim with 235/40/17's on? i have a side wall of 45 right now, will the 40 make a difference? these are my front wheels. i have 235/40/17 kumho ecsta supra 712's. thanks
04 M3 Coupe Current///97 Civic HX (DD) Current///08 Ducati 848 Pearl White Sold
///00 323i Sold///02 RSX Type S Sold///99 996 C2 Sold///01 996 C2 Cab Sold
///01 325ci Sold ///98.5 M3 Alpine Sold ///95 M3 Cosmos Sold///90 Accord Sold
235/40/17 is a factory fitment for the E36 chassis.
your car came with that tire size on it's front wheels - 17x7.5
you'll be fine.
-Ron
Hey man, I'm a professional!
I'm pretty sure the stock 95 M3 sizes 235/40R17 on a 7.5"?
I believe that's what I'm running on all corners in S02s.
The question is what are you running on the back...as long as your overall diameters aren't off that much (front to back) you shouldn't have any problems. Width differences are fine.
HTH,
--Mike
FYI:
95 M3 OE tires were 235/40/17 all around even though the wheels were staggared.
You have to be careful, tire sizes are not very consistant across manufacturers. I can tell you from experience the same size tire in goodyear and hoosier was almost 1/2" different in diameter .
-Alex
"Are you drunk again?"
"No, I'm just exhausted because I've been up all night drinking."
very true - but also consider that goodyears run extremly narrow and hoosier's run very wide.Originally Posted by aweather
my guess on the hoosiers running wider is cause they are racing tires (something you will NOT be normally running on the street). as race tires, their listed size is fudged a little to keep you in your class etc.
-Ron
FYI,
95s didn't come with a staggered rim setup, that came in 96+. (unless some very late model 95s did)
Mine, build date 9/95 were 7.5 all around.
Thanks.
--Mike
Mike,
a friend of mine has a '95 M3 with the original wheels still on it (forged lightweights). they are 7.5" up front and 8.5" in the rear.
is it possible that the different wheel designs were sold in different setups?
If they're the lightweight rims then that's a diff story. (not your typical OE for the standard 95) Those came in staggered even though the same sized rubber for the earlier models. (I never did understand why they would change the rim stagger without changing the tires...)
Stock 95 rims were typically the flat 10 spoke "BMW Motorosport" engraved painted rims.
Thanks.
--Mike
thanks for clearing that up.
yupOriginally Posted by phid_bombadier
