Don't know what that is. It's tuned for an 803 maf. I now have 2 of those.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
One of these?
http://www.amazon.com/Innovate-Motor...band+o2+sensor
I assume I'll need to have a bung welded into the exhaust somewhere?
Wow that's a good price. That's exactly what you want. The good part about a AEM is that it doesn't need to be calibrated.
The innovate like that one (exactly the one I have) needs to be calibrated if it loses power.
1996 332IS
Built 3.2
Wednesday night will be heading up to new england Dragway. A new member maybe members will be running. Hope more show up.
1996 332IS
Built 3.2
How much is it to run?
1996 332IS
Built 3.2
1996 332IS
Built 3.2
1996 332IS
Built 3.2
1996 332IS
Built 3.2
Been doing some research and can't find a definitive answer. Is the afr bung location critical? As long as it's located "precat" everything is ok? It doesn't matter that I'm only monitoring one bank and not both? A custom exhaust is on the wish list but for now I'm sticking with the dual pipe setup I have. I mean what are the chances that Bank1 will be any different than Bank2
You don't want it too close due to heat, but you also will need to probably put it in bank 1. When I was S/Ced I welded up a H pipe and installed it in the center of it. Put it 12-16 inches down past the manifolds.
1996 332IS
Built 3.2
I put my time off request for August 6...
Now I have to get the power steering fixed, change tail lights and secure the headlights plus put the bulbs in.
THE TIME DRAWS NEAR!
Put the AFR bung somewhere convenient between the factory pre cat 02 and the cat. It should be above 9 am and 3 pm, in other words on the top half of the exhaust pipe, so condensation won't collect as much on it. One side is fine since that is all you can conveniently do. That is how I ran while supercharged from 2006-2010. Ideally add an H or X pipe later with a center bung. I converted to a turbo so I would have a single pipe for ideal AFR readings . . . .
It looks mean. Good intimidation factor. I am always scared at the strip when I line up against a car with hood pins. Especially if it is purging nitrous.
