Results 1 to 5 of 5
Thread: Engine No-Start
    Mar 2013
    VALLEJO
    1995BMW740IL
    Unhappy Engine No-Start
    1995 BMW V8Cyl 4.0. I am going to post events that has happended
    1. Alarm(siren) continous noise (car was running)
    2. Moved car to driveway alarm continued
    3. disconnected battery
    4. key in bad condition AAA tried (no success)
    5. siren coming from rear rt side
    6. tried to start panal says (Key Ingition Lock)
    7. Had new BMW key made(alarm continous go off )
    8. Took to East West Europeon...... Their diagnostics
    9. Replaced faulty EWS module
    10. Coded & programmed EWS via BMW icom 3 g system
    11. DME VIN is not complete/scrambled
    12. Replace DME $1821.93 which is causing the EWS to not align itself(recomends)
    13. Replace General Module $670.05 (recomends)
    14. Reconmend a new battery BMW
    15. Car still will not start was not going to spend $2,500
    16. Have at least 20 pages of Diagnostics Report
    17. Help!!!!!!!
    Finland
    e91, e38, c4, b4
    I'm not sure about these older EWS modules, but did you ever sync the EWS and DME?
    BMW 320d Touring e91 -06 ----- BMW 740iA "ALPINA" e38 -00
    Audi UrS4 Avant 2.2T Twincharged @624hp/737Nm -93 ----- Audi 80q B4 2.2T @500hp/620Nm -92
    Feb 2013
    Magna, Utah
    1997 E38 7 Series 740iL
    The guy in this video made his cigarette lighter his start button to get around issues like these.
    [ame]http://www.youtube.com/watch?v=S3HgJJpyt8o[/ame]
    Mar 2013
    VALLEJO
    1995BMW740IL
    Yes the EWS and DME where synced, but only 4to 6 numbers from vin# showed the rest where zeros. Cigarette lighter i will show mechanic!
    Feb 2009
    KC North, MO, USA
    1996 740iL
    What is the build date of your car? Also, if you know, does your DME end with 404 or 484?
    Alarm could be caused from low battery voltage. Another common issue that causes this is the hood switch.
