When you are flying by the seat of your pants, nothing sounds more official than "Plan B"
1991 BMW 325i(Current Daily) (S52)
I have carburetors, and I'm not afraid to use them!
There are always other fish (engines) in the sea (Craigslist)
Life is about enjoying the engine you are sitting behind.
There used to be a bar up here called Plan B.
Sounds like a plan
― George Orwell
Doing a tech check on the M3 today. Getting ready for NED on Wednesday. Signed up for AAA and their free 200 mile tow last night. I be ready
Well looks like you got the important mod taken care of.
I will be running as well. Phillip and I drove all the way out there to find it was closed last night. So mow I will be itching to race everything on the street. School busses, cops, delivery trucks, wont matter. 3 honks to everyone.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Will we have some video footage?
― George Orwell
If a block with a blown head gasket that was also seriously over heated till the head was seriously warped and the intake cam cover was burnt was sitting for 2 to 3 yrs be clogged up? Meaning, the coolant, oil passages, oil pump and oil filter assembly be clogged up. What can be used to clean it up if possible.?
THE TIME DRAWS NEAR!
1996 332IS
Built 3.2
Oil filter housing does not make any difference but if you wanted an all metal one or E46M3 one it would be easiest to change when reinstalling the rebuilt motor.
1996 332IS
Built 3.2
Different filters though. For what its worth, M/S50 and S52/54 oil filter housings (metal cap) use the 51160 which is better built (steel end caps, steel core, and 85 pleats) vs. the M52/tu or M54 housing (plastic threaded cap) with the 51223 (plastic end caps, no core, and 70 pleats).
My 2008 M3 has a plastic filter housing and no metal end caps on the filter. Good enough for a $25k motor.
1996 332IS
Built 3.2
Phil, I sent you a pm about your turbo.
1996 332IS
Built 3.2
Have too many other projects right now to pay for and finish before the turbo. Also really like this turbo and still trying to figure out what I will be giving up and what would be the new turbo.
1996 332IS
Built 3.2
1996 332IS
Built 3.2
