Hi I'm new to this. My 2001 325xi runs smooth but sometimes it starts acting up and it shuts off. The code that i keep getting is Multiple Misfire With Fuel Cut-off
In different Cylinders. Any idea whats causing it?
The first actions should be a smoke test of the intake to check for leaks, a crank case pressure test to check for a failed CCV, a fuel rail pressure check, and a check for oil in the plug wells from leaking valve cover gaskets/grommets.
Jim Levie, Huntsville, AL
Ok ill work on that this week and repost with results thank you
Sent from my iPhone using BF.com
Chris Powell
BMWCCA 274412
quote="bmwdirtracer;26060591"]
+1. First, find the problem - then you know what to fix.[/quote]
Today i cleaned the mass air flow sensor, it shut off the check engine light, i dont know if it fixed the problem because it does it randomly
